IBM PC AT emulation crashing?
First post, by superfury
I've improved the 80286 protected mode a lot the last week. I've tried running the IBM AT BIOS with it, but eventually (before even showing anything or initializing the video adapter), it crashes with a HLT instruction with the Interrupt flag being 0(meaning it will stop doing anything because there's no coprocessor(x87 FPU) making it resume, nor any hardware can wake it up(since the interrupt flag is 0).
I see that the CMOS is written, eventually receiving the values into the status register reaches 0, 1 etc. until it reaches 0x80, then 0x00. I also see a little bit of output to the 0x3DX port range(VGA graphics card).
Anyone knows why the BIOS terminates itself and enters an infinite loop?
Main protection module: https://bitbucket.org/superfury/unipcemu/src/ … ion.c?at=master
Multitasking module: https://bitbucket.org/superfury/unipcemu/src/ … ing.c?at=master
80286 instructions: https://bitbucket.org/superfury/unipcemu/src/ … 286.c?at=master
General timings lookup table (for modr/m settings): https://bitbucket.org/superfury/unipcemu/src/ … ngs.c?at=master
ModR/M decoding and addressing: https://bitbucket.org/superfury/unipcemu/src/ … drm.c?at=master
80186(NEC V30) instructions subset: https://bitbucket.org/superfury/unipcemu/src/ … V30.c?at=master
8086 instructions subset: https://bitbucket.org/superfury/unipcemu/src/ … 086.c?at=master
Normal jumptables: https://bitbucket.org/superfury/unipcemu/src/ … bls.c?at=master
0F opcode jumptables: https://bitbucket.org/superfury/unipcemu/src/ … s0f.c?at=master
Flag calculations: https://bitbucket.org/superfury/unipcemu/src/ … ags.c?at=master
CPU core functionality: https://bitbucket.org/superfury/unipcemu/src/ … cpu.c?at=master (CPU_exec is the main CPU instruction fetching and decoding, finally passing control to the execution(which is in the opcodes files).
Interrupt handling: https://bitbucket.org/superfury/unipcemu/src/ … pts.c?at=master
(80386 32-bit extensions of the 8086 instructions (WIP): https://bitbucket.org/superfury/unipcemu/src/ … 386.c?at=master )
The entire core is built, so that each module (8086, 80186, 80286, 80386, 80486, Pentium) only supplies the new instruction opcodes that are added each processor. So the 80286 in this case, uses the 80286, 80186(NEC V30) and 8086 instruction core for it's full instruction set.
Anyone can see why the IBM AT BIOS crashes with the current instruction set? I know that the hardware should all be emulated correctly (The Turbo XT BIOS works without problems on the NEC V30(186) core. The only addition the 286 adds is protected mode with a few new instructions(besides a wider address bus with 24-bits instead of 20 bits address space)?
Edit: I've added a simple port 80h (Diagnostics port) output to the Settings menu. It displays the code 08h? Does this mean there's a problem with my DMA Page register emulation?
UniPCemu Git repository
Reply 1 of 151, by superfury
Looking at the IBM PC AT source code from http://www.intel-assembler.it/portale/5/ibm-a … -souce-code.asp
The relevant test executed:
	MOV	AL,08H	;	  <><><><><><><><><><><><>
OUT MFG_PORT,AL ; <><> CHECKPOINT 08 <><>
SUB AL,AL
MOV DX,DMA_ PAGE
MOV CX,0FFA ; DO ALL DATA PATTERNS
C22A: OUT DX,AL
INC DX
INC AL
CMP DX,8FH ; TEST DMA PAGES 81 THROUGH 8EH
JNZ C22A
XCHG AH,AL ; SAVE CURRENT DATA PATTERN
DEC AH ; CHECK LAST WRITTEN
DEC DX
C22B: SUB AL,AL ; CHANGE DATA BEFORE READ
IN AL,DX
CMP AL,AH ; DATA AS WRITTEN?
JNZ C26 ; GO ERROR HALT IF NOT
DEC AH
DEC DX
CMP DX,MFG_PORT ; CONTINUE TILL PORT 80
JNZ C22B
INC AH ; NEXT PATTERN TO RIPPLE
MOV AL,AH
LOOP C22A
;----- TEST LAST DMA PAGE REGISTER (USED FOR ADDRESS LINES DURING REFRESH)
MOV AL,0CCH ; WRITE AN CC TO PAGE REGISTERS
C22: MOV DX,LAST_DMA_PAGE
MOV AH,AL ; SAVE THE DATA PATTERN
OUT DX,AL ; OUTPUT PAGE REGISTER
;----- VERIFY PAGE REGISTER 8F
SUB AL,AL ; CHANGE DATA PATTERN BEFORE READ
IN AL,DX ; GET THE DATA FROM PAGE REGISTER
CMP AL,AH
JNZ C26 ; GO IF ERROR
CMP AH,0CCM
JNZ C25 ; GO IF ERROR
MOV AL,033H ; SET UP DATA PATTERN OF 33
JMP C22 ; DO DATA 33
C25:
CMP AH,0 ; CHECK DONE
JZ C27 ; GO IF YES
SUB AL,AL ; SET UP FOR DATA PATTERN 00
JMP C22 ; DO DATA 0
;----- ERROR HALT
C26:
HLT ; HALT SYSTEM
This means that the BIOS expects the unmapped adress ranges from 0x81-0x8F(only 0x81, 0x82, 0x83, 0x87, 0x89, 0x8A, 0x8B an 0x8F being available and existent on the ISA DMA chip's page registers) to be available and stored for some reason?
Edit: Implementing those dummy registers makes the diagnostics code increase to 09(Memory Refresh).
Edit: After implementing toggling bit 4 on every DRAM Refresh, it now increases to 0C(In the middle of the 8042 self test)?
Reply 2 of 151, by Jepael
No they are not unmapped, just not used for anything useful. The LS612 has 4 address lines so it uses the whole address range 0x80-0x8F.
Reply 3 of 151, by superfury
OK. I've added the missing 0x80 port as well(although it's output port is shared with the 0x80 MFG_PORT debug port, this is no problem, since it's an output port(it gives no input to the software, thus no conflicts)). That part passes completely now. It still won't get past checkpoint 0C. Strangely enough, the breakpoint won't start correctly? When the port is written, the debugger starts the next instruction. But the next instruction isn't the same as in the source code?
	MOV	AL,0CH	;	  <><><><><><><><><><><><>
OUT MFG_PORT,AL ; <><> CHECKPOINT OC <><>
JNZ ERR0 ; GO IF NOT OK
;----- GET THE SWITCH SETTINGS
MOV AL,READ_8042_INPUT ; READ INPUT COMMAND
MOV SP:OFFSET C8042C ; SET RETURN ADDRESS
JMP SHORT C8042 ; ISSUE COMMAND
E30B: MOV SP,OFFSET OBF_42B ; SET RETURN ADDRESS
JMP SHORT OBF_42 ; GO WAIT FOR RESPONSE
E30C: IN AL,PORT_A ; GET THE SWITCH
OUT DMA_PAGE+1,AL ; SAVE TEMPORARY
;----- WRITE BYTE 0 OF 8042 MEMORY
MOV AL,WRITE_8042_LOC ; WRITE BYTE COMMAND
MOV OFFSET C8042B ; SET RETURN ADDRESS
JMP SHORT C8042 ; ISSUE THE COMMAND
TST4_D: JZ TST4_D1 ; CONTINUE IF COMMAND ACCEPTED
MOV AL,ODH ; <><><><><><><><><><><><>
OUT MFG_PORT,AL ; <><> CHECKPOINT 0D <><>
HLT
TST4_D1:
MOV AL,5DH ; ENABLE OUTPUT BUFFER FULL INTERRUPT,
OUT PORT_A,AL ; DISABLE KEYBOARD, SET SYSTEM FLAG,
JMP SHORT E30A ; PC 1 COMPATIBILITY, INHIBIT OVERRIDE
;----- ISSUE THE COMMAND TO THE 8042
C8042: CLI ; NO INTERRUPTS ALLOWED
OUT STATUS_PORT,AL ; SEND COMMAND IN AL REGISTER
SUB CX,CX ; LOOP COUNT
C42_1: IN AL,STATUS_PORT ; WAIT FOR THE COMMAND ACCEPTED
TEST AL,INPT_BUF_FULL
LOOPNZ C42_1
RET
;----- WAIT FOR 8042 RESPONSE
OBF_42: SUB CX,CX
MOV BL,6 ; 200MS/PER LOOP * 6 =1200 MS +
C42_2: IN AL,STATUS_PORT ; CHECK FOR RESPONSE
TEST AL,OUT_BUP_FULL
JNZ C42_3 ; GO IF RESPONSE
LOOP C42_2 ; TRY AGAIN
DEC BL ; DECREMENT LOOP COUNT
JNZ C42_2
C42_3: RET ; RETURN TO CALLER
; TEST.11 :
; BASE 64K READ/WRITE MEMORY TEST :
; DESCRIPTION :
; WRITE/READ/VERIFY DATA PATTERNS :
; AA,55,FF,01, AND 00 TO 1 ST 64K :
; OF STORAGE, VERIFY STORAGE :
; ADDRESSABILITY. ;
…Show last 7 lines
;----- FILL MEMORY WITH DATA
E30A: MOV AL,0EH ; <><><><><><><><><><><><>
OUT MFG_PORT,AL ; <><> CHECKPOINT 0E <><>
UniPCemu debugger log when testing from the point the value is set to 0Ch:
The attachment debugger.log is no longer available
I've implemented a bit more of the protected mode segments in real mode, so that stuff like unreal mode will work. Any load to any segment in real mode causes the segment descriptor's base fields to be updated with a new base, while it's high 12 bits are cleared(conforming to 8086-mode 20-bits base addresses).
It now crashes at checkpoint 0B?
Reply 4 of 151, by superfury
These are the current CPU source code:
https://bitbucket.org/superfury/unipcemu/src/ … /cpu/?at=master
The 8086 module is already copied to the 80386 module, with the 80386 code adjusted for 32-bits operand size and the timings.c tables for the 80386 implemented as a copy of the 8086 timings, but with 16-bit instructions adjusted to 32-bits(3rd byte of each enter becomes 2(32-bits data modr/m) instead of 1(16-bits data modr/m). I still need to fix the final parameter(immediate word) to specify immediate doubleword. The same applies to the instruction for JMP immediate seg:offs that's reimplemented. Also, the loop* instructions still need proper 32-bit versions.
I've tried booting the Generic Super PC/Turbo XT BIOS on the 80286, but it keeps clearing memory using STOSW infinitely? Does this mean there's a problem with the segment descriptor implementation in real mode? I don't see any protections being fired(#GP, #NP or #SS)? Anyone can see what's going wrong? Can IBM PC XT bioses even run on a IBM PC AT?
Edit: I've just found out by examining the source code of the 286 AT BIOS, that I was working with the 06/10/85 BIOS source code(from intel-assembler) and the first revision of the BIOS(01/10/84) BIOS. I've redownloaded the correct BIOS from minuszerodegrees to verify the correct BIOS...
Edit: It now gets to the diagnostic point 0C again. After looking at the disassembly by the emulator and the disassembly by the original source code by IBM, I notice something odd:
The DMA page register test I'm using for setting a breakpoint in the BIOS is being overwritten with incorrect values during the DMA Page Registe test (Test 08):
; TEST.08 :
; DMA PAGE REGISTER TEST :
; DESCRIPTION :
; WRITE/READ ALL PAGE REGISTERS :
;----- CHECKPOINT 08
SUB AL,AL
MOV DX,DMA_ PAGE
C22A: OUT DX,AL
INC DX
INC AL
JNZ C22A
DEC DX
IN AL,DX
DEC AH
DEC DX
JNZ C22B
MOV AL,AH
LOOP C22A
When it reaches the final INC AH in the C22B block, register DX equals the MFG_PORT constant (0x80). Thus the first port rippled with every next pattern(except the first pattern) is port 80h(the diagnostics port, which also sets a breakpoint when set using the Settings menu, in this case 0x0C). Thus the debugger starts when the value 0x0C is written to port 80h. But this isn't the correct value: it's one of the loops at the end of C22B putting a DMA Page register test pattern in the Diagnostics port instead of a DMA Page register?
This problem happens for all loops executed, only the first loop(starting point at checkpoint 08 comment) starts with the correct DMA Page Register port?
