First post, by Guest
The Dos-Box works with the original MS-DOS 5.0 keyboard driver.
With this driver foreign keyboard layouts with the numeric block (you can change these key-functions with NUM-key!!) works!
To install this driver only copy the 2 files: KEYB.COM and KEYBOARD.SYS from your old MS-DOS 5.0 diskettes into a mounted folder(e.g. C:\DRIVER).
You can run the driver manually or write the startline in the [autoexec] part of your dosbox.conf file. The line in this case is:
C:\DRIVER\KEYB GR
"GR" stands for the GERMAN keyboard layout. You will have to find out your own keyboard layout initials if you don't want a german keyboard.
Important: If you change the NUM-Functions press the NUM-key 2 times!
Good luck!
