First post, by kikenovic
To make story short, do you know of an AGP 2x card, that would work with a composite green phosphor monitor? (see attached). The plan is to use it in DOS.
Back in the late 90's I was given that monitor, first thing I tried was my NES. Heck, I even used it with my Dreamcast after my TV broke in the early 2000's. Green Crazy Taxi 🤣
    144.84 KiB
Reply 1 of 1, by Jorpho
I suppose if they were easier to find, a lot more people would be using those green or amber or monochrome monitors.
Let's start by saying that you should NOT buy one of these cables, as I have never seen any indication of a card with which they are actually compatible.
http://www.monoprice.com/product?p_id=2509
But one of these should work:
https://www.amazon.ca/Generic-Monoprice-10472 … r/dp/B001CJOLBW
If you want a card that will output composite video directly, then there are lots of those. The ATI All-in-Wonder cards come to mind; they definitely work fine in plain DOS. Depending on your needs you might want a faster card; I think you should be able to get a nice GeForce TI with composite out.
