First post, by bluejeans
I can't find anything older than pentium 4's being sold locally (as in, e-waste shops) and not going to pay ebay prices. Got my pentium 166 back from 1998 that I sold to my neighbour. He whacked it in this case though:
It actually lets you use 72 pin edo ram and sdram side by side! It came with 128mb sdram and 2x4mb edo. I got 2x8's from a friend (who thinks they're "rare as rocking horse poo" but he must be thinking of 64's) in it and took the sd's out, underclocked it to 90mhz as I wanted to experience as close to my 386dx-40 first doom experience as possible. Check out that SCSI burner! He lost the card for it though. I didn't need it as I raised $500 for an ide 4x burner which is a pretty good effort for a then-15 y/o, selling computer crap that was even older than what I had (I think a cyrix 686-200 at the time)
Absolute havoc inside:
Does anyone know if moslo 4biz allows you to set a clock rate equivalent to a 386/486? The deluxe version has this.
Reply 1 of 4, by clueless1
Check the link in my signature. I maintain a database of benchmarks with and without caches enabled, using the utility 'setmul'. It allows my Pentium Overdrive 200MMX to run as slow as a 386DX-25, and it works in software without the need to reboot. 😀 Forum member gerwin is the author of 'setmul'.
Reply 2 of 4, by brassicGamer
Dude, I'll look at the system if you can reduce the size of your images - either before you upload them or by attaching them to the post itself. Or check out Stiletto's guide on using IMGUR with Vogons. Welcome, by the way 😀
Reply 3 of 4, by Stiletto
Edited 😁 😜
do the Fandango!" - Queen
Stiletto
Reply 4 of 4, by shiva2004
Only posted to say that my first computer has exactly the same case. In fact, I've seen it a lot of times in this forum, whoever made them must have sold a ton of them.
