What's your favorite thermal compound?
First post, by clueless1
My last tube of Arctic Silver 5 is about done, so I need to think about ordering more thermal compound. What do you guys like to use? Preferably simple application that can be removed easily.
Reply 2 of 58, by luckybob
whatever is cheapest.
Seriously it does not matter very much.
Reply 3 of 58, by PhilsComputerLab
I use MX-4.
YouTube, Facebook, Website
Reply 4 of 58, by ODwilly
The Antec Diamond stuff is good if you can get it on sale for half price, mx-4 like Phil said is great, I like Ceramique 2 myself. Pretty much anything is better than nothing. Used toothpaste once on a P4, worked great and had no issues.
Reply 5 of 58, by Arctic
PhilsComputerLab wrote:
I use MX4.
Me too.
Reply 6 of 58, by Jorpho
gdjacobs wrote:
I like to use Vegemite.
http://www.dansdata.com/goop.htm
Heh heh. Sounds like a plot point from a cheezy movie.
"The tournament starts in ten minutes, and my rig is fried! What are we gonna do?"
"I have an idea! But whatever you do, don't do That Thing, or the whole thing will blow!"
"Oh no, Evil McBadguy is gonna win! I have no choice! I have to do That Thing!"
"Noooo, the vegemite can't take it! What have you done!?"
Reply 7 of 58, by Nopileus
Arctic MX-4 for low mounting pressure and Gelid GC-Extreme for high mounting pressure.
MX-4 is pretty good for general use and very easy to work with, i'd recommend it.
Reply 8 of 58, by Kahenraz
I've used Arctic Silver for years but I'm getting tired of how difficult it is to clean and also to remove from fingers as it is both thick and sticky. I've recently switched to Noctua NT-H1. I'm also considering buying some Arctic Ceramique as I just recently glooped some AS5 into a processor LGA socket.. and it was NOT fun to clean out.
Reply 9 of 58, by ODwilly
The ceramique is really difficult to clean just to warn you. Not terrible, it just seems to really be sticky ya know?
Reply 10 of 58, by mr_bigmouth_502
Arctic Silver 5 used to be my go-to, but Arctic Cooling MX-4 is alright too. I've discovered that dielectric grease for car ignitions will work in a pinch if you can't find any proper thermal compound.
Reply 11 of 58, by gdjacobs
In a pinch you can use the ointment for diaper rash (high content zinc oxide).
Reply 12 of 58, by clueless1
If I'm switching cpus, there's usually enough residual Arctic Silver on the bottom of the heatsink that I can redistribute it with a finger and it's enough to not have to reapply.
Reply 13 of 58, by archsan
I second Gelid GC Extreme!
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 14 of 58, by nforce4max
Gelid GC Extreme because it is one of the very best and it is easy to clean up plus there is really no cure time unlike as5. I use the cheap stuff on older hardware if it doesn't have a exposed die.
Reply 15 of 58, by ElBrunzy
I buy of toothbrush pouch sized pack of MG Chemical paste as I very often swap processors units. It's cheap and score higher on review than single use arctic silver seringe.
Reply 16 of 58, by Jade Falcon
Rank BANNED
BANNED
Well for me it depends.
If I want the best temps I got for liquid copper, mx4 or nh-1.
If it's for someone else's pc or temps aren't a big deal I used what ever is available and cheap.
If it's for a sub zero run I use dimastech Thermal Grease. It's about 9$ for a 100g so I use it when temps are not a big deal too.
Reply 17 of 58, by mr_bigmouth_502
Is it worth trying any brands other than MX-4 or Arctic Silver 5? There are tons of different types of thermal compound out there and it would be nice to know what situations different brands are suited for.
Reply 18 of 58, by Jorpho
They're for when you have too much money and a burning anxiety that can only be soothed by the promises of marketers.
Reply 19 of 58, by Jo22
I'm surprised no one mentioned play-doh so far.. 😁
