First post, by gladders
Hi all, in my quest to build a middle machine between my 8086 DOS 3.3 machine and my PIII W98 machine, I have settled upon the motherboard attached: an IBM Valuepoint 6384/D. It comes with a 486SX 33MHz, plus a slot for an Overdrive processor.
Specs in link:
http://ps-2.kev009.com/eprmhtml/eprm/f336.htm
I understand these things are pretty picky regarding what RAM they use, and what kind of external L2 cache they use. Would these be promising?
External L2 cache:
http://www.ebay.co.uk/itm/172236058189?_trksi … K%3AMEBIDX%3AIT
RAM:
http://www.ebay.co.uk/itm/182168432969?_trksi … K%3AMEBIDX%3AIT
Also, I notice the machines these motherboards came with did not sport a Turbo button. Can you hook a turbo-buttoned AT case to it regardless, would it work? Or is there some other way to underclock it to 386 level? I presume this applies to the Overdrive processor too - what would be the best to get to maintain best compatibility spread over the three machines?
