First post, by Pablo
I have a prog,with Russian language. On my athlon & win XP a can`t run it. This emuator can Run it, BUT i can`t read something, because currently dosbox is not supproting languages, other than russian. Maybe in next versions of this great emulator i can run my prog, isn`t it?
Reply 1 of 1, by StormBlast
It's not a problem. You can read and write in russian under DOSBox if you load KEYRUS. Just put it in the directory you want to mount, run DOSBox, mount your dir and run KEYRUS. You can get it here: http://gurtjak.skif.net/programs/keyrus8b.zip
