math coprocessor problems
General information and assistance with DOSBox.
Postby user » 2004-4-30 @ 15:49
I am trying to run some old application software on an win xp machine, dell pentium 4. It keeps saying the math coprocessor is missing. Any ideas why?
user
Re: math coprocessor problems
Postby mpainesyd » 2004-11-24 @ 06:17
I have another math coprocessor problem - I think. I am successfully running a grand old DOS database application - Open Access (nothing to do with M$) - within Dosbox on a Mac. I use Radnor to start the program. Everything looked great until I noticed that mathematical calculations were coming out wrong :(
I started Open Access built-in calculator to check its accuracy. Things then got really strange. When I press a numeric key the number appears but with 0.5 added to it. In other words if I press 1 I get 1.5 !
I realise that Dosbox was never intended for such complex applications but I guess there is a chance that it is calcuilating games parameters incorrectly as well.
Otherwise a great product.
mpainesyd
Postby Qbix » 2004-11-24 @ 08:13
please use 0.63
if you did that provide more details
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby mpainesyd » 2004-11-24 @ 09:13
I am using Radnor v1.o which has Dosbox 0.61 . I do not yet know how to update to Dosbox 0.63. I have been searching for instructions without success.
Thanks for the quick response
Mike
mpainesyd
Postby Qbix » 2004-11-24 @ 09:16
well you could try downloading dosbox0.63 for the mac from
www.holgwegner.com
(radnor uses that site as well)
and then start dosbox manually and see if it's better
We happened to have fix some coprocessor bugs in both 0.62 and 0.63
User avatar
Qbix
DOSBox Author
Postby mpainesyd » 2004-11-29 @ 04:47
Just tried 0.63 and the math bug seems to be fixed - thanks. :happy:
mpainesyd
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 0 guests