Edit: It seems I was right, it DOES log it's rippled test data to the Diagnostics Port. But it does end up at 0C afterward(like I thought):
00:00:19:18.02834: POST Code: 01
00:00:19:18.03530: POST Code: 02
00:00:19:53.05798: POST Code: 03
00:00:19:53.06102: POST Code: 04
00:00:19:53.06192: POST Code: 05
00:00:19:53.06280: POST Code: 06
00:00:19:53.07336: POST Code: 07
00:00:19:53.08588: POST Code: 08
00:00:19:53.09036: POST Code: 00
00:00:19:53.09524: POST Code: 01
00:00:19:53.09972: POST Code: 02
00:00:19:54.00454: POST Code: 03
00:00:19:54.01054: POST Code: 04
00:00:19:54.01522: POST Code: 05
00:00:19:54.01996: POST Code: 06
00:00:19:54.02572: POST Code: 07
00:00:19:54.03136: POST Code: 08
00:00:19:54.03708: POST Code: 09
00:00:19:54.04268: POST Code: 0A
00:00:19:54.04916: POST Code: 0B
00:00:19:54.05536: POST Code: 0C
00:00:19:54.06052: POST Code: 0D
00:00:19:54.06560: POST Code: 0E
00:00:19:54.07076: POST Code: 0F
00:00:19:54.07584: POST Code: 10
00:00:19:54.08062: POST Code: 11
00:00:19:54.08528: POST Code: 12
00:00:19:54.08998: POST Code: 13
00:00:19:54.09488: POST Code: 14
00:00:19:54.09958: POST Code: 15
00:00:19:55.00462: POST Code: 16
00:00:19:55.00912: POST Code: 17
00:00:19:55.01404: POST Code: 18
00:00:19:55.01852: POST Code: 19
00:00:19:55.02322: POST Code: 1A
00:00:19:55.02770: POST Code: 1B
00:00:19:55.03262: POST Code: 1C
00:00:19:55.03710: POST Code: 1D
00:00:19:55.04158: POST Code: 1E
00:00:19:55.04648: POST Code: 1F
00:00:19:55.05096: POST Code: 20
00:00:19:55.05566: POST Code: 21
00:00:19:55.06054: POST Code: 22
00:00:19:55.06788: POST Code: 23
00:00:19:55.07260: POST Code: 24
00:00:19:55.07794: POST Code: 25
00:00:19:56.03544: POST Code: 26
00:00:19:56.04038: POST Code: 27
00:00:19:56.04514: POST Code: 28
00:00:19:56.04962: POST Code: 29
00:00:19:56.05456: POST Code: 2A
00:00:19:56.05902: POST Code: 2B
00:00:19:56.06372: POST Code: 2C
00:00:19:56.06858: POST Code: 2D
00:00:19:56.07330: POST Code: 2E
00:00:19:56.07798: POST Code: 2F
00:00:19:56.08298: POST Code: 30
00:00:19:56.08744: POST Code: 31
00:00:19:56.09234: POST Code: 32
00:00:19:56.09680: POST Code: 33
…Show last 207 lines
00:00:19:57.00146: POST Code: 34
00:00:19:57.00634: POST Code: 35
00:00:19:57.01184: POST Code: 36
00:00:19:57.01730: POST Code: 37
00:00:19:57.02178: POST Code: 38
00:00:19:57.02672: POST Code: 39
00:00:19:57.03116: POST Code: 3A
00:00:19:57.03660: POST Code: 3B
00:00:19:57.04150: POST Code: 3C
00:00:19:57.04598: POST Code: 3D
00:00:19:57.05042: POST Code: 3E
00:00:19:57.05530: POST Code: 3F
00:00:19:57.05976: POST Code: 40
00:00:19:57.06424: POST Code: 41
00:00:19:57.06870: POST Code: 42
00:00:19:57.07364: POST Code: 43
00:00:19:57.07836: POST Code: 44
00:00:19:57.08282: POST Code: 45
00:00:19:57.08728: POST Code: 46
00:00:19:57.09216: POST Code: 47
00:00:19:57.09780: POST Code: 48
00:00:19:58.00254: POST Code: 49
00:00:19:58.00756: POST Code: 4A
00:00:19:58.01256: POST Code: 4B
00:00:19:58.01704: POST Code: 4C
00:00:19:58.02150: POST Code: 4D
00:00:19:58.02642: POST Code: 4E
00:00:19:58.03112: POST Code: 4F
00:00:19:58.03558: POST Code: 50
00:00:19:58.04044: POST Code: 51
00:00:19:58.04494: POST Code: 52
00:00:19:58.04940: POST Code: 53
00:00:19:58.05446: POST Code: 54
00:00:19:58.05892: POST Code: 55
00:00:19:58.06340: POST Code: 56
00:00:19:58.06808: POST Code: 57
00:00:19:58.07292: POST Code: 58
00:00:19:58.07740: POST Code: 59
00:00:19:58.08236: POST Code: 5A
00:00:19:58.08686: POST Code: 5B
00:00:19:58.09182: POST Code: 5C
00:00:19:58.09630: POST Code: 5D
00:00:19:59.00076: POST Code: 5E
00:00:19:59.04906: POST Code: 5F
00:00:19:59.05388: POST Code: 60
00:00:19:59.05854: POST Code: 61
00:00:19:59.06412: POST Code: 62
00:00:19:59.06878: POST Code: 63
00:00:19:59.07358: POST Code: 64
00:00:19:59.07814: POST Code: 65
00:00:19:59.08398: POST Code: 66
00:00:19:59.08854: POST Code: 67
00:00:19:59.09294: POST Code: 68
00:00:19:59.09728: POST Code: 69
00:00:19:60.00230: POST Code: 6A
00:00:19:60.00710: POST Code: 6B
00:00:19:60.01178: POST Code: 6C
00:00:19:60.01666: POST Code: 6D
00:00:19:60.02168: POST Code: 6E
00:00:19:60.02604: POST Code: 6F
00:00:19:60.03068: POST Code: 70
00:00:19:60.03508: POST Code: 71
00:00:19:60.04030: POST Code: 72
00:00:19:60.04640: POST Code: 73
00:00:19:60.05110: POST Code: 74
00:00:19:60.05626: POST Code: 75
00:00:19:60.06068: POST Code: 76
00:00:19:60.06504: POST Code: 77
00:00:19:60.07010: POST Code: 78
00:00:19:60.07490: POST Code: 79
00:00:19:60.07948: POST Code: 7A
00:00:19:60.08386: POST Code: 7B
00:00:19:60.09058: POST Code: 7C
00:00:19:60.09500: POST Code: 7D
00:00:19:60.09936: POST Code: 7E
00:00:19:61.00406: POST Code: 7F
00:00:19:61.00934: POST Code: 80
00:00:19:61.01454: POST Code: 81
00:00:19:61.01910: POST Code: 82
00:00:19:61.02402: POST Code: 83
00:00:19:61.02858: POST Code: 84
00:00:19:61.03414: POST Code: 85
00:00:19:61.03916: POST Code: 86
00:00:19:61.04384: POST Code: 87
00:00:19:61.04842: POST Code: 88
00:00:19:61.05292: POST Code: 89
00:00:19:61.05776: POST Code: 8A
00:00:19:61.06236: POST Code: 8B
00:00:19:61.06782: POST Code: 8C
00:00:19:61.07388: POST Code: 8D
00:00:19:61.07868: POST Code: 8E
00:00:19:61.08334: POST Code: 8F
00:00:19:61.08776: POST Code: 90
00:00:19:61.09352: POST Code: 91
00:00:19:61.09810: POST Code: 92
00:00:19:62.00246: POST Code: 93
00:00:19:62.00764: POST Code: 94
00:00:19:62.01200: POST Code: 95
00:00:19:62.01638: POST Code: 96
00:00:19:62.02126: POST Code: 97
00:00:19:62.02566: POST Code: 98
00:00:19:62.03002: POST Code: 99
00:00:19:62.03492: POST Code: 9A
00:00:19:62.03942: POST Code: 9B
00:00:19:62.08686: POST Code: 9C
00:00:19:62.09126: POST Code: 9D
00:00:19:62.09630: POST Code: 9E
00:00:19:63.00096: POST Code: 9F
00:00:19:63.00656: POST Code: A0
00:00:19:63.01094: POST Code: A1
00:00:19:63.01530: POST Code: A2
00:00:19:63.02042: POST Code: A3
00:00:19:63.02478: POST Code: A4
00:00:19:63.02952: POST Code: A5
00:00:19:63.03392: POST Code: A6
00:00:19:63.03872: POST Code: A7
00:00:19:63.04404: POST Code: A8
00:00:19:63.04946: POST Code: A9
00:00:19:63.05384: POST Code: AA
00:00:19:63.05868: POST Code: AB
00:00:19:63.06326: POST Code: AC
00:00:19:63.06812: POST Code: AD
00:00:19:63.07314: POST Code: AE
00:00:19:63.07864: POST Code: AF
00:00:19:63.08464: POST Code: B0
00:00:19:63.08980: POST Code: B1
00:00:19:63.09418: POST Code: B2
00:00:19:63.09908: POST Code: B3
00:00:19:64.00440: POST Code: B4
00:00:19:64.00992: POST Code: B5
00:00:19:64.01508: POST Code: B6
00:00:19:64.01948: POST Code: B7
00:00:19:64.02466: POST Code: B8
00:00:19:64.03052: POST Code: B9
00:00:19:64.03490: POST Code: BA
00:00:19:64.04024: POST Code: BB
00:00:19:64.04558: POST Code: BC
00:00:19:64.05008: POST Code: BD
00:00:19:64.05502: POST Code: BE
00:00:19:64.05950: POST Code: BF
00:00:19:64.06420: POST Code: C0
00:00:19:64.06940: POST Code: C1
00:00:19:64.07458: POST Code: C2
00:00:19:64.08038: POST Code: C3
00:00:19:64.08488: POST Code: C4
00:00:19:64.08990: POST Code: C5
00:00:19:64.09478: POST Code: C6
00:00:19:65.00012: POST Code: C7
00:00:19:65.00566: POST Code: C8
00:00:19:65.01014: POST Code: C9
00:00:19:65.01464: POST Code: CA
00:00:19:65.01958: POST Code: CB
00:00:19:65.02410: POST Code: CC
00:00:19:65.02856: POST Code: CD
00:00:19:65.03326: POST Code: CE
00:00:19:65.03782: POST Code: CF
00:00:19:65.04230: POST Code: D0
00:00:19:65.04676: POST Code: D1
00:00:19:65.05180: POST Code: D2
00:00:19:65.05636: POST Code: D3
00:00:19:65.06086: POST Code: D4
00:00:19:65.06590: POST Code: D5
00:00:19:65.07036: POST Code: D6
00:00:19:65.07496: POST Code: D7
00:00:19:65.07992: POST Code: D8
00:00:19:66.02558: POST Code: D9
00:00:19:66.03006: POST Code: DA
00:00:19:66.03458: POST Code: DB
00:00:19:66.03964: POST Code: DC
00:00:19:66.04422: POST Code: DD
00:00:19:66.04882: POST Code: DE
00:00:19:66.05320: POST Code: DF
00:00:19:66.05756: POST Code: E0
00:00:19:66.06264: POST Code: E1
00:00:19:66.06700: POST Code: E2
00:00:19:66.07202: POST Code: E3
00:00:19:66.07640: POST Code: E4
00:00:19:66.08148: POST Code: E5
00:00:19:66.08586: POST Code: E6
00:00:19:66.09450: POST Code: E7
00:00:19:67.00152: POST Code: E8
00:00:19:67.00684: POST Code: E9
00:00:19:67.01122: POST Code: EA
00:00:19:67.01724: POST Code: EB
00:00:19:67.02162: POST Code: EC
00:00:19:67.02622: POST Code: ED
00:00:19:67.03120: POST Code: EE
00:00:19:67.03560: POST Code: EF
00:00:19:67.04010: POST Code: F0
00:00:19:67.04456: POST Code: F1
00:00:19:67.04944: POST Code: F2
00:00:19:67.05394: POST Code: F3
00:00:19:67.05840: POST Code: F4
00:00:19:67.06304: POST Code: F5
00:00:19:67.06784: POST Code: F6
00:00:19:67.07232: POST Code: F7
00:00:19:67.07680: POST Code: F8
00:00:19:67.08188: POST Code: F9
00:00:19:67.08740: POST Code: FA
00:00:19:67.09186: POST Code: FB
00:00:19:67.09698: POST Code: FC
00:00:19:68.00172: POST Code: FD
00:00:19:68.00708: POST Code: 09
00:00:19:68.05416: POST Code: 0A
00:00:19:68.05446: POST Code: 0B
00:00:24:58.09034: POST Code: 0C
That log was made using the new debugger log setting to log POST codes written to 80h(only when it changes it's value).
The good news is that it DOES end up at the point I want it to be. But it does wrong anyway, for some reason. I'll need to implement a skip value for debugging point 0B at the end here.
Edit: I've implemented a skip value. It gets to point 0C, then it executes a JNZ jump to a HLT instruction, because the 8042 emulation is apparently bad. So the 8042 emulation does have an error?
https://bitbucket.org/superfury/unipcemu/src/ … 042.c?at=master
The IRQ8042 function is called by the PS/2 keyboard and mouse when they have anything for the 8042 to receive, as well as when the 8042 PS/2 port is selected using function A8. This loads any new values into the 8042 chip's output buffer(8042 perspective) and raises any IRQs when enabled.
