Best Drivers for GeForce4 MX-440
Reply 80 of 88, by mockingbird
VirtuaIceMan wrote on 2022-03-01, 14:08:
I'm not really an electronics kinda person. Is it highly likely to be capacitors?
I think we've got a soldiering iron but don't think I have any testing gear, what would be needed? Multimeter or something? I'm more tempted to get a refund as seller said it's working (but they also said no returns)
No, don't try it if you've no experience... Replacing capacitors takes skill on these boards because clearing the holes isn't as easy as it is on single layer phenolic PCBs... You would also need good replacements.
Nah I wouldn't bother with a refund, that's not going to help you... These cards go for next to nothing, expect to re-cap them when you receive them (and service the fan, for that matter).
(Decommissioned:)
Reply 81 of 88, by VirtuaIceMan
The one I got has a big heat sink on instead of a fan and looks brand new on the board.
Reply 82 of 88, by mockingbird
This one?
906.07 KiB
You need to find a friend with a Hakko desoldering pump, get the old caps out, and put something like Panasonic FR series in there, or good 5,000 hour polymers (Panasonic SEPx).
(Decommissioned:)
Reply 83 of 88, by VirtuaIceMan
Yeah that's it, looks like the board is in good condition though. I have no friends like that 😒
I was hoping it might be something less hardware, like the drivers being too old for DX9 or something. I'll investigate drivers later.
Most of the games I want to run (on PowerVR) work though, my more annoying issue is no CD-audio at the moment: Topic 86631
Reply 84 of 88, by The Serpent Rider
mockingbird wrote:
There are significant enough changes in the silicon (NV17 vs NV18, NV25 vs NV28).
I stand corrected, the earliest version for support for NV18 and NV28 is 40.71. But the point still stands, if you try anything earlier it won't work.
Again, incorrect. And that's why the "8x" versions of GeForce4 are not a good choice for older builds.
45.4 KiB
Nuff said.
Reply 85 of 88, by mockingbird
The Serpent Rider wrote on 2022-03-01, 17:47:
Nuff said.
Sir, respectfully, I did test this myself, albeit with an earlier driver version... You are testing with a Ti4200 though, not an MX440-8X.
That said, I stand corrected again, it seems (at least on the Ti4200 8x - NV28).
I'll look into it again -- NV18 that is (GeForce MX440 8x).
(Decommissioned:)
Reply 86 of 88, by VirtuaIceMan
I'm pretty sure it's not the caps now, I booted into WinXP on another drive and the DxDiag DX9.0a Direct3D tests all ran fine. Something's up in Win98SE...
Reply 87 of 88, by mockingbird
Nuff said.
Sir, I just went to perform my testing, took out my Ti4200-8x and MX440-8x, then I got to looking at the 31.40 NVAML.INF to add my device ID...
The 31.40 already has explicit support for the 8x series of cards... That's not what we're discussing. We're discussing modifying the 28.32 to work on the Geforce4-8x series.
To recap, you said the following:
The Serpent Rider wrote on 2022-01-28, 15:34:
They are not similar. They are identical.
I responded with:
mockingbird wrote on 2022-03-01, 00:53:
Incorrect.
I have both. The oldest driver (28.32 - the earliest GeForce4 driver) cannot talk to the MX440-8X. There are significant enough changes in the silicon (NV17 vs NV18, NV25 vs NV28).
Yes, I was wrong about the earliest driver revision for the 8x cards, it starts with the 3x.xx detonators (I stated 4x.xx detonators), but they are not identical, as you state.
The 28.32 detonators will not work on the 8x series Geforce 4 cards.
(Decommissioned:)
Reply 88 of 88, by The Serpent Rider
*yawn*
it's very similar to the AGP8x MX440, but it was launched a while after so driver compatibility (with old versions) is a little worse I think
Well yeah, I missed one part - it works with PCI cards or probably without GART driver installed (aka PCI66 mode). Nevertheless you still can install most crucial parts - DirectDraw/Direct3D and OpenGL libraries from 28.32 and it will work.
1.63 MiB
