First post, by ENunn
My Compaq Presario 5000 US is kinda poopy when playing games. It has a 1.6 GHz Pentium 4. I upgraded the video card to a GeForce FX 5900 XT (originally it was an FX 5200). I'm not sure if its either a CPU or GPU bottleneck OR the computer is just slow. I might swap out the hard drive and reinstall Windows.
Full specs:
Full specs:
Intel Pentium 4 @ 1.6 GHz
NVIDIA GeForce FX 5900XT (originally an NVIDIA GeForce FX 5200)
Compaq 0785h Motherboard
128 MB Video Memory
512 MB DDR RAM (two 256 MB 200 MHz sticks)
WDC WD800AB-60CBA0b 74.53 GB IDE Hard Drive
3dMark2001 benchmarks are OK...I think. Not sure.
Here's a video of the benchmark:
https://www.youtube.com/watch?v=_sBrEY79ZE4
Could it just be a bottleneck or is it just a slow computer?
the
Reply 1 of 22, by mrau
the gpu is powerful, but the rest of the system lags behind
Reply 2 of 22, by Kropotkin
The Intel Pentium 4 is a bit slow.
Reply 3 of 22, by Davros
At the time the 5900 was released the fastest p4 would of been a 3ghz northwood (possibly)
Reply 4 of 22, by leileilol
The P4 you have here even bottlenecks a Geforce2 GTS. Keep looking
Reply 6 of 22, by Darkman
the card would be better with something more along the lines of a higher end Athlon.
Reply 7 of 22, by PhilsComputerLab
Using very high AA could make this card useful, but a better CPU would still be something I recommend.
Reply 8 of 22, by mr_bigmouth_502
Pentium 4s are basically useless below 2.4GHz or so.
Reply 9 of 22, by mrau
not true, i have seen an egg cooked on one of them
Reply 10 of 22, by Tetrium
It may be interesting if it's a s423 with Rambus though.
Not very efficient, but still interesting in a way.
My retro rigs (old topic)
Report spammers here!
Reply 11 of 22, by agent_x007
I think first CPU that utilises Northwood core is Pentium 4 2,0A (for PGA 478).
Reply 12 of 22, by SPBHM
not sure about the first, but the P4 1.6GHz Northwood was a thing and it was very popular for OC, I never heard of anyone failing to reach 2.4GHz with it.
P4 1.6GHz is more Geforce 3 ti territory than Geforce FX, but it all depends on what you expect, if you are going to run older games at very high res it might be a solid choice,
Reply 13 of 22, by Standard Def Steve
Based on that Youtube video showing 3DMark performance, I'm guessing it's a Willamette. 😜
"A little sign-in here, a touch of WiFi there..."
Reply 14 of 22, by swaaye
Good card for 1600x1200 with old games. CPU will get the job done.
Reply 15 of 22, by Carlos S. M.
Probably, i could crank around 8700 3DMarks using an 1.5 Ghz P4 Willamette, RAMBUS and a Geforce 7600GT AGP
Reply 16 of 22, by Rhuwyn
I've got a 5000 series myself with a 1.6 P4. I have a hard time not having at least dual cores for Windows XP and newer. This system is dirt slow with all the updates. I am thinking of just putting a Geforce 2 MX in it and selling it as a High end Windows 98 or 2000 machine. Anything newer then a Geforce 3 or a Geforce 4 MX would be a complete waste.
Reply 17 of 22, by Putas
ENunn wrote:
Will X have a bottleneck with a Y or vice-versa?
These questions are meaningless when we don't know what you will do with it.
Reply 18 of 22, by Jade Falcon
Rank BANNED
BANNED
The cpu will definitely hold the card back. How much of a bottleneck you see depends on what your doing.
If your playing a have like quake3 or ut99 and older it will be fine.
Try to play a newer game like doom 3 then your have problems
Reply 19 of 22, by Tetrium
For older rigs running with XP I typically don't bother going beyond, say, SP2 and often I'll use a slipstreamed version which is tweaked for better performance on slower rigs.
