First post, by melbar
I have one question to the compatibility of these two VGA coolers from Arctic Cooling:
  • -Arctic Cooling NV Silencer 1
    -Arctic Cooling NV Silencer 6
According to the specifications, they are both compatible with FX5700.
The NV Silencer 1 is also officially compatible with Geforce 4 Ti.
The NV Silencer 6 is also officially compatible with Geforce 6200 PCIe, 6600 PCIe and 6600GT PCIe versions.
For the question is:
Is it possible that NV Silencer 6 is also working on GF4 Ti, especially on the GF4 Ti4400/4600/4800 version?
Here is also a compatible list...
http://www.cdrinfo.com/Sections/Reviews/Speci … ArticleId=14694
    35.4 KiB
    90.24 KiB
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 1 of 5, by MrMateczko
This is NV Silencer 1:
This is NV Silencer 6:
Looking at a sample TI4400, it has two different mounting systems, either two yellow screws, or four red screws:
Now take a look at the FX5700:
For me, the spacing of the yellow holes on FX5700 and Ti4400 look the same, so it should fit.
Reply 2 of 5, by firage
The two coolers don't look like they fit the same cards, but the GeForce4 may be compatible with both with its extra mounting holes.
The GFFX 5700 comes in a variety of different configurations it looks like, and the PCIe cards have extra holes similar to the above pic of a GF4.
My big-red-switch 486
Reply 3 of 5, by melbar
@MrMateczko
Ok, thanks for your pictures. Seems that both coolers can fit on Geforce 4 Ti.
I've measured the two diagonal holes with ~80mm (3.1496 inch). Actually now, i have both cards, a FX5700 and a Ti4800SE.
(Cause the FX5700 is not of interest for me, i want to sell the Leadtek Winfast A360.)
Previously, i was thinking to mount the NV silencer 6 onto the FX5700. Now i have check both original coolers, they are both really loud.
But there seems to be only one problem - mounting the NV silencer 6 onto the GF4-Ti:
The chipset itself looks different between GF4-Ti and GF-FX5700.
The GF4- Ti has a wide chip with constant height. The FX5700 chip has a smaller chip which has more height.
It might be a problem with the 4 black "bumpers" on the copper plate.
I think, to cut them into half parts should solve this...
Reply 4 of 5, by melbar
Anybody here, who knows something about the Arctic Cooling Accelero X1?
How can it be compared the X1 against the Silencer NV 5?
Reply 5 of 5, by MrMateczko
It's widely reviewed on the internet. Basically, it's big and it's good. Here's the back shot:
It's designed mainly for 6800/7800 PCI-E. Not sure about how it compares to the Silencer 5, but probably is slightly better, as it is a newer product.
