First post, by tikoellner
 - Member
This question may seem stupid to some more experienced users, but I have the following question related to soundcards I put in my system (GUS classic / AWE32 CT2760 / Yamaha SW60XG / Ensoniq Soundscape II) - I will replace AWE32 with SB PRO 2.0 later on, as this card seems more and more redundant to me, as I don't use it's advanced features, don't like the TSR either. SB Pro 2 seems optimal to me.
I got this cards working nicely together (I select the card I want to use on boot).
The only problem I'm facing is the GM port - I have set my Yamaha at 300H and Soundscape at 330H, but this solution has some considerable limitations, as many games don't let you to select MPU-401 port, defaulting at 330H. So using Yamaha is not always possible.
My question: is it possible to set both cards at 330H to make them work simultaneously? Or will that always result with a conflict of some sort?
