awe64 - no sound
Reply 41 of 104, by dr_st
Yes, hymen.sys...
When you are solving a strange problem, you try all sorts of things. It's quite possible you are dealing with a hardware issue, but to know for sure you want to eliminate all software components that can possibly affect the environment.
Reply 42 of 104, by Robhalfordfan
dr_st wrote:
You don't need CTCM in CONFIG.SYS.
You don't need DIAGNOSE or CTCU in AUTOEXEC.BAT.
I don't think any of this should hurt, but it definitely does not help, so maybe it's best to take it out.
I took out the lines out from config and autoexec.bat and now the aweutil says awe initialization failed
Reply 43 of 104, by j^aws
Rollback, so that the AWE64 initialises. Ensure you have this file in your:
"C:\Your AWE64 directory\DRV" directory, and you should see a file called CTMIDI.DRV.
There are various versions. Ensure it is the one compatible with AWE64. There should be one somewhere in the VOGONS drivers sections.
Reply 52 of 104, by Robhalfordfan
j^aws wrote:
Have you ran CTCU - it's a utility, and verified all the AWE64 ports are available without conflicts, including EMU8000 and MIDI ports?
Yeah here a pic of the testing of audio
    2.55 MiB
Reply 56 of 104, by Robhalfordfan
The gameport test is greyed out but that set I/O range 200-207 (with no other choice available to change range) and pic is the wavetable test and the I/O range has no other choice available to change to
    2.57 MiB
Reply 58 of 104, by Robhalfordfan
Two screen shots for all sound card thing on startup, top pic is start and sec pic is end of sound card startup
    2.89 MiB
    2.88 MiB
