First post, by SuperHanSolo
Hi guys
I picked up this graphics card, but i have no idea what it is. It says AGP9700TVP, but its definately not a Radeon 9700 since its using a quad flat pack GPU mounting and its got a socketed BIOS, so its much more old school. I havent been able to fire it up since its an AGP 1x/2x card, i havent got a system setup with a 1x/2x board. Googling the part numbers and such comes up with nothing.
Any clues what it might be ? Kinda looks like a matrox but not sure at all.
    1.67 MiB
Win 98 Retro PC: AMD K6-2+ @ 550mhz, Mitac 5114VU motherboard, 256MB RAM, Radeon 7000 PCI 64MB DDR
Win 95 Retro PC: Intel Pentium 233mmx, Elpina M571 motherboard, 32MB EDO RAM, Voodoo 3 2000 16MB PCI
Main PC: AMD Ryzen 7700x, 32GB DDR5-6000, Geforce 3080
Reply 2 of 11, by clueless1
FCCID gives us a manufacturer: DFI, Inc.
Using that, I googled "DFI AGP9700" and came up with this page:
http://marc.info/?l=linux-video&m=93326272828458
someone who owns this card says it's based on the Trident 3D Image 9750.
edit: removed bad link. FCC ID search page: https://www.fcc.gov/oet/ea/fccid
Use Grantee Code: E5Y Product Code: AGP9700
Reply 3 of 11, by SuperHanSolo
PhilsComputerLab wrote:
What does it show up as in DOS / Windows? What's under the heatsink?
I havent started it up yet, i didnt have a running computer with a 3.3V AGP slot at the moment.
The heatsink is attached pretty solid, i dont want to risk damaging the card since these QFP mounted chips are quite fragile.
Reply 4 of 11, by elianda
At least it looks similar: http://retronn.de/imports/hwgal/hw_trident_3dimage_9750.html
If you test it be sure to use a CRT as my 9750er didn't showed an image when a TFT was attached.
Youtube Channel
Reply 6 of 11, by SuperHanSolo
It also appears to be a 8MB SGRAM variant, which is odd cause theres nothing i can find about a 9750 with this spec.
Reply 7 of 11, by Kamerat
A bit down this page is a card similar to the one you got: http://www.yjfy.com/museum/video/Trident.htm
Doesn't reveal more information, but it's listed together with other Trident cards.
Edit: It's the only Trident card on that page with a heatsink, so prepare to be blown away by it's performance... 😜
YouTube channel
Reply 8 of 11, by Kamerat
No, it's 4MB made up of four 8Mbit chips.
YouTube channel
Reply 9 of 11, by SuperHanSolo
Ah okay I must have read the spec sheets wrong for those modules. Thanks.
Reply 10 of 11, by Tetrium
I found these links.
DFI AGP-9800 with similar (but not exactly same) layout and with either 2MB or 4MB. Comes with Trident 3DImage 9850
and
DFI AGP 9710 with a different layout, but looks to be the same age and comes with Trident 3DImage 9750 and also either 2MB or 4MB.
Both come with SGRAM.
My retro rigs (old topic)
Report spammers here!
