First post, by Guest
I'm having trouble getting a batch file to work under DOSBox. It
dies at a 'for' loop. The batch file works fine under old DOS.
The same batch file has a problem with a copy command. The
command has a /y option, which says to overwrite an existing file
without prompting the user. Old DOS works fine, DOSBox says I
have an invalid parameter.
Any help?
Thanks
-jeff
<Disclaimer - I searched the forum first before asking these, sorry
if they've been answered and I wasn't able to fine the answer.>
