First post, by mmx_91
Hi!
I'm trying to fire up a Matrox Millennium (4MB - IS Storm labelled by IBM) that I got for almost nothing some weeks ago. It has two DIP switches on the board as shown on the picture (actual photo):
One is for Bios protection, and the other one is to disable VGA (still don't really know why I would want to disable it, to use double monitors I've read) 🤣.
I can't manage to make it work. If I disable the VGA ouptup by using the SW2 switch, the computer refuses to boot and its beep code tells me 'no graphics card present', which is ok. But if I keep this option enabled as it shoud be, the pc works but shows nothing on the screen.
To try it further, I installed a secondary AGP card and tried to diagnose the Matrox one, I even updated its bios to latest version (3.00), and it keeps telling me that VGA is disabled (and no image at all), whereas the physical switch is not set to do so. This is what the computer tells me:
I don't really know what's happening here, as I don't hace any experience in Matrox cards, but I realise they're a bit special. My plan is keeping it to be paired with a pci Voodoo in a future build 😀. Maybe it's broken (I don't think so since it's recognised 😀 ).
Does anybody experienced such problems?
Thank you in advance for your help!
Reply 1 of 16, by Half-Saint
Have you tried this card in another computer?
Reply 2 of 16, by mmx_91
Yep! The main tests were done over a SS7 system, but also tried it on an Athlon XP with the same results. I still have to test further before discarding it 😀
Reply 3 of 16, by CkRtech
It is possible your switch is broken. If you have a multimeter, you can test the switch using the two points on the back of the card. If that is the case, you will probably get continuity from the two points despite the position of the switch.
Reply 4 of 16, by cookie
Hello everyone,
I'm putting an answer to this subject, as I've been looking for this exact graphics card model, found one, and encountered the same problem. Reported in devices but no VGA output.
For those in the same situation, you need to tell the program PROGBIOS.exe to force flashing of the bios (but backup the original just in case).
Since this model of card comes in factory with a Macintosh bios, it will not be addressed correctly.
Install the Matrox Millennium as a 2nd video card, and use another one as the 1st (higher PCI slot, use another brand to not confuse progbios).
There's a hidden option -k so it gives the command line : progbios -i 838-20.bin -k
(don't forget to move the bios protection dipswitch)
Remove others video cards, reboot and enjoy POST screen. 😀 hope it helps whoever will need this.
Reply 5 of 16, by Errius
As I understand, on a system with two video cards, the "disable VGA" option makes that card the secondary adaptor, even if it is mounted on the AGP slot or a lower PCI slot than the primary card.
This issue came up in this thread: ATI 3D Rage II jumpers
"AI Requires Proof That You Are Human"
Reply 6 of 16, by cookie
I found a Millennium Installation Guide on Google (Matrox filetype:pdf "switch" "vga disabled") which says this :
[code]Switch 2: VGA Enable/Disable switch
By default the VGA of your Millennium card is enabled (Switch 2=OFF) for single-screen
operation, which means that you must remove or disable your existing VGA, if you have one. If the
VGA is on the motherboard of your PCI system, it should be disabled automatically.
This switch should be set to ON if you want to work in a dual-screen configuration. In this case
you will also be using either a VGA in another slot or on your system’s motherboard, or another
Matrox card for output to the second monitor.[/code]
So that proves it, it is for a dual-screen combination with Matrox software.
However in this specific case I think the "Vga Disabled" message in DOS we saw is because the Mac firmware makes it unusable to the PC BIOS (not because of the dipswitch).
That was the only way I found to make it work, by reflashing its bios.
Reply 7 of 16, by Merovign
Alternatively if you find one with a Mac bios you might sell or trade it, 90s Mac video cards are relatively rare.
I have a Mac Millenium that's not detected by its Mac but is by a PC, and sadly I think someone flashed it with a PC BIOS.
*Too* *many* *things*!
Reply 8 of 16, by cookie
I backed up the Millennium PCI's Mac BIOS file, if you wish to flash it for Mac I could make them available here
Reply 9 of 16, by eisapc
If the card was IBM labeled it may originate from an RS/6000 workstation. I remember flashing another Matrox PC card with the IBM BIOS in lack of a GXT 130 for my RS6K.
eisapc
Reply 10 of 16, by naujoks
I, too, have a non booting Millennium, presumed to have a MAC BIOS on it.
Where can I find the progbios.exe and the BIOS? And what's the command to save the old BIOS?
Reply 11 of 16, by analog_programmer
naujoks wrote on 2024-01-19, 20:40:
MGA Millennium BIOS file and flash tool can be downloaded from Vogons drivers library page.
Also you can try some BIOS-dump files from here (look at "Download attachments - BIOS").
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 12 of 16, by naujoks
Ahhh I ran the progbios utility, but it started flashing the BIOS right away, not even asking for any confirmation.
It worked, but I wasn't able to back up the old BIOS. Now I'm sad. Can someone send me the Mac BIOS, please?
Reply 13 of 16, by PC Hoarder Patrol
naujoks wrote on 2024-01-20, 09:00:
Try here - https://ftp.matrox.com/pub/mga/mac/millennm/bios/
Older versions can be found here - https://ftp.matrox.com/pub/mga/mac/millennm/previous/
Reply 14 of 16, by naujoks
Thanks, these are all .HQX files. Do they need to be converted to a binary file?
Reply 15 of 16, by elszgensa
Haven't looked at the files but the extension sounds a lot like a Mac archive format. I'd try opening them with the usual suspects like 7-Zip first, failing that - Aladdin/Stuffit Expander.
Reply 16 of 16, by PC Hoarder Patrol
naujoks wrote on 2024-01-20, 13:41:
Yes, they're Mac binary... only tried 7-Zip (no go) though apparently Stuffit or Winzip are claimed to work