This is the output I currently get:
00:00:14:02.08082: POST Code: 01
00:00:14:02.08861: POST Code: 02
00:00:14:37.01219: POST Code: 03
00:00:14:37.01495: POST Code: 04
00:00:14:37.01599: POST Code: 05
00:00:14:37.01687: POST Code: 06
00:00:14:37.02898: POST Code: 07
00:00:14:37.04017: POST Code: 08
00:00:14:37.04502: POST Code: 00
00:00:14:37.04965: POST Code: 01
00:00:14:37.05431: POST Code: 02
00:00:14:37.05920: POST Code: 03
00:00:14:37.06423: POST Code: 04
00:00:14:37.06867: POST Code: 05
00:00:14:37.07349: POST Code: 06
00:00:14:37.07796: POST Code: 07
00:00:14:37.08261: POST Code: 08
00:00:14:37.08715: POST Code: 09
00:00:14:37.09224: POST Code: 0A
00:00:14:37.09696: POST Code: 0B
00:00:14:38.00139: POST Code: 0C
00:00:14:38.00611: POST Code: 0D
00:00:14:38.01079: POST Code: 0E
00:00:14:38.01521: POST Code: 0F
00:00:14:38.01984: POST Code: 10
00:00:14:38.02522: POST Code: 11
00:00:14:38.07377: POST Code: 12
00:00:14:38.07824: POST Code: 13
00:00:14:38.08429: POST Code: 14
00:00:14:38.08918: POST Code: 15
00:00:14:38.09365: POST Code: 16
00:00:14:38.09808: POST Code: 17
00:00:14:39.00292: POST Code: 18
00:00:14:39.00734: POST Code: 19
00:00:14:39.01179: POST Code: 1A
00:00:14:39.01669: POST Code: 1B
00:00:14:39.02152: POST Code: 1C
00:00:14:39.02607: POST Code: 1D
00:00:14:39.03070: POST Code: 1E
00:00:14:39.03586: POST Code: 1F
00:00:14:39.04076: POST Code: 20
00:00:14:39.04557: POST Code: 21
00:00:14:39.05124: POST Code: 22
00:00:14:39.05584: POST Code: 23
00:00:14:39.06184: POST Code: 24
00:00:14:39.06627: POST Code: 25
00:00:14:39.07067: POST Code: 26
00:00:14:39.07514: POST Code: 27
00:00:14:39.08007: POST Code: 28
00:00:14:39.08453: POST Code: 29
00:00:14:39.08980: POST Code: 2A
00:00:14:39.09471: POST Code: 2B
00:00:14:39.09914: POST Code: 2C
00:00:14:40.00384: POST Code: 2D
00:00:14:40.00876: POST Code: 2E
00:00:14:40.01331: POST Code: 2F
00:00:14:40.01776: POST Code: 30
00:00:14:40.02611: POST Code: 31
00:00:14:40.03054: POST Code: 32
00:00:14:40.03498: POST Code: 33
…Show last 211 lines
00:00:14:40.04001: POST Code: 34
00:00:14:40.04471: POST Code: 35
00:00:14:40.04915: POST Code: 36
00:00:14:40.05428: POST Code: 37
00:00:14:40.05872: POST Code: 38
00:00:14:40.06341: POST Code: 39
00:00:14:40.06834: POST Code: 3A
00:00:14:40.07276: POST Code: 3B
00:00:14:40.07721: POST Code: 3C
00:00:14:40.08212: POST Code: 3D
00:00:14:40.08657: POST Code: 3E
00:00:14:40.09097: POST Code: 3F
00:00:14:40.09540: POST Code: 40
00:00:14:41.00042: POST Code: 41
00:00:14:41.00485: POST Code: 42
00:00:14:41.00930: POST Code: 43
00:00:14:41.01371: POST Code: 44
00:00:14:41.01877: POST Code: 45
00:00:14:41.02319: POST Code: 46
00:00:14:41.02763: POST Code: 47
00:00:14:41.03292: POST Code: 48
00:00:14:41.03768: POST Code: 49
00:00:14:41.04210: POST Code: 4A
00:00:14:41.04707: POST Code: 4B
00:00:14:41.05149: POST Code: 4C
00:00:14:42.00028: POST Code: 4D
00:00:14:42.00482: POST Code: 4E
00:00:14:42.00936: POST Code: 4F
00:00:14:42.01455: POST Code: 50
00:00:14:42.01949: POST Code: 51
00:00:14:42.02423: POST Code: 52
00:00:14:42.02856: POST Code: 53
00:00:14:42.03413: POST Code: 54
00:00:14:42.03861: POST Code: 55
00:00:14:42.04295: POST Code: 56
00:00:14:42.04843: POST Code: 57
00:00:14:42.05340: POST Code: 58
00:00:14:42.05785: POST Code: 59
00:00:14:42.06292: POST Code: 5A
00:00:14:42.06750: POST Code: 5B
00:00:14:42.07185: POST Code: 5C
00:00:14:42.07685: POST Code: 5D
00:00:14:42.08119: POST Code: 5E
00:00:14:42.08576: POST Code: 5F
00:00:14:42.09020: POST Code: 60
00:00:14:42.09464: POST Code: 61
00:00:14:42.09943: POST Code: 62
00:00:14:43.00387: POST Code: 63
00:00:14:43.00833: POST Code: 64
00:00:14:43.01341: POST Code: 65
00:00:14:43.01783: POST Code: 66
00:00:14:43.02227: POST Code: 67
00:00:14:43.02731: POST Code: 68
00:00:14:43.03175: POST Code: 69
00:00:14:43.03618: POST Code: 6A
00:00:14:43.04060: POST Code: 6B
00:00:14:43.04559: POST Code: 6C
00:00:14:43.05030: POST Code: 6D
00:00:14:43.05509: POST Code: 6E
00:00:14:43.06046: POST Code: 6F
00:00:14:43.06553: POST Code: 70
00:00:14:43.07017: POST Code: 71
00:00:14:43.07585: POST Code: 72
00:00:14:43.08096: POST Code: 73
00:00:14:43.08546: POST Code: 74
00:00:14:43.08979: POST Code: 75
00:00:14:43.09564: POST Code: 76
00:00:14:44.00007: POST Code: 77
00:00:14:44.00479: POST Code: 78
00:00:14:44.01014: POST Code: 79
00:00:14:44.01509: POST Code: 7A
00:00:14:44.02106: POST Code: 7B
00:00:14:44.02604: POST Code: 7C
00:00:14:44.03035: POST Code: 7D
00:00:14:44.03736: POST Code: 7E
00:00:14:44.04167: POST Code: 7F
00:00:14:44.04624: POST Code: 80
00:00:14:44.05068: POST Code: 81
00:00:14:44.05501: POST Code: 82
00:00:14:44.06004: POST Code: 83
00:00:14:44.06482: POST Code: 84
00:00:14:44.06926: POST Code: 85
00:00:14:44.07423: POST Code: 86
00:00:14:44.07879: POST Code: 87
00:00:14:44.08312: POST Code: 88
00:00:14:44.08794: POST Code: 89
00:00:14:44.09236: POST Code: 8A
00:00:14:45.04209: POST Code: 8B
00:00:14:45.04653: POST Code: 8C
00:00:14:45.05102: POST Code: 8D
00:00:14:45.05545: POST Code: 8E
00:00:14:45.06034: POST Code: 8F
00:00:14:45.06540: POST Code: 90
00:00:14:45.06984: POST Code: 91
00:00:14:45.07479: POST Code: 92
00:00:14:45.08015: POST Code: 93
00:00:14:45.08480: POST Code: 94
00:00:14:45.09009: POST Code: 95
00:00:14:45.09575: POST Code: 96
00:00:14:46.00023: POST Code: 97
00:00:14:46.00465: POST Code: 98
00:00:14:46.00944: POST Code: 99
00:00:14:46.01386: POST Code: 9A
00:00:14:46.01850: POST Code: 9B
00:00:14:46.02331: POST Code: 9C
00:00:14:46.02775: POST Code: 9D
00:00:14:46.03220: POST Code: 9E
00:00:14:46.03714: POST Code: 9F
00:00:14:46.04160: POST Code: A0
00:00:14:46.04629: POST Code: A1
00:00:14:46.05073: POST Code: A2
00:00:14:46.05514: POST Code: A3
00:00:14:46.05987: POST Code: A4
00:00:14:46.06429: POST Code: A5
00:00:14:46.06903: POST Code: A6
00:00:14:46.07348: POST Code: A7
00:00:14:46.07844: POST Code: A8
00:00:14:46.08344: POST Code: A9
00:00:14:46.08840: POST Code: AA
00:00:14:46.09343: POST Code: AB
00:00:14:46.09775: POST Code: AC
00:00:14:47.00228: POST Code: AD
00:00:14:47.00661: POST Code: AE
00:00:14:47.01128: POST Code: AF
00:00:14:47.01723: POST Code: B0
00:00:14:47.02179: POST Code: B1
00:00:14:47.02659: POST Code: B2
00:00:14:47.03114: POST Code: B3
00:00:14:47.03612: POST Code: B4
00:00:14:47.04042: POST Code: B5
00:00:14:47.04478: POST Code: B6
00:00:14:47.04984: POST Code: B7
00:00:14:47.05516: POST Code: B8
00:00:14:47.05949: POST Code: B9
00:00:14:47.06448: POST Code: BA
00:00:14:47.06881: POST Code: BB
00:00:14:47.07339: POST Code: BC
00:00:14:47.07783: POST Code: BD
00:00:14:47.08371: POST Code: BE
00:00:14:47.08859: POST Code: BF
00:00:14:47.09317: POST Code: C0
00:00:14:47.09792: POST Code: C1
00:00:14:48.00226: POST Code: C2
00:00:14:48.00689: POST Code: C3
00:00:14:48.01183: POST Code: C4
00:00:14:48.01627: POST Code: C5
00:00:14:48.02190: POST Code: C6
00:00:14:48.07122: POST Code: C7
00:00:14:48.07590: POST Code: C8
00:00:14:48.08029: POST Code: C9
00:00:14:48.08581: POST Code: CA
00:00:14:48.09065: POST Code: CB
00:00:14:48.09505: POST Code: CC
00:00:14:48.09982: POST Code: CD
00:00:14:49.00475: POST Code: CE
00:00:14:49.00919: POST Code: CF
00:00:14:49.01483: POST Code: D0
00:00:14:49.02105: POST Code: D1
00:00:14:49.02546: POST Code: D2
00:00:14:49.02991: POST Code: D3
00:00:14:49.03441: POST Code: D4
00:00:14:49.03905: POST Code: D5
00:00:14:49.04347: POST Code: D6
00:00:14:49.04788: POST Code: D7
00:00:14:49.05254: POST Code: D8
00:00:14:49.05696: POST Code: D9
00:00:14:49.06139: POST Code: DA
00:00:14:49.06584: POST Code: DB
00:00:14:49.07039: POST Code: DC
00:00:14:49.07529: POST Code: DD
00:00:14:49.07973: POST Code: DE
00:00:14:49.08423: POST Code: DF
00:00:14:49.08856: POST Code: E0
00:00:14:49.09381: POST Code: E1
00:00:14:49.09836: POST Code: E2
00:00:14:50.00268: POST Code: E3
00:00:14:50.00772: POST Code: E4
00:00:14:50.01216: POST Code: E5
00:00:14:50.01670: POST Code: E6
00:00:14:50.02183: POST Code: E7
00:00:14:50.02615: POST Code: E8
00:00:14:50.03053: POST Code: E9
00:00:14:50.03530: POST Code: EA
00:00:14:50.04047: POST Code: EB
00:00:14:50.04479: POST Code: EC
00:00:14:50.04934: POST Code: ED
00:00:14:50.05441: POST Code: EE
00:00:14:50.05895: POST Code: EF
00:00:14:50.06472: POST Code: F0
00:00:14:50.07065: POST Code: F1
00:00:14:50.07507: POST Code: F2
00:00:14:50.07961: POST Code: F3
00:00:14:50.08487: POST Code: F4
00:00:14:50.08995: POST Code: F5
00:00:14:50.09429: POST Code: F6
00:00:14:50.09936: POST Code: F7
00:00:14:51.00414: POST Code: F8
00:00:14:51.00899: POST Code: F9
00:00:14:51.01399: POST Code: FA
00:00:14:51.01915: POST Code: FB
00:00:14:51.02408: POST Code: FC
00:00:14:51.02999: POST Code: FD
00:00:14:51.03625: POST Code: 09
00:00:14:52.02716: POST Code: 0A
00:00:14:52.02747: POST Code: 0B
00:00:14:52.02810: POST Code: 0C
00:00:14:52.02902: POST Code: 0E
00:00:14:52.02937: POST Code: 0F
00:00:16:19.01612: POST Code: 32
00:00:16:57.06425: POST Code: 11
So I can conclude it errors our somewhere in the STGTST_CNT function? I've tested it until the first LODSW loop, which reads 0xAA55 values from memory.
Reply 5 of 151, by superfury
I just though about something: The 80286 and 80386 raise their high (above 1MB) address lines on reset for code segment accesses, until CS is loaded through a intersegment CALL or JMP instruction. So when it resets it reads the BIOS code from selector OR 0xF00000(OR 0xFFF00000 on a 80386 CPU). Then when the CS register is loaded, the bios clears those automatic assertions, instead using the lower 1MB area to address the ROM(as long as it's using segment 0xF000) instead.
So before resetting those lines (at CPU reset), the BIOS must be at physical address 0xFF0000(segment F000)-0xFFFFFF for a 64k BIOS ROM. But after CS is loaded, it's supposed to be at 0xF0000-0xFFFFF.
Does the ROM decode both the high addresses and the low addresses at the same time? So it responds to both ranges(since it doesn't know anything about the CS being loaded after reset or not)?
Edit: After implementing proper segment and address lines, it ends up with POST Diagnostic code 11h, which, according to http://www.postcodemaster.com/IBMAT.shtml is:
11 - Verify 286 LGDT/SGDT and LIDT/SIDT Instructions
So there's an error with my 80286+ L/S GDT/IDT instructions?
