First post, by Chryzmo
Chryzmo
Offline
Heyas,
I came across DosBox and found it interesting, plus a way to play the Ultimas on Linux 😜.
However, I installed it from source, which seemed to work. When I try to run it I get an error though:
$ dosbox
Fatal signal: Segmentation Fault (SDL Parachute Deployed)
audio_alsa: no cards found!
When I ran ./configure, it didn't give me any errors, so I assumed the install should go smoothly, whihc it did until I tried to run DosBox. I have SDL installed as well, it again noticed it in the ./configure.
Is there some kind of config file I need to edit or something like that?
Thanks,
Chris
