First post, by keropi
Hiya!
I am looking for a BIOS with the English fonts for this VGA:
Mine has Greek fonts that replace some of the special characters and this doesn't work well for me since if I need Greek support (almost never) I can load a TSR ...
If anyone can help please dump the roms 😎 , thanks!
Reply 3 of 10, by QBiN
Keropi,
I think you may be in luck. My card appears to be a WDC reference card because yours looks like an identical OEM as far as I can tell. The ONLY difference I see is that mine leaves off the oscillator crystal yours has. Our cards even name the BIOS sockets the same U-number.
2.3 MiB
WDC reference 90C30
In the ZIP I've named the binary dump files according to their corresponding socket numbers. The dumps were taken on a MiniPro reader using v6.10 of the MiniPro software. The chips on mine are 27C256 ROM's no different than yours. So you should no issue burning them.
    WDC-90C30-ROMs.zip
    22.43 KiB
    127 downloads
Reply 4 of 10, by keropi
I just tried the new new BIOS and it works fine - no more Greek characters embedded , thanks QBiN!!!
Reply 6 of 10, by keropi
yeah! and these are really fast cards and without the TSENG issues. But I am not sure they have a RAMDAC that supports more than 8bit color depth.
Reply 7 of 10, by dosgamer
Thanks QBIN! I have that exact same card here with the ROM chips missing!
Coppermine Celeron 800 @ 1.12GHz (8x140) - Asus P2B Rev. 1.12 - 256MB PC133 CL2 - Voodoo5 5500 AGP - SB AWE64 CT4520 - Roland SCC-1 - Intel Pro/1000GT - 1.44MB Floppy - ATAPI ZIP 100 - 120GB IDE - DVD-ROM - DVD-R/RW/RAM - Win98SE
Reply 9 of 10, by keropi
^ I have 2 different WD90C30-LR cards, under win3x none supports more than 256 colors. At first I thought maybe this was a driver issue or something but it seems now there is confirmation... tbh I didn't think to look for the ramdac datasheet 🤣 🤣 🤣
It makes me wonder what the whole point of 1MB VRAM really is
Reply 10 of 10, by dosgamer
Well, my Dell 486 also has a WD90C30 onboard, and that one uses a HiColor RAMDAC (SC11483CV, datasheet: http://datasheet.datasheetarchive.com/origina … DSAP0025504.pdf
