First post, by lindylex
I have tried "Creative Sound Blaster 16" and they throws the following errors.
sb16: warning: command 0x5,2 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x8,0 is not truly understood yetsb16: warning: command 0x3,0 is not truly understood yetsb16: warning: command 0x5,2 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0xe,2 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0xf,1 is not truly understood yet
sb16: warning: command 0xf,1 is not truly understood yetsb16: warning: command 0x4,1 is not truly understood yetsb16: warning: command 0x8,0 is not truly understood yetsb16: warning: command 0x3,0 is not truly understood yetmain-loop: WARNING: I/O thread spun for 1000 iterations
I want to try to get audio for Windows 3.11 Workgroup working using one of the following emulated audio cards.
es1370 ENSONIQ AudioPCI ES1370
ac97 Intel 82801AA AC97 Audio
adlib Yamaha YM3812 (OPL2)
gus Gravis Ultrasound GF1
Can you point me to the drivers for the card you think I will have the most success with and instructions to get it to work with Windows 3.11.
I tried to install Ensoniq but I think it is for DOS only or I do not know how to get them to work in Windows 3.11.
This is the copy from the help file for Ensoniq.
Instructions for installing the Ensoniq DOS drivers for your AudioPCI card and Creative cards that are rebranded Ensoniq AudioPCI cards.Installation is simple!Copy the AUDIOPCI folder into the root directory of C:So basically after you have copied the folder you want to have C:\AUDIOPCI with all the files in that folder!Next open the supplied AUTOEXEC.BAT (or copy from this file) and copy paste 4 lines into your own AUTOEXEC.BATSET BLASTER=A220 I5 D1 T2SET SNDSCAPE=C:\AUDIOPCIC:\AUDIOPCI\APINIT.COMC:\AUDIOPCI\APLOAD.EXE
