First post, by Jade Falcon
Rank BANNED
BANNED
I been tasked with installing a meshed wifi network in a roughly 1800-2000 sq ft retail location.
The building has a lot of sheet metal in the walls and ceiling that blocks wifi singles.
They need good strong wifi in ever nook and cranny of the building as they use old IPhones for barcode scanners and what not.
The store does not have a budget for something like a Meraki setup and I'm looking for a more low cost setup. Anyone here used open mesh before? Is it reliable? Any good? Or should I look elsewhere?
Any advice on open mesh would be nice. I always herd good stuff about it but never used it before.
Reply 2 of 9, by Jade Falcon
Rank BANNED
BANNED
clueless1 wrote:
No experience with openmesh, sorry. Have you ever messed with Unifi?
No I have not. I never really looked into them.
Reply 3 of 9, by Rhuwyn
I've used Meraki but not open mesh, but now I wanna try it...🤣
Reply 4 of 9, by sf78
I've just "daisy chained" several WIFI routers around the place to get maximum cover. It would be the cheapest option as then you can connect the computers, phones etc. however you want.
Reply 5 of 9, by Jade Falcon
Rank BANNED
BANNED
I done that before, it never ends wells.
Reply 6 of 9, by clueless1
Unifi has a huge bang for your buck. You install controller software on one PC and it controls every Unifi AP (you can still SSH into the APs if needed). You can move SSIDs to any device from the software, and segmented guest wifi is built in. The APs are about $85 each and the controller software is free.
Reply 7 of 9, by sf78
I haven't had problems as long as you only have one router with outside connection that gives all the IP's and the others are "silent" and just replicate the network signal. I have 3 running at my work place and they don't have any resource conflicts.
Signal strength is also pretty good, even through brick walls and fire doors (around 3/5 bars).
Reply 8 of 9, by gdjacobs
The problem is scalability when you don't have proper network backhaul.
Reply 9 of 9, by Jade Falcon
Rank BANNED
BANNED
It's less of a Signal strength problem and more of a scaling problem and sometime with apple devices things get messy with such a setup.
