First post, by ersteinmal
Dear all.
intro: it seems, that I made mistakes, maybe the reason is my bad english.
Status: I like to make *.conf files inside the Game path. And of cause, the name of them have to get the Gamemame like that.
The attachment Siedler mit Dosbox.conf is no longer available
Siedler mit Dosbox.bat => C:\Spiele\dosbox\dosbox "C:\Spiele\SIEDLER\Siedler mit Dosbox.conf" (only one attachment is allowed.
But it does not work. I thing that the mistake is, that only dosbox.conf is allowed.
Please help.
Regards
Carsten
    72 Bytes
    31 downloads
Reply 1 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
1. we have Dosbox forums, please use them (I'll move this topic)
2. you need to use the command line argument -conf
C:\Spiele\dosbox\dosbox -conf "C:\Spiele\SIEDLER\Siedler mit Dosbox.conf"
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 6, by ersteinmal
Thanks For changing.
Here my tryings:
1. Correcting the .bat file to :
2. Run "Reset Options.bat"
CONFIG:Loading primary settings from config file C:\Spiele\SIEDLER\Siedler mit Dosbox.conf
MIDI:Opened device:win32
DOS keyboard layout loaded with main language code GR for layout gr
.conf text:
mount c "C:\Spiele\SIEDLER"
c:
sied.exe
[autoexec]
fullscreen=true
==>>It does not work.
There must be an other mistake.
Carsten
Reply 3 of 6, by Dominus
DOSBox Moderator
The stuff above [autoexec] needs to be below and the stuff below needs to be above
Reply 5 of 6, by Dominus
DOSBox Moderator
actually fullscreen=true needs to be below [sdl]. You should look at the default dosbox.conf for a more verbose config which explains stuff. For example that the commands needs to be in the autoexec section (meaning below [autoexec].
But from your smiley I guess you made it work now?
