First post, by Oldskoolmaniac
I have a bunch of socket 370, 462 and 478 mothe boards laying around and im running slim on good coolers. Im wondering if anyone have modyfied any of the newer coolers to fit their boards to keep overclocking temps down.
Just trying to get idea's here.
The kind of coolers that stand straight up and have dual fans would be awesome to rig that to a socket 462, those cpu's run hot!
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 1 of 23, by ODwilly
You can still buy them new, or pick em up for cheap on Ebay.
Reply 2 of 23, by Vincent_Vega_SA
Here is a picture of my S370 setup with DUAL FAN cooling system, just as an idea 😊
1.65 MiB
Reply 3 of 23, by Oldskoolmaniac
^^^least it cools the ram as well
Reply 8 of 23, by F2bnp
There is that Startech copper cooler that works really well with socket 370.
As far as socket A and 478 are concerned, your only option is to track down big, copper coolers from the era unfortunately 🙁.
Reply 9 of 23, by awgamer
Either make your own or marry the mounting from an old crummy 370/462/478 cooler to a present day cooler like the evo 212, now you have all the cooling you need with way bigger coolers than during that time.
Reply 10 of 23, by PhilsComputerLab
StarTech have a 478 cooler, but looking at it I think it's good up to 2.8 or maybe 3 GHz. I can't stand the boxed coolers, they are a pain to remove and work with...
YouTube, Facebook, Website
Reply 11 of 23, by Oldskoolmaniac
Yea the copper startech cooler for socket 370 are good, but idk if they would keep the socket 462 cool enough though.
As for the socket 478 I did this to my one computer I call blackmagic and overclock the crap out of it, but i would like to find a better way of doing it then this...
    2.51 MiB
Reply 12 of 23, by Logistics
I wonder if there were any of these plug-n-play water-cooling setups around, back then. I'd like to use one on a 478 system, but I've never built one of the custom water-cooling setups.
Reply 13 of 23, by ODwilly
Hey you could always mount one of those 15k rpm Delta fans on a bare cpu. Just rig it up to float over the top of it with some zip ties! Who needs heatsinks when you have MASSIVE AIRFLOW!!!
Reply 14 of 23, by mr_bigmouth_502
Isn't it kind of necessary to have a heatsink of some sort to keep the CPU from cooking itself?
Reply 15 of 23, by ODwilly
Im not sure. Depends on how much air you can move. I tested a bunch of cpus on a 478 dell with a fast 80mm fan blowing over it on the bench and it stayed cool
Reply 16 of 23, by Oldskoolmaniac
Im pretty sure having a heatsink will take of a few degrees cause it transfers it from the cpu, also heat rises upward.
Reply 17 of 23, by Tetrium
Do not make fun of massive airflow, once you seen such a powerfan in action, it will blow you away 😎
My retro rigs (old topic)
Report spammers here!
Reply 18 of 23, by Kodai
If I remember correctly, the 478 can be made to work with 775 towers and water blocks. Just pop out the plastic surround and you can then use those socket 775 "X" shaped retention brackets to the back of the motherboard.
The holes for that junky plastic surround are a perfect match for the mounting holes of socket 775, but the socket is a wee bit taller. Just adjust the mounting pressure to be a bit less.
Reply 19 of 23, by Aideka
There sure is a way to mount 775 coolers on socket 478, and some coolers work without brackets too https://www.youtube.com/watch?v=iPGPRYylj5o