Edit: This doesn't seem to be the case. At 11h it's actually verifying the DRAM Refresh rate to be within expected limits:
	MOV 	AL,11H	;	  <><><><><><><><><><><><>
OUT MFG_PORT,AL ; <><> CHECKPOINT 11 <><>
;----- VERIFY SPEED/REFRESH CLOCK RATES ( ERROR = 1 LONG AND 1 SHORT BEEP )
XOR BL,BL ; CLEAR REFRESH CYCLE REPEAT COUNT
XOR CX,CX ; INITIALIZE SPEED RATE REGISTER
EVEN ; PLACE ON EVEN WORD BOUNDARY
C34:
IN AL,PORT_B ; READ REFRESH BIT REGISTER
TEST AL,REFRFSH_BIT ; MASK FOR BIT
LOOPZ C34 ; DECREMENT LOOP COUNTER TILL ON
C35: ; superfury: address 05AE
TEST AL,REFRFESH_BIT ; MASK FOR BIT
LOOPNZ C35 ; DECREMENT LOOP COUNTER TILL OFF
; superfury: addr 5B4
DEC BL ; DECREMENT REFRESH CYCLE REPEAT COUNT
JNZ C34 ; REPEAT TILL CYCLE COUNT DONE
; addr 5B8; CX=6761
CMP CX,RATE_UPPER ; CHECK FOR RATE BELOW UPPER LIMIT
JAE C36 ; SKIP ERROR BEEP IF BELOW MAXIMUM
C36E:
MOV DX,0101H ; GET BEEP COUNTS FOR REFRESH ERROR
CALL ERR_BEEP ; CALL TO POST ERROR BEEP ROUTINES
HLT ; HALT SYSTEM - BAD REFRESH RATE
C36I
CMP CX,RATE_LOWER ; CHECK FOR RATE ABOVE LOWER LIMIT
JA C36E ; GO TO ERROR BEEP IF BELOW MINIMUM
;----- GET THE INPUT BUFFER (SWITCH SETTINGS)
IN AL,DMA_PAGE+1 ; GET THE SWITCH SETTINGS
AND AL,KEY_BD_INHIB+DSP_JMP+MFG_LOOP+BASE_MEM+BASE_MEM8 ; STRIP BITS
MOV @MFG_TST,AL ; SAVE SETTINDS
SUB AL,AL ; RESET DMA_PAGE
OUT DMA_PAGE+1,AL
My emulation gets 0x6761 in CX when it reaches the rate check compares. It needs to be within 0xF8A7-0xF9F0 range for the BIOS to verify correct speed. So my emulator's DMA refresh speed is either too slow, or the bit isn't toggling fast enough?
Edit: I've modified the DMA transfers to take 10 14MHz cycles instead of 9 and moved the toggling of the DRAM Refresh bit to the DRAM DREQ check of the DMA controller channel 0 handler. Now the entire check passes.
It now crashes on the SIDT/LIDT/SGDT/LGDT instruction check.
Edit: Managed to fix the instructions. It now gets to the point it loads 1 into AX and executes a LMSW AX instruction to switch to protected mode. Yay! 😀
Then it executes a long intersegment jump to flush it's descriptor cache, at which point it triple faults(I see this because I end up at F000:FFFF again, after which all CPU checks start again). So there's a problem with loading that CS segment descriptor now, it seems.
Looking at the access rights in the CS descriptor, it's byte contains 0x93. which means writable data segment, not accessed, not Expanding down?
Reply 6 of 151, by superfury
Looking at the BIOS again, it's trying to jump to 0040:1D73 for some reason? That cannot be correct? Segment descriptor 40h points to the start of the BIOS ROM?
Edit: It was reading the descriptor wrong. It saw a TSS descriptor instead of a Code/Data segment(S bit needs to be cleared for it to be a TSS). It now correctly goes and load the Code Segment(CS). After that, it tries to execute a RET, which results in a triple fault, resetting the CPU.
Edit: Managed by fixing the Descriptor Privilege Check done on the SS (and other) descriptor's DPL comparing to CPL and RPL(instead of comparing to CPL and segment index). Now that part of the BIOS works without much problems.
Now I'm getting Diagnostic code 23, which, according to http://postcodemaster.com/IBMAT.shtml is:
23 - Advanced Video Card Initialization Failure or Invalid Switch Setting
The current diagnostic log:
00:00:03:19.00991: POST Code: 01
00:00:03:19.01499: POST Code: 02
00:00:03:44.06131: POST Code: 03
00:00:03:44.06352: POST Code: 04
00:00:03:44.06434: POST Code: 05
00:00:03:44.06495: POST Code: 06
00:00:03:44.07352: POST Code: 07
00:00:03:44.08183: POST Code: 08
00:00:03:44.08671: POST Code: 00
00:00:03:44.08961: POST Code: 01
00:00:03:44.09273: POST Code: 02
00:00:03:44.09562: POST Code: 03
00:00:03:44.09930: POST Code: 04
00:00:03:45.00219: POST Code: 05
00:00:03:45.00540: POST Code: 06
00:00:03:45.00828: POST Code: 07
00:00:03:45.01119: POST Code: 08
00:00:03:45.01480: POST Code: 09
00:00:03:45.01767: POST Code: 0A
00:00:03:45.02057: POST Code: 0B
00:00:03:45.02344: POST Code: 0C
00:00:03:45.02632: POST Code: 0D
00:00:03:45.03019: POST Code: 0E
00:00:03:45.03310: POST Code: 0F
00:00:03:45.03598: POST Code: 10
00:00:03:45.03885: POST Code: 11
00:00:03:45.04174: POST Code: 12
00:00:03:45.04539: POST Code: 13
00:00:03:45.04848: POST Code: 14
00:00:03:45.05137: POST Code: 15
00:00:03:45.05445: POST Code: 16
00:00:03:45.05735: POST Code: 17
00:00:03:45.06021: POST Code: 18
00:00:03:45.06487: POST Code: 19
00:00:03:45.06864: POST Code: 1A
00:00:03:45.07194: POST Code: 1B
00:00:03:45.07483: POST Code: 1C
00:00:03:45.07770: POST Code: 1D
00:00:03:45.08101: POST Code: 1E
00:00:03:45.08464: POST Code: 1F
00:00:03:45.08752: POST Code: 20
00:00:03:45.09040: POST Code: 21
00:00:03:45.09338: POST Code: 22
00:00:03:45.09627: POST Code: 23
00:00:03:45.09996: POST Code: 24
00:00:03:46.00286: POST Code: 25
00:00:03:46.00574: POST Code: 26
00:00:03:46.00861: POST Code: 27
00:00:03:46.01153: POST Code: 28
00:00:03:46.01534: POST Code: 29
00:00:03:46.01823: POST Code: 2A
00:00:03:46.02110: POST Code: 2B
00:00:03:46.02400: POST Code: 2C
00:00:03:46.02689: POST Code: 2D
00:00:03:46.03037: POST Code: 2E
00:00:03:46.03327: POST Code: 2F
00:00:03:46.03613: POST Code: 30
00:00:03:46.03923: POST Code: 31
00:00:03:46.04244: POST Code: 32
00:00:03:46.04562: POST Code: 33
…Show last 227 lines
00:00:03:46.04935: POST Code: 34
00:00:03:46.05266: POST Code: 35
00:00:03:46.05553: POST Code: 36
00:00:03:46.05862: POST Code: 37
00:00:03:46.06149: POST Code: 38
00:00:03:46.06502: POST Code: 39
00:00:03:46.06819: POST Code: 3A
00:00:03:46.07150: POST Code: 3B
00:00:03:46.07460: POST Code: 3C
00:00:03:46.07768: POST Code: 3D
00:00:03:46.08118: POST Code: 3E
00:00:03:46.08509: POST Code: 3F
00:00:03:46.08852: POST Code: 40
00:00:03:46.09161: POST Code: 41
00:00:03:46.09621: POST Code: 42
00:00:03:47.00011: POST Code: 43
00:00:03:47.06066: POST Code: 44
00:00:03:47.06371: POST Code: 45
00:00:03:47.06668: POST Code: 46
00:00:03:47.06971: POST Code: 47
00:00:03:47.07353: POST Code: 48
00:00:03:47.07679: POST Code: 49
00:00:03:47.07979: POST Code: 4A
00:00:03:47.08274: POST Code: 4B
00:00:03:47.08582: POST Code: 4C
00:00:03:47.08926: POST Code: 4D
00:00:03:47.09223: POST Code: 4E
00:00:03:47.09518: POST Code: 4F
00:00:03:47.09812: POST Code: 50
00:00:03:48.00108: POST Code: 51
00:00:03:48.00430: POST Code: 52
00:00:03:48.00726: POST Code: 53
00:00:03:48.01024: POST Code: 54
00:00:03:48.01337: POST Code: 55
00:00:03:48.01632: POST Code: 56
00:00:03:48.01973: POST Code: 57
00:00:03:48.02270: POST Code: 58
00:00:03:48.02564: POST Code: 59
00:00:03:48.02868: POST Code: 5A
00:00:03:48.03166: POST Code: 5B
00:00:03:48.03508: POST Code: 5C
00:00:03:48.03804: POST Code: 5D
00:00:03:48.04100: POST Code: 5E
00:00:03:48.04395: POST Code: 5F
00:00:03:48.04690: POST Code: 60
00:00:03:48.04983: POST Code: 61
00:00:03:48.05326: POST Code: 62
00:00:03:48.05619: POST Code: 63
00:00:03:48.05914: POST Code: 64
00:00:03:48.06211: POST Code: 65
00:00:03:48.06528: POST Code: 66
00:00:03:48.06878: POST Code: 67
00:00:03:48.07173: POST Code: 68
00:00:03:48.07468: POST Code: 69
00:00:03:48.07763: POST Code: 6A
00:00:03:48.08058: POST Code: 6B
00:00:03:48.08353: POST Code: 6C
00:00:03:48.08646: POST Code: 6D
00:00:03:48.08991: POST Code: 6E
00:00:03:48.09301: POST Code: 6F
00:00:03:48.09618: POST Code: 70
00:00:03:48.09991: POST Code: 71
00:00:03:49.00287: POST Code: 72
00:00:03:49.00602: POST Code: 73
00:00:03:49.00943: POST Code: 74
00:00:03:49.01242: POST Code: 75
00:00:03:49.01536: POST Code: 76
00:00:03:49.01857: POST Code: 77
00:00:03:49.02153: POST Code: 78
00:00:03:49.02510: POST Code: 79
00:00:03:49.02798: POST Code: 7A
00:00:03:49.03098: POST Code: 7B
00:00:03:49.03407: POST Code: 7C
00:00:03:49.03786: POST Code: 7D
00:00:03:49.04093: POST Code: 7E
00:00:03:49.04382: POST Code: 7F
00:00:03:49.04669: POST Code: 80
00:00:03:49.04980: POST Code: 81
00:00:03:49.05344: POST Code: 82
00:00:03:49.05650: POST Code: 83
00:00:03:49.05938: POST Code: 84
00:00:03:49.06251: POST Code: 85
00:00:03:49.06538: POST Code: 86
00:00:03:49.06827: POST Code: 87
00:00:03:49.07134: POST Code: 88
00:00:03:49.07467: POST Code: 89
00:00:03:49.07753: POST Code: 8A
00:00:03:49.08084: POST Code: 8B
00:00:03:49.08419: POST Code: 8C
00:00:03:49.08721: POST Code: 8D
00:00:03:49.09079: POST Code: 8E
00:00:03:49.09367: POST Code: 8F
00:00:03:49.09654: POST Code: 90
00:00:03:49.09989: POST Code: 91
00:00:03:50.00340: POST Code: 92
00:00:03:50.00640: POST Code: 93
00:00:03:50.00928: POST Code: 94
00:00:03:50.01241: POST Code: 95
00:00:03:50.01551: POST Code: 96
00:00:03:50.01921: POST Code: 97
00:00:03:50.02211: POST Code: 98
00:00:03:50.02497: POST Code: 99
00:00:03:50.02808: POST Code: 9A
00:00:03:50.03094: POST Code: 9B
00:00:03:50.08345: POST Code: 9C
00:00:03:50.08637: POST Code: 9D
00:00:03:50.09082: POST Code: 9E
00:00:03:50.09457: POST Code: 9F
00:00:03:50.09766: POST Code: A0
00:00:03:51.00137: POST Code: A1
00:00:03:51.00426: POST Code: A2
00:00:03:51.00736: POST Code: A3
00:00:03:51.01084: POST Code: A4
00:00:03:51.01396: POST Code: A5
00:00:03:51.01684: POST Code: A6
00:00:03:51.01994: POST Code: A7
00:00:03:51.02283: POST Code: A8
00:00:03:51.02572: POST Code: A9
00:00:03:51.02940: POST Code: AA
00:00:03:51.03231: POST Code: AB
00:00:03:51.03518: POST Code: AC
00:00:03:51.03807: POST Code: AD
00:00:03:51.04095: POST Code: AE
00:00:03:51.04468: POST Code: AF
00:00:03:51.04756: POST Code: B0
00:00:03:51.05041: POST Code: B1
00:00:03:51.05353: POST Code: B2
00:00:03:51.05640: POST Code: B3
00:00:03:51.06029: POST Code: B4
00:00:03:51.06387: POST Code: B5
00:00:03:51.06761: POST Code: B6
00:00:03:51.07079: POST Code: B7
00:00:03:51.07538: POST Code: B8
00:00:03:51.07940: POST Code: B9
00:00:03:51.08254: POST Code: BA
00:00:03:51.08589: POST Code: BB
00:00:03:51.08954: POST Code: BC
00:00:03:51.09370: POST Code: BD
00:00:03:51.09762: POST Code: BE
00:00:03:52.00050: POST Code: BF
00:00:03:52.00362: POST Code: C0
00:00:03:52.00688: POST Code: C1
00:00:03:52.01059: POST Code: C2
00:00:03:52.01391: POST Code: C3
00:00:03:52.01744: POST Code: C4
00:00:03:52.02068: POST Code: C5
00:00:03:52.02513: POST Code: C6
00:00:03:52.02821: POST Code: C7
00:00:03:52.03116: POST Code: C8
00:00:03:52.03414: POST Code: C9
00:00:03:52.03719: POST Code: CA
00:00:03:52.04044: POST Code: CB
00:00:03:52.04339: POST Code: CC
00:00:03:52.04634: POST Code: CD
00:00:03:52.04927: POST Code: CE
00:00:03:52.05245: POST Code: CF
00:00:03:52.05653: POST Code: D0
00:00:03:52.05948: POST Code: D1
00:00:03:52.06242: POST Code: D2
00:00:03:52.06538: POST Code: D3
00:00:03:52.06897: POST Code: D4
00:00:03:52.07193: POST Code: D5
00:00:03:52.07489: POST Code: D6
00:00:03:52.07785: POST Code: D7
00:00:03:52.08078: POST Code: D8
00:00:03:52.08375: POST Code: D9
00:00:03:52.08683: POST Code: DA
00:00:03:52.09037: POST Code: DB
00:00:03:52.09333: POST Code: DC
00:00:03:52.09628: POST Code: DD
00:00:03:52.09935: POST Code: DE
00:00:03:53.00246: POST Code: DF
00:00:03:53.00589: POST Code: E0
00:00:03:53.00885: POST Code: E1
00:00:03:53.01177: POST Code: E2
00:00:03:53.01474: POST Code: E3
00:00:03:53.01794: POST Code: E4
00:00:03:53.02089: POST Code: E5
00:00:03:53.02393: POST Code: E6
00:00:03:53.02682: POST Code: E7
00:00:03:53.02991: POST Code: E8
00:00:03:53.03344: POST Code: E9
00:00:03:53.03634: POST Code: EA
00:00:03:53.03929: POST Code: EB
00:00:03:53.04248: POST Code: EC
00:00:03:53.04539: POST Code: ED
00:00:03:53.04826: POST Code: EE
00:00:03:53.05114: POST Code: EF
00:00:03:53.05475: POST Code: F0
00:00:03:53.05764: POST Code: F1
00:00:03:53.06052: POST Code: F2
00:00:03:53.06339: POST Code: F3
00:00:03:54.01784: POST Code: F4
00:00:03:54.02074: POST Code: F5
00:00:03:54.02414: POST Code: F6
00:00:03:54.02752: POST Code: F7
00:00:03:54.03040: POST Code: F8
00:00:03:54.03329: POST Code: F9
00:00:03:54.03618: POST Code: FA
00:00:03:54.03970: POST Code: FB
00:00:03:54.04257: POST Code: FC
00:00:03:54.04545: POST Code: FD
00:00:03:54.04925: POST Code: 09
00:00:03:54.07494: POST Code: 0A
00:00:03:54.07529: POST Code: 0B
00:00:03:54.07585: POST Code: 0C
00:00:03:54.07663: POST Code: 0E
00:00:03:54.07718: POST Code: 0F
00:00:05:09.05722: POST Code: 32
00:00:05:49.03596: POST Code: 11
00:00:18:09.00070: POST Code: 12
00:00:18:09.00402: POST Code: 13
00:00:18:09.00448: POST Code: 14
00:00:18:09.01508: POST Code: 15
00:00:18:09.01654: POST Code: 16
00:00:18:09.01726: POST Code: 17
00:00:18:09.01874: POST Code: 18
00:00:18:09.01898: POST Code: 19
00:00:18:09.01962: POST Code: 81
00:00:18:09.06834: POST Code: 85
00:00:18:09.06856: POST Code: 1A
00:00:18:09.06916: POST Code: 1B
00:00:18:41.06910: POST Code: 1C
00:00:18:41.07046: POST Code: 1D
00:00:18:56.01146: POST Code: 21
00:00:18:79.04666: POST Code: 23
So protected mode works:) Now only need to fix the issues left.
