First post, by clueless1
System: P2-400Mhz, Voodoo3 2000 PCI, Win98SE (unpatched)
When I run GLQuake with Glide, it runs perfectly, but at 640x400x16. Looks great, but there is an 80 pixel space at the top. I've tried creating an MS-DOS Prompt shortcut and adding -width 800 -height 600 to the end of the command line. What happens is it starts, I see the "Starting Quake" rectangle in the center of the screen, then I see the 3dfx logo, then I get a black screen with a mouse cursor. The mouse cursor moves around, but disappears towards the edges of the screen. I can't ALT-TAB back to the desktop, and CTRL-ALT-DEL does nothing. I have to hit the power button on the PC. I've also tried -width 1024 -height 768 and that does the same thing. These resolutions work fine on the Windows desktop, and they work in Half Life.
I've also tried opening an MS-DOS command prompt window, navigating to the Quake folder, and launching from there:
c:\windows\desktop\quake\glquake.exe -width 1024 -height 768
Same issue.
I'm running the AmigaMerlin drivers.
I've renamed the opengl32.dll driver in the folder to force the native Glide driver.
Any ideas?
Reply 1 of 3, by PhilsComputerLab
Try the attached version.
My process for installing GLQuake:
- Burn the BIN / CUE from GOG.com
- Install Win Quake
- At the end it asks for GLQuake and 3dfx support: Say no!
- Then run the GLQuake installer
V3 has full OpenGL support and is fast enough, so it should work out of the box. MiniGL can boost performance, but one thing at a time.
For benchmark for example I use this shortcut:
glquake.exe +timedemo demo1 -width 1024 -height 768 -bpp 16 -nocdaudio
For gaming this should work:
glquake.exe -width 1024 -height 768 -bpp 16
YouTube, Facebook, Website
Reply 3 of 3, by Gamecollector
GLQuake includes the very old minigl version (1.1?). It may be even pre-Voodoo2 so 640x480 only.
Just update to versions 1.47 or 1.49 and try again. These versions work correctly up to 1024x768 for me.
