First post, by tigrou
I wrote the following code, which is supposed to output a 60 Hz square wave to the PC speaker :
org 100h
loop:
in al, 61h
or al, 00000010b ;turn pc speaker on
out 61h, al
call _wait
in al, 61h
and al, 11111101b ;turn pc speaker off
out 61h, al
call _wait
jmp loop
_wait:
mov cx, 00h
mov dx, 411ah ;wait 16.666ms
mov ah, 86h
int 15h
ret
It can be compiled under NASM (http://www.nasm.us/) using the following command :
nasm sound.asm -o sound.com
The PC speaker is turned on/off using bit 1, as described here : http://wiki.osdev.org/PC_Speaker#The_Raw_Hardware
However, when run under DOSBOX it does not works as expected (I did not try on real hardware) :
- It only output sound for a short time, then silence. Why ?
- The sound is heavily distorted. It does not sounds at all like a 100% perfect square wave.
How can I fix this ?
Important : as stated in the OSDev page, the PC Speaker can be controlled using the PIT. However this is not what i want. I want to control the PC speaker directly by sending one and zeroes (in order to output something different than a square wave).
Reply 1 of 3, by mrau
dynamic ticks? try setting static speed?
Reply 2 of 3, by tigrou
I use the following settings :
core=normal
cputype=auto
cycles=3000
Reply 3 of 3, by tigrou
OK the problem came from the _wait procedure. Replacing it by something simpler works perfectly :
_wait:
mov cx, 10000
delay_loop:
loop delay_loop
This is of course CPU frequency dependent, but it's not a problem for what I want.