Reply 7 of 151, by superfury
I've managed to get it as far as to start testing the 1MB+ extended memory. But immediately when the first block of extended memory is checked using REP STOSW:
HOW_BIG_2A:
SUB AX,AX ; WRITE ZEROS
MOV CX,2000H*4 ; SET COUNT FOR 32K WORDS
REP STOSW ; FILL 32K WORDS
Now the ES descriptor loaded earlier is cleared in the GDT(the GDT entry is cleared by the operation)?
Edit: Examining the memory dump from the start of the test (when the procedure is called) reveals that the IDT entry is already cleared beforehand. Thus the descriptor is read correctly. So that means that the previous BIOS check does overwrite the GDT, but doesn't restore it(fully)?
Edit: Looking at the disassembly just before the function, at the first REP STOSW, I see that the processor is supposed to address 1M+, but the A20 line is still disabled? So the address wraps back to 0, thus clearing the first 64K of RAM, which also contains the GDT. Then, it starts to reload the DS entry, based on a PUSH ES; PUSH ES; POP DS instruction, where pushing ES to the stack, then POPping DS back from the stack reloads the DS descriptor from the GDT, which is erased by the REP STOSW, because it wraps around 1M until 2M. So (with the current 6MB RAM) it will clear the main GDT every 2MB, so at 1M-1M+64K, 3M-3M+64k and 5M-5M+64k. Although the first loading of the GDT results in a #GP fault, leading to a triple fault, because the GDT is erased from existance.
Edit: The BIOS doesn't do anything to the 8042 chip after reading the first reset POST initialization 0xAA byte?
Reply 9 of 151, by Jepael
superfury wrote:
I just found out the BIOS doesn't enable A20 before checking extended memory. Is A20 enabled or disabled by default?
It does boot ROM at physical address 0xFFFFF0h.
If A20 was disabled, it can't do that because it would force the bus address to be 0xFEFFF0, right?
Reply 10 of 151, by superfury
Ok. So A20 is enabled when the PC AT is turned on. But which one? From what I can find IBM used the 8042 for that. But what about the fast A20(Since the PS/2)? Is fast A20 disabled by default? Or are they both enabled&disabled? They're OR'ed together, or not?
Reply 11 of 151, by Jepael
Good question. They are ORed together on PS2, but I don't know the initial FAST A20 state. Since it boots, it's still enabled.
Reply 12 of 151, by superfury
Is the PS/2 AT-compatible? If it is, both should be disabled on boot. Then, If it can also run 8086 wraparround hacks using the AT BIOS(both are disabled, but only the 8042 is used by the AT BIOS), that would mean it's turned off(0 in fast A20) on powerup. Anyone has an accurate emulator of an I PS/2 to run with a IBM AT BIOS?
Reply 13 of 151, by superfury
Looking at https://github.com/OBattler/PCem-X/blob/master/PCem/mem.c shows that the keyboard is enabled by default(2) on MMU(CPU) reset and the fast version is either reset(0) every CPU reset or only during powerup(variable initialization)?
Reply 14 of 151, by superfury
Well, the protected mode seems to work now. It gets to point 27h, after which it enters an incredibly slow DMA Refresh toggle loop(because of the JZ loop inside of a LOOP block. Currently about 0x30 per two seconds(with ~ 0x6000 left to go). So either 8086 timings(@4.77MHz) isn't enough for the BIOS, or my emulator is too slow(on my 4.0Ghz Intel i7)?
Would I need to make the 8086 timings compatible by changing the 80286 CPU timings to be accurate to actual 80286 real mode timings and clocked to a 80286 clock instead of 8086 timings@4.77MHz?
Reply 15 of 151, by superfury
I'm just wondering: when does bit 4 of port 0x61 toggle? Every time a DMA byte is transferred on DMA0? Or every time PIT timer 1 (Port 0x41) times out? Is it the realtime status of the PIT1 1.19MHz signal?
Edit: Looking it up again reveals port 0x61 reports the status of the PIT0&2 signals on bits 5&4. Implementing this now succeeds the timing detection. The only strange thing left is that it says it's only a 100ms delay, while the actual delay takes much longer(due to the short time the bit is actually cleared). But although the delay takes a long time, it succeeds now(within a little bit of time) 😀
It now gets to checkpoint 2B.
Edit: Managed to fix IRQ bugs. It now fully supports edge-triggered (low-to-high) IRQs. The PIT0 signal is now directly passed to raise/lower irq(IR0 input) calls(which handle raising and lowering of it's signals).
Inhabiting the IRQ0 raised value of the Interrupt Request now disables the IRR value accordingly, with no more IRQs being generated until another rising IR0(IR0 isn't changed by port 0x61 anymore, only by the PIT's Timer 0 output).
It now also displays the first part (64k) of the memory test it's supposed to be doing in protected mode:)
The display now reads:
00064 KB OK
010000 0000 201-Memory Error
The POST log reads:
00:00:03:25.03514: POST Code: 01
00:00:03:25.04207: POST Code: 02
00:00:03:49.06489: POST Code: 03
00:00:03:49.06665: POST Code: 04
00:00:03:49.06719: POST Code: 05
00:00:03:49.06790: POST Code: 06
00:00:03:49.07514: POST Code: 07
00:00:03:49.08402: POST Code: 08
00:00:03:49.08677: POST Code: 00
00:00:03:49.08983: POST Code: 01
00:00:03:49.09252: POST Code: 02
00:00:03:49.09528: POST Code: 03
00:00:03:49.09799: POST Code: 04
00:00:03:50.00104: POST Code: 05
00:00:03:50.00374: POST Code: 06
00:00:03:50.00648: POST Code: 07
00:00:03:50.00947: POST Code: 08
00:00:03:50.01248: POST Code: 09
00:00:03:50.01528: POST Code: 0A
00:00:03:50.01800: POST Code: 0B
00:00:03:50.02075: POST Code: 0C
00:00:03:50.02343: POST Code: 0D
00:00:03:50.02648: POST Code: 0E
00:00:03:50.02967: POST Code: 0F
00:00:03:50.03260: POST Code: 10
00:00:03:50.03535: POST Code: 11
00:00:03:50.03837: POST Code: 12
00:00:03:50.04140: POST Code: 13
00:00:03:50.04419: POST Code: 14
00:00:03:50.04692: POST Code: 15
00:00:03:50.04966: POST Code: 16
00:00:03:50.05287: POST Code: 17
00:00:03:50.05589: POST Code: 18
00:00:03:50.05888: POST Code: 19
00:00:03:50.06160: POST Code: 1A
00:00:03:50.06433: POST Code: 1B
00:00:03:50.06704: POST Code: 1C
00:00:03:50.07023: POST Code: 1D
00:00:03:50.07293: POST Code: 1E
00:00:03:50.07649: POST Code: 1F
00:00:03:50.07947: POST Code: 20
00:00:03:50.08337: POST Code: 21
00:00:03:50.08622: POST Code: 22
00:00:03:50.08932: POST Code: 23
00:00:03:50.09202: POST Code: 24
00:00:03:50.09475: POST Code: 25
00:00:03:50.09747: POST Code: 26
00:00:03:51.00022: POST Code: 27
00:00:03:51.00347: POST Code: 28
00:00:03:51.00645: POST Code: 29
00:00:03:51.05371: POST Code: 2A
00:00:03:51.05689: POST Code: 2B
00:00:03:51.05956: POST Code: 2C
00:00:03:51.06248: POST Code: 2D
00:00:03:51.06515: POST Code: 2E
00:00:03:51.06780: POST Code: 2F
00:00:03:51.07088: POST Code: 30
00:00:03:51.07355: POST Code: 31
00:00:03:51.07622: POST Code: 32
00:00:03:51.07887: POST Code: 33
…Show last 300 lines
00:00:03:51.08159: POST Code: 34
00:00:03:51.08457: POST Code: 35
00:00:03:51.08782: POST Code: 36
00:00:03:51.09049: POST Code: 37
00:00:03:51.09315: POST Code: 38
00:00:03:51.09582: POST Code: 39
00:00:03:51.09846: POST Code: 3A
00:00:03:52.00158: POST Code: 3B
00:00:03:52.00485: POST Code: 3C
00:00:03:52.00800: POST Code: 3D
00:00:03:52.01108: POST Code: 3E
00:00:03:52.01374: POST Code: 3F
00:00:03:52.01680: POST Code: 40
00:00:03:52.01957: POST Code: 41
00:00:03:52.02225: POST Code: 42
00:00:03:52.02491: POST Code: 43
00:00:03:52.02795: POST Code: 44
00:00:03:52.03124: POST Code: 45
00:00:03:52.03548: POST Code: 46
00:00:03:52.03838: POST Code: 47
00:00:03:52.04104: POST Code: 48
00:00:03:52.04370: POST Code: 49
00:00:03:52.04676: POST Code: 4A
00:00:03:52.04941: POST Code: 4B
00:00:03:52.05206: POST Code: 4C
00:00:03:52.05471: POST Code: 4D
00:00:03:52.05735: POST Code: 4E
00:00:03:52.06043: POST Code: 4F
00:00:03:52.06307: POST Code: 50
00:00:03:52.06572: POST Code: 51
00:00:03:52.06835: POST Code: 52
00:00:03:52.07100: POST Code: 53
00:00:03:52.07366: POST Code: 54
00:00:03:52.07673: POST Code: 55
00:00:03:52.07939: POST Code: 56
00:00:03:52.08204: POST Code: 57
00:00:03:52.08468: POST Code: 58
00:00:03:52.08732: POST Code: 59
00:00:03:52.09042: POST Code: 5A
00:00:03:52.09329: POST Code: 5B
00:00:03:52.09595: POST Code: 5C
00:00:03:52.09858: POST Code: 5D
00:00:03:53.00142: POST Code: 5E
00:00:03:53.00409: POST Code: 5F
00:00:03:53.00673: POST Code: 60
00:00:03:53.00972: POST Code: 61
00:00:03:53.01257: POST Code: 62
00:00:03:53.01667: POST Code: 63
00:00:03:53.02124: POST Code: 64
00:00:03:53.02392: POST Code: 65
00:00:03:53.02671: POST Code: 66
00:00:03:53.02979: POST Code: 67
00:00:03:53.03247: POST Code: 68
00:00:03:53.03513: POST Code: 69
00:00:03:53.03779: POST Code: 6A
00:00:03:53.04113: POST Code: 6B
00:00:03:53.04378: POST Code: 6C
