If you can get the current CVS, DosBox has support for floppy and hard disk images.
The way I've implemented it, however, won't help you much unless you're willing to create a hard drive image and install MS-DOS 6.22 first.
That aside, there's a real easy way to install... use WinImage to dump all of the files from images into a single directory and install from there. The Windows install won't have any problems.
If you'd like to go the hard disk image route, here's how you do it...
Use BXIMAGE from Bochs to create your hard drive image (70MB should be good... doesn't work with anything larger ATM)
Then, in dosbox, type imgmount d <filename of image on host filesystem> -size <drive size parameters> -fs none
(For example: imgmount e: d:\test.img -size 512,63,16,142 -fs none)
Then, boot off of a DOS disk with 'boot <name of dosimage floppy>' (no quotes, of course.
In real DOS, fdisk and format (with system install) that hard drive image (which will now be at C, since real DOS doesn't see any of DosBox's mounted directories). Since an fdisk will require a reboot, shut down DosBox and start again, typing in the same imgmount and boot command... formating this time in DOS.
Restart DosBox... again this time,
(note no -fs none this time.. You'll actually be able to see the mounted image, file system and all, in your DosBox session)
type boot <windowsdisk1> <windowsdisk2> <windowsdisk3> <windowsdisk4> <etc> -l c
the "-l c" will boot off the hard drive. I hope you formated that drive with the system option! 😁 For example, to load up the windows disks, you might type: boot WIN1.IMG WIN2.IMG WIN3.IMG WIN4.IMG -l c. This all assumes that you are typing boot inside DosBox in a directory where those images are. Finally, run the setup on the first disk in drive A:. When it asks for the next disk, swap it by hitting the Ctrl-F4 key. This will swap out disk1, and bring in disk2. The next hit of Ctrl-F4 will swap in disk3, and so on until it comes back around to disk1.
I hope this makes sense. Like I said, its probably just easier for you to extract all those files to a single directory and install from there. I will say this, however, Windows in DosBox is more stable when booted to real MS-DOS.
