First post, by DracoNihil
I've been trying to get this to work just now and everytime I get ingame it either segfaults just when gameplay begins or segfaults right after a few seconds of gameplay. I'm using mainline 0.74 DosBOX from the Ubuntu repositories. I'm not trying to run the 3dFX version that GOG defaults to.
I'm running Linux Mint 17.3 Rosa and my Kernel is: 4.4.0-22-generic #40~14.04.1-Ubuntu
This is what shows up in dmesg:
[94761.353854] traps: dosbox[9662] general protection ip:7f726024bb0e sp:7ffc0baa6b28 error:0 in libm-2.19.so[7f726022d000+105000]
[95223.034879] traps: dosbox[9696] general protection ip:7f39ada38b0e sp:7ffdcf503078 error:0 in libm-2.19.so[7f39ada1a000+105000]
Here's the contents of my .conf file:
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=openglnb
autolock=true
sensitivity=100
waitonerror=true
priority=normal,normal
mapperfile=mapper-0.74.map
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=~/.dosbox/capture
memsize=63
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=dynamic
cputype=pentium_slow
cycles=auto 7800 105%
#cycles=fixed 77000
cycleup=100
cycledown=100
[mixer]
nosound=false
rate=48000
blocksize=1024
prebuffer=512
[midi]
mpu401=none
mididevice=none
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=opl3
oplemu=compat
oplrate=48000
[gus]
gus=false
gusrate=48000
gusbase=240
gusirq=5
gusdma=3
…Show last 34 lines
ultradir=X:\
[speaker]
pcspeaker=false
pcrate=48000
tandy=auto
tandyrate=44100
disney=false
[joystick]
joysticktype=4axis
timed=false
autofire=true
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=false
ems=false
umb=false
keyboardlayout=auto
[ipx]
ipx=false
[autoexec]
#mount X: ~/ULTRASND411
Unrelated but I also get segfaults while trying to play Quake under DosBOX.
― Κυνικός Δράκων