00:00:03:53.04685: POST Code: 6D
00:00:03:53.04951: POST Code: 6E
00:00:03:53.05214: POST Code: 6F
00:00:03:53.05508: POST Code: 70
00:00:03:53.05772: POST Code: 71
00:00:03:53.06080: POST Code: 72
00:00:03:53.06384: POST Code: 73
00:00:03:53.06674: POST Code: 74
00:00:03:53.06946: POST Code: 75
00:00:03:53.07211: POST Code: 76
00:00:03:53.07522: POST Code: 77
00:00:03:53.07785: POST Code: 78
00:00:03:53.08051: POST Code: 79
00:00:03:53.08317: POST Code: 7A
00:00:03:53.08623: POST Code: 7B
00:00:03:53.08899: POST Code: 7C
00:00:03:53.09218: POST Code: 7D
00:00:03:53.09614: POST Code: 7E
00:00:03:53.09899: POST Code: 7F
00:00:03:54.00172: POST Code: 80
00:00:03:54.00471: POST Code: 81
00:00:03:54.00807: POST Code: 82
00:00:03:54.01089: POST Code: 83
00:00:03:54.01364: POST Code: 84
00:00:03:54.01743: POST Code: 85
00:00:03:54.02045: POST Code: 86
00:00:03:54.02316: POST Code: 87
00:00:03:54.02615: POST Code: 88
00:00:03:54.02927: POST Code: 89
00:00:03:54.03198: POST Code: 8A
00:00:03:54.03504: POST Code: 8B
00:00:03:54.03774: POST Code: 8C
00:00:03:54.04050: POST Code: 8D
00:00:03:54.04320: POST Code: 8E
00:00:03:54.08952: POST Code: 8F
00:00:03:54.09253: POST Code: 90
00:00:03:54.09599: POST Code: 91
00:00:03:54.09944: POST Code: 92
00:00:03:55.00254: POST Code: 93
00:00:03:55.00551: POST Code: 94
00:00:03:55.00827: POST Code: 95
00:00:03:55.01099: POST Code: 96
00:00:03:55.01370: POST Code: 97
00:00:03:55.01667: POST Code: 98
00:00:03:55.01954: POST Code: 99
00:00:03:55.02225: POST Code: 9A
00:00:03:55.02497: POST Code: 9B
00:00:03:55.02770: POST Code: 9C
00:00:03:55.03067: POST Code: 9D
00:00:03:55.03337: POST Code: 9E
00:00:03:55.03609: POST Code: 9F
00:00:03:55.03881: POST Code: A0
00:00:03:55.04153: POST Code: A1
00:00:03:55.04444: POST Code: A2
00:00:03:55.04715: POST Code: A3
00:00:03:55.05029: POST Code: A4
00:00:03:55.05319: POST Code: A5
00:00:03:55.05591: POST Code: A6
00:00:03:55.05863: POST Code: A7
00:00:03:55.06167: POST Code: A8
00:00:03:55.06447: POST Code: A9
00:00:03:55.06717: POST Code: AA
00:00:03:55.06991: POST Code: AB
00:00:03:55.07261: POST Code: AC
00:00:03:55.07553: POST Code: AD
00:00:03:55.07825: POST Code: AE
00:00:03:55.08096: POST Code: AF
00:00:03:55.08367: POST Code: B0
00:00:03:55.08659: POST Code: B1
00:00:03:55.08940: POST Code: B2
00:00:03:55.09211: POST Code: B3
00:00:03:55.09516: POST Code: B4
00:00:03:55.09781: POST Code: B5
00:00:03:56.00066: POST Code: B6
00:00:03:56.00330: POST Code: B7
00:00:03:56.00653: POST Code: B8
00:00:03:56.01038: POST Code: B9
00:00:03:56.01354: POST Code: BA
00:00:03:56.01630: POST Code: BB
00:00:03:56.01979: POST Code: BC
00:00:03:56.02245: POST Code: BD
00:00:03:56.02564: POST Code: BE
00:00:03:56.02834: POST Code: BF
00:00:03:56.03117: POST Code: C0
00:00:03:56.03465: POST Code: C1
00:00:03:56.03752: POST Code: C2
00:00:03:56.04078: POST Code: C3
00:00:03:56.04342: POST Code: C4
00:00:03:56.04626: POST Code: C5
00:00:03:56.04901: POST Code: C6
00:00:03:56.05198: POST Code: C7
00:00:03:56.05482: POST Code: C8
00:00:03:56.05746: POST Code: C9
00:00:03:56.06051: POST Code: CA
00:00:03:56.06315: POST Code: CB
00:00:03:56.06597: POST Code: CC
00:00:03:56.06862: POST Code: CD
00:00:03:56.07195: POST Code: CE
00:00:03:56.07502: POST Code: CF
00:00:03:56.07765: POST Code: D0
00:00:03:56.08049: POST Code: D1
00:00:03:56.08313: POST Code: D2
00:00:03:56.08597: POST Code: D3
00:00:03:56.08861: POST Code: D4
00:00:03:56.09143: POST Code: D5
00:00:03:56.09438: POST Code: D6
00:00:03:56.09709: POST Code: D7
00:00:03:57.00065: POST Code: D8
00:00:03:57.00340: POST Code: D9
00:00:03:57.00614: POST Code: DA
00:00:03:57.01051: POST Code: DB
00:00:03:57.01335: POST Code: DC
00:00:03:57.01684: POST Code: DD
00:00:03:57.01987: POST Code: DE
00:00:03:57.02253: POST Code: DF
00:00:03:57.02572: POST Code: E0
00:00:03:57.02901: POST Code: E1
00:00:03:57.03176: POST Code: E2
00:00:03:57.03472: POST Code: E3
00:00:03:57.03768: POST Code: E4
00:00:03:57.04077: POST Code: E5
00:00:03:57.04339: POST Code: E6
00:00:03:57.04623: POST Code: E7
00:00:03:57.04896: POST Code: E8
00:00:03:57.05172: POST Code: E9
00:00:03:57.05475: POST Code: EA
00:00:03:57.05737: POST Code: EB
00:00:03:57.06082: POST Code: EC
00:00:03:57.06391: POST Code: ED
00:00:03:57.06685: POST Code: EE
00:00:03:57.07005: POST Code: EF
00:00:03:58.02167: POST Code: F0
00:00:03:58.02445: POST Code: F1
00:00:03:58.02716: POST Code: F2
00:00:03:58.03085: POST Code: F3
00:00:03:58.03354: POST Code: F4
00:00:03:58.03692: POST Code: F5
00:00:03:58.03967: POST Code: F6
00:00:03:58.04238: POST Code: F7
00:00:03:58.04545: POST Code: F8
00:00:03:58.04816: POST Code: F9
00:00:03:58.05089: POST Code: FA
00:00:03:58.05359: POST Code: FB
00:00:03:58.05664: POST Code: FC
00:00:03:58.05937: POST Code: FD
00:00:03:58.06262: POST Code: 09
00:00:03:65.09551: POST Code: 0A
00:00:03:65.09578: POST Code: 0B
00:00:03:65.09622: POST Code: 0C
00:00:03:65.09684: POST Code: 0E
00:00:03:65.09712: POST Code: 0F
00:00:05:40.02817: POST Code: 32
00:00:05:78.02603: POST Code: 11
00:00:16:56.09135: POST Code: 12
00:00:16:56.09454: POST Code: 13
00:00:16:56.09480: POST Code: 14
00:00:16:57.00731: POST Code: 15
00:00:16:57.00908: POST Code: 16
00:00:16:57.01005: POST Code: 17
00:00:16:57.01137: POST Code: 18
00:00:16:57.01147: POST Code: 19
00:00:16:57.01200: POST Code: 81
00:00:16:57.05840: POST Code: 85
00:00:16:57.05848: POST Code: 1A
00:00:16:57.05891: POST Code: 1B
00:00:27:20.05532: POST Code: 1C
00:00:27:20.05684: POST Code: 1D
00:00:31:95.08104: POST Code: 1E
00:00:31:95.08198: POST Code: 1F
00:00:31:95.08378: POST Code: 20
00:00:31:95.08552: POST Code: 21
00:00:32:26.09228: POST Code: 23
00:00:37:33.07304: POST Code: 24
00:00:37:33.07628: POST Code: 25
00:00:37:33.07656: POST Code: 26
00:02:13:03.03048: F000:1A37 (E461)IN AL, 61
00:02:13:03.03056: Registers:
00:02:13:03.03056: AX: 1010, BX: 0000, CX: 0EAD, DX: C800
00:02:13:03.03064: CS: F000, DS: 0040, ES: 0040, SS: 0000
00:02:13:03.03072: SP: 03FC, BP: 0000, SI: 0AD7, DI: 0000
00:02:13:03.03072: IP: 1A37, FLAGS: 0246
00:02:13:03.03080: FLAGSINFO:c1P0a0ZstIdo00n0
00:02:13:03.03088: Interrupt status: 0000000000000010
00:02:13:03.03088: VGA@195,212(CRT:222,246)
00:02:13:03.03096: Display=801,446
00:02:13:77.06568: F000:1A39 (2410)AND AL, 10
00:02:13:77.06576: Registers:
00:02:13:77.06584: AX: 10B0, BX: 0000, CX: 0EAD, DX: C800
00:02:13:77.06584: CS: F000, DS: 0040, ES: 0040, SS: 0000
00:02:13:77.06592: SP: 03FC, BP: 0000, SI: 0AD7, DI: 0000
00:02:13:77.06608: IP: 1A39, FLAGS: 0246
00:02:13:77.06608: FLAGSINFO:c1P0a0ZstIdo00n0
00:02:13:77.06816: Interrupt status: 0000000000000010
00:02:13:77.06824: VGA@244,212(CRT:271,246)
00:02:13:77.06832: Display=801,446
00:02:14:25.06336: F000:1A3B (3AC4)CMPB AL,AH
00:02:14:25.06352: Registers:
00:02:14:25.06352: AX: 1010, BX: 0000, CX: 0EAD, DX: C800
00:02:14:25.06368: CS: F000, DS: 0040, ES: 0040, SS: 0000
00:02:14:25.06368: SP: 03FC, BP: 0000, SI: 0AD7, DI: 0000
00:02:14:25.06368: IP: 1A3B, FLAGS: 0202
00:02:14:25.06384: FLAGSINFO:c1p0a0zstIdo00n0
00:02:14:25.06384: Interrupt status: 0000000000000010
00:02:14:25.06592: VGA@264,212(CRT:291,246)
00:02:14:25.06592: Display=801,446
00:02:14:71.04992: F000:1A3D (74F8)JZ 1A37
00:02:14:71.05008: Registers:
00:02:14:71.05008: AX: 1010, BX: 0000, CX: 0EAD, DX: C800
00:02:14:71.05008: CS: F000, DS: 0040, ES: 0040, SS: 0000
00:02:14:71.05024: SP: 03FC, BP: 0000, SI: 0AD7, DI: 0000
00:02:14:71.05024: IP: 1A3D, FLAGS: 0246
00:02:14:71.05024: FLAGSINFO:c1P0a0ZstIdo00n0
00:02:14:71.05264: Interrupt status: 0000000000000010
00:02:14:71.05264: VGA@278,212(CRT:305,246)
00:02:14:71.05264: Display=801,446
00:02:16:65.09056: F000:1A41 (E2F4)LOOP 1A37
00:02:16:65.09072: Registers:
00:02:16:65.09072: AX: 0000, BX: 0000, CX: 0EAD, DX: C800
00:02:16:65.09072: CS: F000, DS: 0040, ES: 0040, SS: 0000
00:02:16:65.09088: SP: 03FC, BP: 0000, SI: 0AD7, DI: 0000
00:02:16:65.09088: IP: 1A41, FLAGS: 0287
00:02:16:65.09088: FLAGSINFO:C1P0a0zStIdo00n0
00:02:16:65.09360: Interrupt status: 0000000000000010
00:02:16:65.09376: VGA@217,281(CRT:244,315)
00:02:16:65.09376: Display=801,446
00:04:14:95.08768: POST Code: 27
00:04:15:07.05760: POST Code: 29
00:04:15:07.05808: POST Code: 2A
00:04:15:07.05952: POST Code: 2B
00:04:15:07.06048: POST Code: 2C
00:04:15:07.06240: POST Code: 2D
00:04:15:07.06256: POST Code: 2F
00:04:15:07.06272: POST Code: 30
00:04:15:07.06336: POST Code: 81
00:04:15:08.07568: POST Code: 85
00:04:15:08.07584: POST Code: 31
00:04:15:10.05008: POST Code: 00
Reply 16 of 151, by superfury
Just managed to get it working further. It now checks memory up to 256K, then gives a memory error (I see accesses to physical address A0000+)? The VGA isn't mapped at that point?
