First post, by Crush
I get this soon as I start a ground mission. Any idea what causes this?
Also, I cant seem to enlarge the Dosbox window and when I go full screen, I get a black screen and DOSBox crashes...
Reply 1 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
you use core=dynamic. So you are on your own. Dont 't bother.
Water flows down the stream
Reply 2 of 9, by Crush
Dont bother using fullscreen? 🤣 I guess I dont mind as long as I can still play.
Reply 3 of 9, by wd
Rank DOSBox Author
DOSBox Author
duh......
Reply 4 of 9, by Crush
Thanks WD, ya been hepful...
Reply 5 of 9, by eL_PuSHeR
Stop using dynamic core. It's still very experimental. Use normal core for games/apps where you get the overrrun.
Reply 6 of 9, by Crush
Already stopped. Everything's running fine now. 😀
Thanks
Reply 7 of 9, by wd
Rank DOSBox Author
DOSBox Author
i hope in fullscreen 😉
Reply 8 of 9, by Crush
'fraid not. Still get the Black Screen of Death and I have use task manager to crash DOSBox 🙁
Reply 9 of 9, by Crush
By the way, DOSBox is indeed a strole of genius and a Godsend. I got a *ton* of old DOS games that I couldn't run before DOSBox.
I had gone searching for a DOS emulator in the hopes of being able to play X-COM again and DOSBox was the first to pop up so I said, what the heck, give it a try.
The one game that I *knew* DOSBox wouldn't be able to run perfectly was Megatraveller2. I just *knew* I wouldn't get the sound or that piece of music that plays during the character generation process.
To my total surprise DOSBox set up and ran the game perfectly.
Mechwarrior 1 was another problem child that DOSBox ran perfectly.
I have no doubt it could run Privateer if the game would only recognize the CD drive 🙁
Awesome job DOSBox crew!
