First post, by dan87951
I'm building a dual pentium pro system and my SAN ACE CPU coolers do not have 4 pin molex connectors on them, instead they use a 3 pin dedicated fan header (motherboard does not have). Does anyone know any adapters or a new wiring harness that would fit my fans? Enclosed is a picture of my fans.
Thanks
    13.71 KiB
Reply 1 of 4, by cj_reha
http://www.staples.com/C2G-6-inch-3-Pin-Fan-t … qh6QaAhhl8P8HAQ
Reply 3 of 4, by dan87951
My motherboard has a 3 pin fan power connector but its too big for the connectors on my fan. Enclosed are some pictures of the connector. The connectors on my fan are very small. Anyone know what kind of connector this is called?
    87 KiB
    134.82 KiB
Reply 4 of 4, by G1nX
It looks to me like you have a WOL (Wake on Lan) cable there. Example: http://oyvind.servehttp.com/images/PCmods%20P … r/wol_cable.jpg
You can find the adapter cable you need for your fan on later intel CPUs like P2 and P3 with stock fans. See here an example: http://www.biocomp.net/pii_350_pair.jpg
Good luck,
G1nX
Retro-gamer & VGA Collector
Powered by Voodoo5 6000