By looking at a simple log of loaded descriptors, all seems fine up until the error:
00:00:03:29.09396: POST Code: 01
00:00:03:30.00288: POST Code: 02
00:00:03:53.08812: POST Code: 03
00:00:03:53.09056: POST Code: 04
00:00:03:53.09110: POST Code: 05
00:00:03:53.09187: POST Code: 06
00:00:03:53.09917: POST Code: 07
00:00:03:54.00679: POST Code: 08
00:00:03:54.00976: POST Code: 00
00:00:03:54.01238: POST Code: 01
00:00:03:54.01522: POST Code: 02
00:00:03:54.01785: POST Code: 03
00:00:03:54.02083: POST Code: 04
00:00:03:54.02364: POST Code: 05
00:00:03:54.02683: POST Code: 06
00:00:03:54.03041: POST Code: 07
00:00:03:54.03534: POST Code: 08
00:00:03:54.03816: POST Code: 09
00:00:03:54.04176: POST Code: 0A
00:00:03:54.04483: POST Code: 0B
00:00:03:54.04803: POST Code: 0C
00:00:03:54.05112: POST Code: 0D
00:00:03:54.05443: POST Code: 0E
00:00:03:55.00244: POST Code: 0F
00:00:03:55.00594: POST Code: 10
00:00:03:55.00870: POST Code: 11
00:00:03:55.01145: POST Code: 12
00:00:03:55.01438: POST Code: 13
00:00:03:55.01707: POST Code: 14
00:00:03:55.02015: POST Code: 15
00:00:03:55.02279: POST Code: 16
00:00:03:55.02603: POST Code: 17
00:00:03:55.02888: POST Code: 18
00:00:03:55.03151: POST Code: 19
00:00:03:55.03460: POST Code: 1A
00:00:03:55.03721: POST Code: 1B
00:00:03:55.04028: POST Code: 1C
00:00:03:55.04293: POST Code: 1D
00:00:03:55.04580: POST Code: 1E
00:00:03:55.04843: POST Code: 1F
00:00:03:55.05146: POST Code: 20
00:00:03:55.05443: POST Code: 21
00:00:03:55.05706: POST Code: 22
00:00:03:55.06001: POST Code: 23
00:00:03:55.06265: POST Code: 24
00:00:03:55.06573: POST Code: 25
00:00:03:55.06948: POST Code: 26
00:00:03:55.07212: POST Code: 27
00:00:03:55.07498: POST Code: 28
00:00:03:55.07761: POST Code: 29
00:00:03:55.08066: POST Code: 2A
00:00:03:55.08332: POST Code: 2B
00:00:03:55.08653: POST Code: 2C
00:00:03:55.08956: POST Code: 2D
00:00:03:55.09283: POST Code: 2E
00:00:03:55.09687: POST Code: 2F
00:00:03:56.00050: POST Code: 30
00:00:03:56.00328: POST Code: 31
00:00:03:56.00615: POST Code: 32
00:00:03:56.00921: POST Code: 33
…Show last 380 lines
00:00:03:56.01185: POST Code: 34
00:00:03:56.01507: POST Code: 35
00:00:03:56.01800: POST Code: 36
00:00:03:56.02079: POST Code: 37
00:00:03:56.02418: POST Code: 38
00:00:03:56.02730: POST Code: 39
00:00:03:56.03036: POST Code: 3A
00:00:03:56.03302: POST Code: 3B
00:00:03:56.03594: POST Code: 3C
00:00:03:56.03879: POST Code: 3D
00:00:03:56.04143: POST Code: 3E
00:00:03:56.04450: POST Code: 3F
00:00:03:56.04713: POST Code: 40
00:00:03:56.04999: POST Code: 41
00:00:03:56.05263: POST Code: 42
00:00:03:56.05601: POST Code: 43
00:00:03:56.05908: POST Code: 44
00:00:03:56.06233: POST Code: 45
00:00:03:56.06622: POST Code: 46
00:00:03:56.06914: POST Code: 47
00:00:03:56.07185: POST Code: 48
00:00:03:56.07478: POST Code: 49
00:00:03:56.07747: POST Code: 4A
00:00:03:56.08040: POST Code: 4B
00:00:03:56.08315: POST Code: 4C
00:00:03:56.08636: POST Code: 4D
00:00:03:56.08968: POST Code: 4E
00:00:03:56.09241: POST Code: 4F
00:00:03:56.09604: POST Code: 50
00:00:03:56.09905: POST Code: 51
00:00:03:57.00169: POST Code: 52
00:00:03:57.00456: POST Code: 53
00:00:03:57.00720: POST Code: 54
00:00:03:57.01014: POST Code: 55
00:00:03:57.01278: POST Code: 56
00:00:03:57.01563: POST Code: 57
00:00:03:57.01827: POST Code: 58
00:00:03:57.02110: POST Code: 59
00:00:03:57.02405: POST Code: 5A
00:00:03:57.02675: POST Code: 5B
00:00:03:57.02987: POST Code: 5C
00:00:03:57.03271: POST Code: 5D
00:00:03:57.03674: POST Code: 5E
00:00:03:57.04175: POST Code: 5F
00:00:03:57.04685: POST Code: 60
00:00:03:57.05192: POST Code: 61
00:00:03:57.05697: POST Code: 62
00:00:03:57.06198: POST Code: 63
00:00:03:57.06713: POST Code: 64
00:00:03:57.07213: POST Code: 65
00:00:03:57.07727: POST Code: 66
00:00:03:57.08228: POST Code: 67
00:00:03:58.04430: POST Code: 68
00:00:03:58.04815: POST Code: 69
00:00:03:58.05141: POST Code: 6A
00:00:03:58.05548: POST Code: 6B
00:00:03:58.05817: POST Code: 6C
00:00:03:58.06113: POST Code: 6D
00:00:03:58.06409: POST Code: 6E
00:00:03:58.06697: POST Code: 6F
00:00:03:58.07052: POST Code: 70
00:00:03:58.07323: POST Code: 71
00:00:03:58.07613: POST Code: 72
00:00:03:58.07950: POST Code: 73
00:00:03:58.08266: POST Code: 74
00:00:03:58.08794: POST Code: 75
00:00:03:58.09165: POST Code: 76
00:00:03:58.09459: POST Code: 77
00:00:03:58.09769: POST Code: 78
00:00:03:59.00059: POST Code: 79
00:00:03:59.00330: POST Code: 7A
00:00:03:59.00639: POST Code: 7B
00:00:03:59.00929: POST Code: 7C
00:00:03:59.01197: POST Code: 7D
00:00:03:59.01490: POST Code: 7E
00:00:03:59.01759: POST Code: 7F
00:00:03:59.02048: POST Code: 80
00:00:03:59.02318: POST Code: 81
00:00:03:59.02607: POST Code: 82
00:00:03:59.02895: POST Code: 83
00:00:03:59.03163: POST Code: 84
00:00:03:59.03454: POST Code: 85
00:00:03:59.03723: POST Code: 86
00:00:03:59.04012: POST Code: 87
00:00:03:59.04282: POST Code: 88
00:00:03:59.04573: POST Code: 89
00:00:03:59.04843: POST Code: 8A
00:00:03:59.05132: POST Code: 8B
00:00:03:59.05428: POST Code: 8C
00:00:03:59.05696: POST Code: 8D
00:00:03:59.05984: POST Code: 8E
00:00:03:59.06253: POST Code: 8F
00:00:03:59.06546: POST Code: 90
00:00:03:59.06816: POST Code: 91
00:00:03:59.07108: POST Code: 92
00:00:03:59.07398: POST Code: 93
00:00:03:59.07666: POST Code: 94
00:00:03:59.07954: POST Code: 95
00:00:03:59.08224: POST Code: 96
00:00:03:59.08517: POST Code: 97
00:00:03:59.08801: POST Code: 98
00:00:03:59.09092: POST Code: 99
00:00:03:59.09375: POST Code: 9A
00:00:03:59.09701: POST Code: 9B
00:00:03:60.00011: POST Code: 9C
00:00:03:60.00280: POST Code: 9D
00:00:03:60.00580: POST Code: 9E
00:00:03:60.01085: POST Code: 9F
00:00:03:60.01520: POST Code: A0
00:00:03:60.01891: POST Code: A1
00:00:03:60.02167: POST Code: A2
00:00:03:60.02446: POST Code: A3
00:00:03:60.02765: POST Code: A4
00:00:03:60.03058: POST Code: A5
00:00:03:60.03420: POST Code: A6
00:00:03:60.03907: POST Code: A7
00:00:03:60.04397: POST Code: A8
00:00:03:60.04902: POST Code: A9
00:00:03:60.05558: POST Code: AA
00:00:03:60.06133: POST Code: AB
00:00:03:60.06942: POST Code: AC
00:00:03:60.07399: POST Code: AD
00:00:03:60.08090: POST Code: AE
00:00:03:60.08556: POST Code: AF
00:00:03:60.09030: POST Code: B0
00:00:03:60.09558: POST Code: B1
00:00:03:61.00038: POST Code: B2
00:00:03:61.00530: POST Code: B3
00:00:03:61.01038: POST Code: B4
00:00:03:61.01390: POST Code: B5
00:00:03:61.01669: POST Code: B6
00:00:03:61.07196: POST Code: B7
00:00:03:61.07484: POST Code: B8
00:00:03:61.07761: POST Code: B9
00:00:03:61.08052: POST Code: BA
00:00:03:61.08328: POST Code: BB
00:00:03:61.08699: POST Code: BC
00:00:03:61.09006: POST Code: BD
00:00:03:61.09481: POST Code: BE
00:00:03:61.09803: POST Code: BF
00:00:03:62.00119: POST Code: C0
00:00:03:62.00419: POST Code: C1
00:00:03:62.00687: POST Code: C2
00:00:03:62.00981: POST Code: C3
00:00:03:62.01253: POST Code: C4
00:00:03:62.01549: POST Code: C5
00:00:03:62.01829: POST Code: C6
00:00:03:62.02115: POST Code: C7
00:00:03:62.02405: POST Code: C8
00:00:03:62.02692: POST Code: C9
00:00:03:62.02999: POST Code: CA
00:00:03:62.03271: POST Code: CB
00:00:03:62.03565: POST Code: CC
00:00:03:62.03835: POST Code: CD
00:00:03:62.04135: POST Code: CE
00:00:03:62.04429: POST Code: CF
00:00:03:62.04699: POST Code: D0
00:00:03:62.04998: POST Code: D1
00:00:03:62.05269: POST Code: D2
00:00:03:62.05565: POST Code: D3
00:00:03:62.05833: POST Code: D4
00:00:03:62.06128: POST Code: D5
00:00:03:62.06424: POST Code: D6
00:00:03:62.06694: POST Code: D7
00:00:03:62.06987: POST Code: D8
00:00:03:62.07257: POST Code: D9
00:00:03:62.07552: POST Code: DA
00:00:03:62.07821: POST Code: DB
00:00:03:62.08125: POST Code: DC
00:00:03:62.08413: POST Code: DD
00:00:03:62.08696: POST Code: DE
00:00:03:62.08990: POST Code: DF
00:00:03:62.09260: POST Code: E0
00:00:03:62.09558: POST Code: E1
00:00:03:62.09917: POST Code: E2
00:00:03:63.00191: POST Code: E3
00:00:03:63.00484: POST Code: E4
00:00:03:63.00753: POST Code: E5
00:00:03:63.01059: POST Code: E6
00:00:03:63.01330: POST Code: E7
00:00:03:63.01624: POST Code: E8
00:00:03:63.01931: POST Code: E9
00:00:03:63.02203: POST Code: EA
00:00:03:63.02494: POST Code: EB
00:00:03:63.02783: POST Code: EC
00:00:03:63.03071: POST Code: ED
00:00:03:63.03351: POST Code: EE
00:00:03:63.03627: POST Code: EF
00:00:03:63.03910: POST Code: F0
00:00:03:63.04185: POST Code: F1
00:00:03:63.04470: POST Code: F2
00:00:03:63.04750: POST Code: F3
00:00:03:63.05045: POST Code: F4
00:00:03:63.05334: POST Code: F5
00:00:03:63.05624: POST Code: F6
00:00:03:63.05958: POST Code: F7
00:00:03:63.06243: POST Code: F8
00:00:03:63.06539: POST Code: F9
00:00:03:63.06866: POST Code: FA
00:00:03:63.07345: POST Code: FB
00:00:03:63.07764: POST Code: FC
00:00:03:63.08189: POST Code: FD
00:00:03:63.08707: POST Code: 09
00:00:03:71.07096: POST Code: 0A
00:00:03:71.07132: POST Code: 0B
00:00:03:71.07177: POST Code: 0C
00:00:03:71.07240: POST Code: 0E
00:00:03:71.07267: POST Code: 0F
00:00:05:22.07786: POST Code: 32
00:00:05:61.01095: POST Code: 11
00:00:16:78.08158: POST Code: 12
00:00:16:78.08610: POST Code: 13
00:00:16:78.08640: POST Code: 14
00:00:16:78.09676: POST Code: 15
00:00:16:78.09806: POST Code: 16
00:00:16:78.09852: POST Code: 17
00:00:16:78.09970: POST Code: 18
00:00:16:78.09980: POST Code: 19
00:00:16:79.00034: POST Code: 81
00:00:16:79.04440: Loading segment #0 with base 000F0000
00:00:16:79.04446: POST Code: 85
00:00:16:79.04454: POST Code: 1A
00:00:16:79.04464: Loading segment #2 with base 0000D8A0
00:00:16:79.04504: POST Code: 1B
00:00:16:79.04540: Loading segment #2 with base 00000400
00:00:16:79.04554: Loading segment #2 with base 0000D8A0
00:00:16:94.01106: Loading segment #2 with base 00010000
00:00:17:10.00536: Loading segment #2 with base 0000D8A0
00:00:17:10.00588: Loading segment #2 with base 00000400
00:00:17:10.00602: Loading segment #2 with base 0000D8A0
00:00:17:24.04112: Loading segment #2 with base 00020000
00:00:17:40.09798: Loading segment #2 with base 0000D8A0
00:00:17:40.09854: Loading segment #2 with base 00000400
00:00:17:40.09866: Loading segment #2 with base 0000D8A0
00:00:17:55.06672: Loading segment #2 with base 00030000
00:00:17:71.09524: Loading segment #2 with base 0000D8A0
00:00:17:71.09578: Loading segment #2 with base 00000400
00:00:17:71.09592: Loading segment #2 with base 0000D8A0
00:00:17:86.02098: Loading segment #2 with base 00040000
00:00:18:02.02866: Loading segment #2 with base 0000D8A0
00:00:18:02.02918: Loading segment #2 with base 00000400
00:00:18:02.02936: Loading segment #2 with base 0000D8A0
00:00:18:16.04508: Loading segment #2 with base 00050000
