First post, by foey
I've just swapped out a Western Digital WD400 to a Samsung PATA 160Gb Drive on my Athlon 2100 XP system (MSI KT3Ultra2 Motherboard) and now I'm not getting any HDD activity light on the case
I swapped the drive back and works once again. Assuming this is PATA controller related? Anyone had/noticed this?
Thanks,
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 1 of 2, by gdjacobs
What BIOS revision are you running? I'd update to the latest in case >128GB disk support was patched in. Version 5.7 dated 24-Feb-2003 is the release you want.
Reply 2 of 2, by foey
I think I've found the issue. When I removed the cable I noticed that the plastic which holds the cable on the connectors was broken, the ribbon cable was slightly off the pins one side.
I swapped the cable and it's now working! Strange how it worked with the previous drive when I reconnected it.
Thanks for the advice, I made sure the board was updated before swapping the drives.
