First post, by Normandy
Hi
Hope someone can help me out with this problem.
I have tried make a game from theunderdogs work. Its a bit tricky because one has to burn a CD-rom with the game dir and start the game from a similar dir on a harddrive. Then the pesky copyprotection on this now freeware game demands thats one adds a Lastdrive=x statement one number highter then the CD drive. d:
Ive tried to play around with Dosbox and can make the CD spin up, with D-fend but it err´s with what seems to be a copy protection error. According to the guys at theunderdogs this LASTDRIVE is neccesary to bypass the ancient copyprotection.
So where if possiable do I add a LASTDRIVE=E in the Dosbox.conf file??? or elsewhere?
Thx in advance
OS: W2k, game: America invades h**p://www.the-underdogs.org/game.php?id=1284 and Ive read the README.
Reply 1 of 7, by newsdee
if it's just a variable, you can type the following at any DOS prompt:
C:\> SET LASTDRIVE = E
Or just add it under the "autoexec" section of your dosbox.conf file.
Don't panic.
Reply 2 of 7, by Normandy
Good tip and I tried it and it didnt do the trick.
I still have this error: "Illegal read from c8000033" that continuesly loops
However, is I remember my DOS correctly, the LASTDRIVE statement is suppose to come in the config.sys, not in the autoexec.bat part of a "normal" dos boot. I was hoping someone would know where to add it in the doxbox.conf file or elsewhere.
Nevertheless many thx for the effort. 😀
Reply 4 of 7, by Invader
Regarding your breakthrough, I am unable to access the Underdogs Forum. Would you please indicate what you did to get the game to work? What did you type into the autoexec portion of the dosbox config file? I'm still getting hung up at the CDROM check.
Thanks
Reply 5 of 7, by HunterZ
Just FYI, the HotU forum is down for as long as a couple more weeks because it got hacked. More info is on the main page: http://www.the-underdogs.org
Reply 6 of 7, by Guest
The forum at underdogs is still not up. I have downloaded d-fend and removed the read only attributes from all the files. I still cannot get D-day to work. Where do you put the lastdrive command? Does it matter what directory you installed the game in? Do you run the game from the cd rom or harddrive? Thanks.
Reply 7 of 7, by Fikiri
I was able to get this game to work on OS X using DOSBox .63 using a hack seen on the DOSBox Game compatibility page that bypasses the CD protection requirement. There are two parts to the hack.
1. Using a Hex Editor (I used one called HexEdit) open the file invades.exe .
Search for 000D4D7A; Change 75 to 90. Then go to 000D4D7B (the next one) and change 33 to 90. Save the file.
2. Now you must make all the files read/writeable. In OS X, do Get Info on invades.cfg Look for Ownership and Permissions, click on the details arrow and alter the permissions for all users and groups to read/write. Select each folder, do as above, and click on the "Apply to enclosed items..." button.
Now you can run the game from your HD without a CD.