00:00:18:33.00726: Loading segment #2 with base 0000D8A0
00:00:18:33.00780: Loading segment #2 with base 00000400
00:00:18:33.00794: Loading segment #2 with base 0000D8A0
00:00:18:47.05814: Loading segment #2 with base 00060000
00:00:18:63.03010: Loading segment #2 with base 0000D8A0
00:00:18:63.03072: Loading segment #2 with base 00000400
00:00:18:63.03084: Loading segment #2 with base 0000D8A0
00:00:18:78.07762: Loading segment #2 with base 00070000
00:00:18:94.04360: Loading segment #2 with base 0000D8A0
00:00:18:94.04414: Loading segment #2 with base 00000400
00:00:18:94.04426: Loading segment #2 with base 0000D8A0
00:00:19:09.02070: Loading segment #2 with base 00080000
00:00:19:25.06638: Loading segment #2 with base 0000D8A0
00:00:19:25.06720: Loading segment #2 with base 00000400
00:00:19:25.06732: Loading segment #2 with base 0000D8A0
00:00:19:40.02634: Loading segment #2 with base 00090000
00:00:19:56.03978: Loading segment #2 with base 0000D8A0
00:00:19:56.04040: POST Code: 1C
00:00:19:56.04182: Loading segment #0 with base 000F0000
00:00:19:56.04252: Loading segment #0 with base 000F0000
00:00:19:56.04266: Loading segment #2 with base 00000400
00:00:19:56.04288: Loading segment #2 with base 0000D8A0
00:00:19:56.04300: POST Code: 1D
00:00:19:56.04340: Loading segment #2 with base 00000400
00:00:19:56.04352: Loading segment #2 with base 0000D8A0
00:00:19:70.03458: Loading segment #2 with base 00100000
00:00:19:86.08354: Loading segment #2 with base 0000D8A0
00:00:19:86.08412: Loading segment #2 with base 00000400
00:00:19:86.08424: Loading segment #2 with base 0000D8A0
00:00:20:01.00992: Loading segment #2 with base 00110000
00:00:20:17.00314: Loading segment #2 with base 0000D8A0
00:00:20:17.00368: Loading segment #2 with base 00000400
00:00:20:17.00380: Loading segment #2 with base 0000D8A0
00:00:20:31.08594: Loading segment #2 with base 00120000
00:00:20:47.05978: Loading segment #2 with base 0000D8A0
00:00:20:47.06038: Loading segment #2 with base 00000400
00:00:20:47.06052: Loading segment #2 with base 0000D8A0
00:00:20:62.00934: Loading segment #2 with base 00130000
00:00:20:78.04902: Loading segment #2 with base 0000D8A0
00:00:20:78.04958: Loading segment #2 with base 00000400
00:00:20:78.04972: Loading segment #2 with base 0000D8A0
00:00:20:93.02680: Loading segment #2 with base 00140000
00:00:21:09.03812: Loading segment #2 with base 0000D8A0
00:00:21:09.03898: Loading segment #2 with base 00000400
00:00:21:09.03914: Loading segment #2 with base 0000D8A0
00:00:21:23.06194: Loading segment #2 with base 00150000
00:00:21:39.06410: Loading segment #2 with base 0000D8A0
00:00:21:39.06528: Loading segment #2 with base 00000400
00:00:21:39.06550: Loading segment #2 with base 0000D8A0
00:00:21:53.09610: Loading segment #2 with base 00160000
00:00:21:69.07938: Loading segment #2 with base 0000D8A0
00:00:21:69.07992: Loading segment #2 with base 00000400
00:00:21:69.08006: Loading segment #2 with base 0000D8A0
00:00:21:84.02840: Loading segment #2 with base 00170000
00:00:22:00.09004: Loading segment #2 with base 0000D8A0
00:00:22:00.09060: Loading segment #2 with base 00000400
00:00:22:00.09072: Loading segment #2 with base 0000D8A0
00:00:22:15.02412: Loading segment #2 with base 00180000
00:00:22:31.08104: Loading segment #2 with base 0000D8A0
00:00:22:31.08158: Loading segment #2 with base 00000400
00:00:22:31.08170: Loading segment #2 with base 0000D8A0
00:00:22:46.02936: Loading segment #2 with base 00190000
00:00:22:62.04922: Loading segment #2 with base 0000D8A0
00:00:22:62.04976: Loading segment #2 with base 00000400
00:00:22:62.04990: Loading segment #2 with base 0000D8A0
00:00:22:76.05156: Loading segment #2 with base 001A0000
00:00:22:93.03510: Loading segment #2 with base 0000D8A0
00:00:22:93.03562: Loading segment #2 with base 00000400
00:00:22:93.03574: Loading segment #2 with base 0000D8A0
00:00:23:08.05542: Loading segment #2 with base 001B0000
00:00:23:24.00596: Loading segment #2 with base 0000D8A0
00:00:23:24.00652: Loading segment #2 with base 00000400
00:00:23:24.00664: Loading segment #2 with base 0000D8A0
00:00:23:39.00516: Loading segment #2 with base 001C0000
00:00:23:55.07188: Loading segment #2 with base 0000D8A0
00:00:23:55.07242: Loading segment #2 with base 00000400
00:00:23:55.07254: Loading segment #2 with base 0000D8A0
00:00:23:69.07892: Loading segment #2 with base 001D0000
00:00:23:85.09260: Loading segment #2 with base 0000D8A0
00:00:23:85.09314: Loading segment #2 with base 00000400
00:00:23:85.09326: Loading segment #2 with base 0000D8A0
00:00:24:00.04354: Loading segment #2 with base 001E0000
00:00:24:16.06110: Loading segment #2 with base 0000D8A0
00:00:24:16.06160: Loading segment #2 with base 00000400
00:00:24:16.06176: Loading segment #2 with base 0000D8A0
00:00:24:30.09910: Loading segment #2 with base 001F0000
00:00:24:47.00874: Loading segment #2 with base 0000D8A0
00:00:24:47.00924: POST Code: 1E
00:00:24:47.00966: Loading segment #0 with base 000F0000
00:00:24:47.01012: Loading segment #0 with base 000F0000
00:00:24:47.01028: POST Code: 1F
00:00:24:47.01212: POST Code: 20
00:00:24:47.01450: POST Code: 21
00:00:24:79.09186: POST Code: 23
00:00:29:93.05178: POST Code: 24
00:00:29:93.05572: POST Code: 25
00:00:29:93.05604: POST Code: 26
00:03:46:10.03408: POST Code: 27
00:03:46:22.08656: POST Code: 29
00:03:46:22.08704: POST Code: 2A
00:03:46:22.08880: POST Code: 2B
00:03:46:22.09072: POST Code: 2C
00:03:46:22.09456: POST Code: 2D
00:03:46:22.09488: POST Code: 2F
00:03:46:22.09504: POST Code: 30
00:03:46:22.09584: POST Code: 81
00:03:46:23.07072: Loading segment #0 with base 000F0000
00:03:46:23.07072: POST Code: 85
00:03:46:23.07088: POST Code: 31
00:03:46:23.07120: Loading segment #2 with base 00000400
00:03:46:23.09008: Loading segment #0 with base 000F0000
00:03:46:23.09088: Loading segment #0 with base 000F0000
00:03:46:23.09248: Loading segment #0 with base 000F0000
00:03:46:23.09360: Loading segment #0 with base 000F0000
00:03:46:23.09488: Loading segment #0 with base 000F0000
00:03:46:23.09744: Loading segment #2 with base 0000D8A0
00:03:46:23.09888: Loading segment #2 with base 00010000
00:03:48:50.02432: POST Code: 32
00:03:49:06.03712: Loading segment #2 with base 0000D8A0
00:03:49:06.03776: Loading segment #2 with base 00020000
00:03:49:06.03792: POST Code: 31
00:03:51:36.02528: POST Code: 32
00:03:51:91.06352: Loading segment #2 with base 0000D8A0
00:03:51:91.06448: Loading segment #2 with base 00030000
00:03:51:91.06464: POST Code: 31
00:03:54:13.02880: POST Code: 32
00:03:54:69.02784: Loading segment #2 with base 0000D8A0
00:03:54:69.02848: Loading segment #2 with base 00040000
00:03:54:69.02864: POST Code: 31
00:03:54:69.03264: Loading segment #2 with base 00000400
00:03:54:69.03328: Loading segment #0 with base 000F0000
00:03:54:69.03376: Loading segment #0 with base 000F0000
00:03:54:69.03440: Loading segment #0 with base 000F0000
00:03:54:69.03504: Loading segment #0 with base 000F0000
00:03:54:69.03552: Loading segment #0 with base 000F0000
00:03:54:71.08048: POST Code: 00
Just CS(segment #0) and DS(Segment #2) are logged here, because the test tests using it.
Edit: Just might have found the cause: The PIT was returning the wrong channel 1 line on port 0x61, causing bit 0x40 to be set (which is incorrect) with current status 2(which isn't the line at all: it's the part of the command, being used for changing PIT states(like waiting for gates to rise, lower, step, inactive counters etc.).
UniPCemu Git repository
Reply 17 of 151, by superfury
It now runs until the following point:
01664 KB OK
0010000 0080 203-Memory Address Error
Although the delays using the 0x61 bit 4(PIT1 output) take terribly long for some reason? Like about 1-1.5 minute for a 100 millisecond delay according to the code. Looking at what it sets up it's about 200Hz signal resulting after division(200Hz Rate Generator)? If this is used for toggling and timing, about 200 changes each second is consumed, so the 100 millisecond taking about 6000 of those changes results in a 122 seconds delay?
The reload value is set to 0x12FF, so 1.19MHz/0x12FF=~1193181/4863=245.3 timeouts per second, thus 6628*245.3=27.01 seconds delay?
;--- WAITF ---------------------------------------------------------------
; FIXED TIME WAIT ROUTINE HARDWARE CONTROLLED - NOT PROCESSOR) :
; ENTRY: :
; (CX) = COUNT OF 15.,085737 MICROSECOND INTERVALS TO WAIT :
; MEMORY REFRESH TIMER 1 OUTPUT USED AS REFERENCE :
; EXIT: :
; AFTER (CX) TIME COUNT (PLUS OR MINUS 16 MICROSECONDS) :
; (CX) = 0 :
WAITF PROC NEAR ; DELAY FOR (CX)*15.085737 US
PUSH AX ; SAVE WORK REGISTER (AH)
WAITFI: ; USE TIMER 1 OUTPUT BITS
IN AL,PORT_B ; READ CURRENT COUNTER OUTPUT STATUS
AND AL,REFRESH_BIT ; MASK FOR REFRESH DETERMINE BIT
CMP AL,AH ; DID IT JUST CHANGE
JE WAITF1 ; WAIT FOR A CHANCE IN OUTPUT LINE
MOV AH,AL ; SAVE NEW FLAG STATE
LOOP WAITF1 ; DECREMENT HALF CYCLES TILL COUNT END
POP AX ; RESTORE (AH)
RET ; RETURN (CX)= 0
WAITF ENDP
The problem with this is that the timer is set to refresh too slow (instead of a count of 72 loaded(to get the correct frequency), there's a counter of 0x12FF loaded)?
Edit: Implementing the AT PIT Read Back command and seperate hi/low byte updates has no effect it seems. The impossible big value is still set?
Reply 18 of 151, by Jepael
Timer mode 0x53, so loads LSB only. Loaded count should be 18 = 0x12, so 0x0012, not 0x12FF.
I think the PIT emulation is wrong, if you load only LSB, then force high byte to zero.
Reply 19 of 151, by superfury
Well, the strange thing is: I'm receiving strange command bytes:
First it sets command byte 0x54, which sets PIT 1, mode 2, LSB
Then it sets command byte 0x40, which latches PIT1(overwrite mode to latch low, high mode).
Further commands keep being command 0x40(latch low,high mode)? Or does this latch mode only affect reads from port 0x40-0x42?
This is my current PIT emulation code:
https://bitbucket.org/superfury/unipcemu/src/ … pit.c?at=master
Look at the out8253/in8253 commands for the I/O from the CPU and how that's handled. tickPIT handles all timing based on the 14MHz clock and realtime clock(nanoseconds passed, used for sound updates).
Does the latch modes overwrite the current lo,hi or lo-hi mode or only used temporary until it's fully processed(and discarded(not used anymore, thus reverting to the previous non-latch mode) when being fully read/written or the command register is written)? I've roughly based it on osdev documentation, but it doesn't specify where, if at all, the command register is stored and what retains when.
