First post, by Konsumsklave
Sorry for the OT post but i hate registering so feel free to move it to the games section
When i try to start wing commander it says
"ems driver is not vcpi complaint"
unless i deactivate the ems support
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
xms=true
ems=false
Ironically the "mem" command still states that ems is aviabable
(free extended, free expanded memory)
And when i try to start wing commander armada it says
"network driver detected cannot switch to protedted mode safely".
Ironically Wing commander Armada is a multiplayer game and should not have problems with network drivers so is this a dosbox error message ?
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
ipx=false.
and you used a cvs version of dosbox so actually I should ignore this question.
Water flows down the stream
Reply 2 of 2, by Magamo
Also, you're going to want to loadfix out 64k of memory, Armada won't load unless you do.
I still say its odd that a Network game won't work with a network driver loaded... Silly Origin. 😀
