First post, by skaarj
Latest openglide with several modifications specifically tested for UT99 in Windows. Attached source code and binaries.
Vsync set by wglSwapInterval=1 (given video card supports this extension). If InitFullScreen=1, then press F11 in UT99 to reacquire the in-game brightness level. Also, the wrapper's gamma function has been disabled since it depends on compatibility between win32 api and video driver. Instead it is ideal, if necessary, to use driver settings for gamma level.
To build in mingw32/gcc:
./bootstrap
./configure --disable-sdl
make
[manual step: rename libglide2x.dll to glide2x.dll]
Glide2x.dll binary dependent on two mingw32 c/c++ runtime libraries. Edit settings in OpenGLid.ini. These four files may be copied to game directory (UT99's /System/) after backing up any installed copy of glide2x.dll.
This package is for experienced users only. User is responsible for installation and any issues that may arise.
    openglide-ut-1.zip
    408.76 KiB
    1038 downloads
    win32 openglide for ut99 (ver 1)
Reply 1 of 5, by skaarj
Attached source code below.
    openglide-ut-1-src.zip
    219.52 KiB
    1022 downloads
    openglide-ut-1 source code
Reply 4 of 5, by skaarj
Added two previously posted patches and reverted borderless window mode.
Resolution: set a value of 0 to turn off scaling or 1 through 16 to specify a scaling factor. May test with fractional values. For example, where Resolution=2 and InitFullScreen=0, then window size is scaled by two times.
    openglide-ut-2.zip
    408.98 KiB
    913 downloads
    win32 openglide for ut99 (ver 2)
    openglide-ut-2.diff
    5.46 KiB
    936 downloads
    Apply this patch (ver 2) to source code in first post of thread
Reply 5 of 5, by skaarj
I am unable to incorporate or test the attached code since it is for Tomb Raider, but it contains a change which was previously suggested as a fix for the appearance of "triangular shadows" near the game start. The "SmoothShading" setting is off by default, but set SmoothShading=1 to activate the fix.
    smooth_shading.diff
    2.59 KiB
    937 downloads
    openglide patch for tomb raider (code untested)
