First post, by Cthulhus
Hi there,
My question is simple, how add basic dos defaut softwars (like MEM, DELTREE, COPY, EDIT ... ) in startup DosBox drive (Z:)
I know that I can do that in mounted drive, but I want it as default!
Thanks
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
Z:\ is a purely virtual disk. So are the applications on it. So the only way to get applications there is to code them in dosbox so they get added to Z:\
Water flows down the stream
Reply 2 of 5, by Guest
And how recode it ? Can we have for the next version and folder where is instaled DosBox where we can add software for Z ... non ? Mauvaise idée ?
Reply 3 of 5, by BastiK
You could use the mount parameter with the dosbox.exe to mount your folder with your commands as "default"
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
well mount the folder you want as Y:\
and change your path to z:\;y:\
Reply 5 of 5, by ChaosFish
I like the idea.
