Need help for my newly acquired 8088
First post, by Deksor
Hi, I've just bought an 8088. It comes with a 5"1/4 floppy drive and a western digital hdd (with many many more things and other PCs that I'll probably show you later in the right topic) for 50€ in total. However as you may have guessed, it doesn't POST (at least it doesn't seem to since I don't have any monitor compatible with it. I've got 16bit ISA VGA cards though). The HDD is probably making a short circuit (tantalum capacitor ?) since the psu doesn't start at all when it is plugged. But it's fine when I disconect it.
I've tried my POST card, and here is what it does :
First the POST card doesn't show any code, but apparently every voltage are fine. Then the speaker makes a clicky sound and the card shows "FF". But this is the only thing that the computer does for now.
The floppy controller had an awful VARTA battery on it, and the second ISA slot had corrosion, so I've cleaned up a bit that slot with a toothbrush and vinegar. Now it should be fine, (the motherboard doesn't seem to be damaged anywhere else, even right next to the ISA slot). What could be the problem ?
Here are some photos from the machine :
1.4 MiB
947.86 KiB
Reply 1 of 36, by Jo22
FF is a good sign, it normally means that all operations succeeded.
The ticking sound usually occures when the system is counting the memory.
The floppy controller is an multi i/o card, I suppose. Its battery could be for the real-time clock then.
But I'm speaking under correction here, I'm no XT expert (still learning about this matter).
Reply 2 of 36, by keropi
You need to find a VGA that is compatible with 8bit mode, then we'll be able to figure things further
Reply 3 of 36, by Jolaes76
Take a look at your 16bit ISA VGA cards and try to find out if you have an 8 bit compatible one among them. Use Total Hw 99, vogons topics and vintage computer forums (vcfed.org) to get some help.
If there is a 8/16 jumper on a card then you have a good chance that the card will work in your XT. Not guaranteed, though. Some 16 bit VGAs work in the 8 bit AT slot but not in an 8 bit XT slot.
A Trident 8900C card, for example, should work in your motherboard.
Edit: got ninjaed by keropi 😀
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 4 of 36, by Deksor
Okay so I tried a trident video card ... and the PC is in fact counting the RAM !
I didn't knew it worked like that in 8088s
But the next problem is : my DIN keyboard isn't detected (the BIOS says "keyboard error") and so I can't do anything ...
This motherboard is in the AT form factor. But it seems that it's not compatible with AT keyboard. Am I right ?
EDIT : oh also this PC has a turbo mode. But oddly, in that mode at some point the picture disappears completely and I have to turn the computer off, wait for some time and turn it back on to have it working again. Is the PC overclocked so fast that it crashes ? 🤣
But I'm rather thinking that the PSU is becoming old
Reply 5 of 36, by keropi
^ the keyboard error could be because of the KEYLOCK feature , put a jumper in the pins on the mobo and try again
Reply 6 of 36, by Deksor
Doesn't work 😒
It must be the keyboard standard that isn't compatible with my AT style keyboard isn't it ?
Reply 8 of 36, by Deksor
Yeah, but I don't have any of those 🙁
Isn't there a way to create that around a simple microcontroller ? Like an Atmega328p ?
So this PC is working like an XT with an AT form factor, right ? What an odd PC ^^ (and I've found another motherboard that must be the same ^^)
Reply 10 of 36, by keropi
here you go, a design based on a PIC - works great: http://www.vcfed.org/forum/showthread.php?264 … board-converter
or CarlosTex, IIRC he has some for sale
Reply 11 of 36, by Deksor
I was saying that because I have a few spare atmega328P and an arduino to program them ^^
I've found this that may be what I'm looking for http://www.vcfed.org/forum/showthread.php?445 … to-XT-converter
Reply 12 of 36, by Jo22
If the PC would at least boot from A:> without key press, you could hook it up to another PC via a serial null-modem cable.
Just make a bootable floppy and add this line to autoexec.bat
CTTY AUX
..then you could use HyperTerminal (or similar terminal program) to access your XT's DOS prompt.
It works for DOS and for text-mode programs which use the DOS API for output.
I did such things many times when I was just a little kid.. ^^
Source: http://www.easydos.com/ctty.html
Reply 13 of 36, by Deksor
Sadly it hangs on the "keyboard error". And it seems that the VARTA killed the io card (I might be able to repair it though, it not too damaged I think. And there are probably only one trace layer per side)
Reply 14 of 36, by Deksor
So on the hdd side, i've disassembled the PCB but I've not seen anything that's really special. Nothing burned, nothing blown up ... But there is absolutely a short circuit somewhere
Reply 15 of 36, by Jo22
Are the HDD cables fine ?
Reply 16 of 36, by Deksor
It doesn't even need to be plugged to the controller card.
Oh maybe you're talking about the wires coming from the inside of drive and that plugs into the pcb ? In that case, yes they are fine.
Reply 17 of 36, by Deksor
Now I cleaned a bit the io controller that had the leaky battery. When the computer is powered on, the floppy drive is spining and the controller doesn't prevent the computer to POST anymore. But it doesn't seem to be normal to me to have the floppy drive spining before the POST or without any floppy in the drive. There must be some damage left somewhere on that controller, but I don't know where. The computer seems to detect it though because it says that there is no bootable floppy inserted (so it may be able to boot even though there isn't any floppy inserted)
Here is the controller :
1.68 MiB
The chip in the middle, near the isa slot with a socket is a bit corroded. I replaced it's socket and did the best I could to clean it. It's a TIBPAL 16L8-25CN
Reply 19 of 36, by Deksor
Well this was the battery ^^
And the huge missing trace is the ground, and I checked with my multimeter, it's not disconnected
