Building yet another Windows 98 SE Box
First post, by squareguy
I have settled on an ASRock 775i65G R3.0 Motherboard, still available new
http://www.asrock.com/mb/Intel/775i65G%20R3.0 … =Specifications
A Intel Celeron 450 CPU (2.2 GHz), cheap and available I got another for $5.00 including shipping.
http://ark.intel.com/products/35239/Intel-Cel … GHz-800-MHz-FSB
512MB Crucial DDR400 RAM (256MB X 2)
A Quadro4 700 XGL video card (basically a GeForce4 Ti 4400 with only 64MB RAM)
Ok, so the CPU isn't sexy but remember it's faster than a Pentium 4 3.4 GHz.
3DMark 2000 scores around 15.5k with this setup with default settings. I cannot remember what 3DMark 2001 SE scored but I think it was a little over 10k but I changed it to 1280x1024. I will look again when I have time.
This will be a single boot Windows 98 SE only box. I think I am going to use a SB Live! 5.1 (SB0060) along side a Vortex 2 sound card and maybe a Yamaha software synth.
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 1 of 59, by SRQ
A Celeron 450 is faster than a P4 3.4?!?!
Absolutely no way, what.
E: Read that as 450mhz and I'm dumb >.> Leaving this here so you can laugh at my dumb.
Reply 2 of 59, by squareguy
Lol I should have posted its speed and not just model number.
I misspoke, it's a hair slower than a P4 3.4 and a little faster than a 3.2
Single threaded performance from PassMark
Pentium 4 3.2: 694
Celeron 450: 731
Pentium 4 3.4: 736
Honestly that is plenty fast for me. Remember this motherboard can go much, much faster if needed.
Windows 98 SE
Reply 3 of 59, by SRQ
I didn't click your link and made dumb assumptions.
DDR should've tipped me off.
Reply 4 of 59, by Nopileus
Looks like that Celeron is more of less half a Core2Duo, pretty fast.
I've been running a 1.8 P4 Northwood alongside a GF4 ti 4200 and the obligatory vortex 2 and have yet to hit its limit. Probably just running the wrong games. 😵
The Aureal software wavetable sounds surprisingly good, waveblaster modules also work in proper DOS though.
Any reason why you went for a 775 platform?
Reply 5 of 59, by PhilsComputerLab
Good point Nopileus!
For me, I use Windows 98 mostly for Aureal A3D games 😀
Your P4 should run any Windows 98 era game. Often I see people run and benchmark games on their Windows 98 machines, that are fully supported under Windows XP anyway.
Reply 6 of 59, by squareguy
I went for 775 for a few reasons.
#1 It's still available brand new
#2 it's not collectible
#3 it's plenty fast with no overclocking or tricks
#4 it's a 35 Watt TDP CPU so it's not a room heater
#5 since it's still available brand new and not collectible if it fries my feeling aren't hurt
I am stocking up for other spare parts
Windows 98 SE
Reply 7 of 59, by Nopileus
I blame you for getting me into all this to begin with Phil,
otherwise i wouldn't have known how criminally cheap this 478 era stuff is. The Dreamblaster S1 is on you too 😀
Late 2000 is about the furthest i've gone in terms of games for now, Starlancer and NOLF being notable. Still plenty of room to go further.
Actually the TDP argument is a pretty good point, i chose the 1.8 Northwood specifically because the 2.8E Prescott that came with my motherboard was just way too hot.
Reply 8 of 59, by PhilsComputerLab
That's awesome 😊
I'd love to buy that board. With Newegg Australia I'm looking at A$110 shipped, which is fair enough, but not a bargain either.
The power draw is a good argument. The 478 Northwood chips aren't too bad, but they are by no means energy efficient processors.
Reply 9 of 59, by squareguy
Wow Phil. That's almost double what I paid, taking exchange rate into account. Maybe you could get lucky and find one locally.
Windows 98 SE
Reply 10 of 59, by PhilsComputerLab
Yes, but like you, I'd love to have this board NIB 😀
Reply 11 of 59, by nforce4max
Nelson from the Simpsons going "ha ha"
Reply 12 of 59, by nforce4max
PhilsComputerLab wrote:
That's awesome 😊
Play with some P4 mobiles as they work in normal 478 boards, the mobiles have two multiplier states but that requires a single from the chipset for the high state so on normal boards they only default to the low state (1.2ghz or 12x100) so they only sip power. They are good for high clocking boards 😉
The common P4 mobiles only pull 35 to 45w at their high state but on the low it is a lot less so have fun.
Reply 13 of 59, by PhilsComputerLab
Interesting, didn't know that!
Reply 14 of 59, by SRQ
Interesting idea: What's the lowest wattage processor that works with DOS and 98SE stuff and is equivalent to a baseline of, say, a PIII 900?
Reply 15 of 59, by PhilsComputerLab
Well the P III is faster, clock for clock, compared to the P4. But the P4 starts, I think, at 1.4 GHz, so that chip should do the trick 😀
Reply 16 of 59, by Rhuwyn
Interesting Question. Obviously in order to support 16bit code it must be a 32bit processor. Maybe a Pentium M, or Athlon-XP mobile? Perhaps one of the last Intel Atom's before they moved to 64bit. Not sure how one of those Atoms would compare to a Pentium3.
Reply 17 of 59, by Nopileus
I remember there being some desktop boards supporting core solo and core duo processors, those might take the cake if an atom isn't fast enough.
Reply 18 of 59, by SRQ
But would they still run well with 98? I'm not counting it if there's serious compat errors or DOS mode is unusable.
My basic idea is could one create a passive-cooled super low watt 9X machine?
Reply 19 of 59, by archsan
^How about underclocked Celeron 4x0?
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
