First post, by sf78
I didn't want to bump the 2-3 year old thread about overkill systems, but I ran into similar problems with H-L. I have a P3/128MB/Voodoo3 PCI and the frame rate seems to be all over the place. At quiet scenes it might be around 130-170 fps and in battle scenes with lots of explosions and enemies it might slow down to 30-35 fps and stutter. Any thoughts on this? The game is versio 1.0 and GPU drivers are official 3fx from Nov 2000, I also use DX6 and the resolution is 1024x768. Was this a common thing with official drivers? I remember playing H-L when it first came out with K6-2 and Voodoo 2 and it didn't seem this bad. I did install WickedGL to see if it makes a difference, but I haven't run into a major battle yet.
Reply 1 of 18, by Ampera
Of course the FPS will slow down in intense scenes. That happened since the dawn of computing. Even today, an intense scene with lots of effects and geometry can slow a card down. It's normal.
Try to enable VSync, or if it really gets an issue, cap the FPS to 30 or 35 if you are that annoyed by it.
Personally I don't see screen tearing and stuttering as much, but some do.
Reply 3 of 18, by F2bnp
How fast is your Pentium III? The Voodoo3 should be plenty fast to hit above 60fps most of the time, but Half-Life can be remarkably heavy on the CPU. Pentium III 500 won't cut it for example and will often go into the 30s like in your case.
Reply 4 of 18, by sf78
Sonofa...I took the wrong case! It's the PII that I was running, bastards used the same case for both Pentiums. Now I need to find where the P3 is lurking.... Thanks for asking, I never thought of checking the CPU as I was sure this was the correct one as it had V3 installed and the V2 was supposed to be in the PII which it cleary wasn't. 😵
    203.32 KiB
Reply 6 of 18, by SPBHM
I've played a fair amount of HL on my PII400 with a voodoo 4 4500 in glide and it does struggle a bit, CPU is definitely a limiting factor, even with a P3 you are likely to see FPS drops related to the CPU,
Reply 7 of 18, by Deksor
tgod wrote:
Here's an old half-life tweak guide made for voodoo 2's in mind, it might help.
http://www.play-half-life.de/Main1.html
Excuse me to "steal" that thread, I just have a small question :
I've got an SLI of voodoo 2 on a pentium 2 400 (overclocked to 448MHz) and I tried these commands on half life but it didn't seem to change anything. In fact I don't know if those commands actually worked since when I type them, the game says "player : gl_texsort(0)" and does'nt say anything else" How do I use these commands ?
Please note that I'm using the 1.0 version (yep, retail version !)
Reply 8 of 18, by tgod
You have the console enabled right? Simply typing gl_texsort in there will tell if if the command is valid since half life will reply with something like "gl_textsort is 1"
It also looked liked you typed the parenthesis, don't need those. Just "gl_texsort 1" to change the value. Not all the commands in that guide work depending on the version of the game you use, so just move to the next one then.
Reply 9 of 18, by Deksor
okay, the tutorial wasn't really clear on the syntax, like I said, I litteraly typed "gl_texsort1(0)"
Allright, so these settings were already set to the best options for voodoo 2s ...
Anyways that computer isn't finished, once I'll find the right motherboard, I will be able to overclock that CPU to 533 (at least, if it wants to co-operate ...). Sure I could use a pentium 3 made for that speed, but this is a special build ^^
Thank you very munch !
Reply 10 of 18, by FFXIhealer
This is why I've been badging all of my systems up. Check it out:
4.47 MiB
Extra case badges
3.96 MiB
E-Machines, Windows 10 64-bit, Core 2 Duo E7300, 4GB DDR3-1066, 500GB HDD
4.05 MiB
Windows 98 FE, Pentium-3 "Katmai" 600Mhz, 256MB 100MHz SDRAM, 40GB HDD, Viper V770 TNT2 32MB AGP, 2x Voodoo2 12MB SLI
4.19 MiB
Windows 10 64-bit, Core i7-6700K "Skylake", 16GB DDR4-3200, 256GB SM950 m.2 SSD, 1TB 850 EVO SSD, 3TB HDD, GeForce GTX 980ti
4.4 MiB
Samsung Netbook, Windows 10 32-bit, Atom N450 "Pineview" 1.6GHz, 2GB DDR3-800, 256GB Crucial SSD
Reply 11 of 18, by sf78
Yes, but the IBM already did it. Too bad they put the stickers in the lower right corner and I didn't bother to look that closely. I usually just use a piece of masking tape on top of the case for specs as I tend to swap out parts quite often. I did find my P3 tower, but it had XP installed so I didn't bother with it. Still, interesting to see it's such a demanding game.
Reply 12 of 18, by PhilsComputerLab
These old 3D games are often a lot more demanding than imagined / memory tricks us 😀
With Half-Life I think it's mostly the CPU that needs beefing up a bit.
If you have a Slot 1 machine, that's easy, so many options. With Super Socket 7 not so much. There is only so much even a K6-III can do.
YouTube, Facebook, Website
Reply 13 of 18, by FFXIhealer
There's Phil. Hey Phil, I got MS-DOS 7 working in Upper Memory (Windows 95 system). I've been watching some of your videos on YouTube. Good stuff there.
Reply 14 of 18, by PhilsComputerLab
Nice 😊
Reply 15 of 18, by leileilol
With the V3 don't use the 3dfx Mini Driver that HL provides. 3dfx has a more mature ICD installed for the V3 and will work with the "default" setting.
Same advice applies to Quake2 and licensees. Don't use "3dfx OpenGL" for Voodoo3!
long live PCem
Reply 16 of 18, by sf78
I think I tried that already, the WickedGL patch did seem to make a difference though. The reason I remember H-L running pretty well was that V2 only used 800x600 resolution so that probably helped too, even though in theory PII should be slightly faster than the K6-2 we had back then. Anyway, thanks for the input, I'm already at later stages of the game so it's all good.
Reply 17 of 18, by FFXIhealer
🤣 Back on my Pentium II system, I ran ALL my games at 800 x 600 unless I was forced down to 640 x 480 (Final Fantasy 7/8, NES/SNES ROMs, etc).
Reply 18 of 18, by candle_86
FFXIhealer wrote:
This is why I've been badging all of my systems up. Check it out: […]
where can one find a Windows ME case badge, i can't find any
