First post, by snorg
So I finally managed to find one of these and picked it up but when it arrived, it turned out to be an external break-out box and not the internal bay. It's about the same size so it was very difficult to tell from the photo. It actually looks like it would still fit in a 5.25" drive bay but of course I have no cable to go from the rear over to the SB Audigy, as the one that came with it is a thick external cable (I didn't realize there was an Audigy model with an external output/connector on the rear of the card?).
So what I'm wondering is: would it be possible to take off the external housing on the breakout box, put it in a drive bay and cobble a cable together to reach my Audigy card? I haven't done it yet but it looks like the external cover is only held on by 4 screws. l have been looking for one of these for a while and had hoped this would complete the search.
Reply 1 of 17, by firage
You probably mean the external Audigy Drive that came with the Audigy Platinum eX?
I have wondered what they look like inside. Could just be an Audigy Drive with very little added on at the rear. It came with a fairly simple looking Extension Card for the external cable. (http://www.karbosguide.com/books/videosound/images/990.JPG)
The first generation Audigy Drives were Live Drive IR's with new faceplates; the PCB is the same with some extra internal headers left off. Audigy 2's had new Drives with different cable pinouts.
My big-red-switch 486
Reply 2 of 17, by Errius
This confused me as well. I think this is correct:
Audigy 2 ZS - Card alone
Audigy 2 ZS Platinum – Card with I/O Drive and remote control
Audigy 2 ZS Platinum Pro - Card with External I/O Hub and remote control
"AI Requires Proof That You Are Human"
Reply 3 of 17, by snorg
firage wrote:
You probably mean the external Audigy Drive that came with the Audigy Platinum eX? […]
Yep, that's it for sure. I may just cut my losses and try and sell it on eBay,
I take it it's useless without the interface card.
Reply 4 of 17, by gdjacobs
Yes, it's a unique interface for the Platinum Pro.
You can sell it on or keep it and get the associated card (which is pretty awesome). Ultimately, it's your choice which way to go.
Reply 5 of 17, by firage
I would bet there is very possibly a regular Audigy Drive inside that external casing, because I have one of these black faceplates and they're interchangeable. The screws appear to be in the right spots, too. Regardless, it'll definitely be easier to find an Audigy Drive bundled with its internal cable than try to source the cable by itself.
Reply 6 of 17, by Errius
Apparently having this box outside of the computer improves sound quality. That's why it's the premium "pro" product. I'd like to know if there's actually a basis to this.
Reply 7 of 17, by gdjacobs
Depends if the internal box has all around shielding and how effective noise suppression on the analog lines and power rails is (although this should be roughly equal between the two boxes).
Reply 8 of 17, by yawetaG
Well, almost all current professional audio interfaces are external for that precise reason, so there should be some truth to it.
Reply 9 of 17, by firage
Professional audio interfaces are external mostly because they need a lot of room for inputs and outputs, and/or compatibility with laptop computers is a big selling point. People's fear of EMI is a minor factor.
USB is typically still feeding external boxes dirty power, which is probably the biggest issue next to ground loops.
Reply 10 of 17, by yawetaG
Dunno, there are internal sound interfaces available with either truly massive breakout cables/boxes or expansion "cards" that simply take up another slot and that add more in/outputs, yet people generally seem to prefer external interfaces even in a studio with lots of immovable audio gear.
Reply 11 of 17, by firage
The large channel counts are limited to digital I/O only, as far as I know, which means they require separate analog units. For example, RME only offers four analog input or output channels per PCIe card, so four cards (if they even support stacking that many) to match one half-rack interface. They couldn't put preamps on those cards either.
Since racks of external gear are the rule in a professional setting, internal interfaces are understandably pretty niche. This is regardless of any noise inside the machine that couldn't be isolated out.
Just taking the interface outside of the PC isn't enough to fix problems of low quality design. The $149.99 list price E-MU 1212M PCI achieved cleaner line quality a decade ago than all of the external pro-sumer crap out today.
Reply 12 of 17, by hard1k
Doesn't it use just a regular 40-pin flat cable like the ones for IDE?.. I've replaced quite a while with the usual IDE cables and everything was OK.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 13 of 17, by firage
Good to know it works - for some reason, there are warnings and reports of mixed success with IDE cables. Shouldn't be a problem as the header pinouts match 1-for-1 at both ends, as long the IDE cable has all the pins available (nothing blocked). I guess the key thing is to get the orientation right the first time with this one. 😀
ATA/66+ cables do something funky with pin 34, so probably avoid those. Also, stick with a single connector or the master, as slave connectors might not connect pin 28.
Reply 14 of 17, by RJDog
You will almost definitely want to use a 40-conductor cable, not a 80-conductor cable like is found in newer IDE cables. The 80 conductor cables have every other conductor tied to ground, which ends up meaning (in most cables) that some "ground" pins are tied to other "ground" pins, which might not be actually "ground" pins to the Audigy box, thereby screwing things up. That, and ensuring the right polarity as you said.
Reply 15 of 17, by darry
I currently have 2 X-FI SB0460 cards that are hooked up to "drives" using 40 conductor cables without issues .
One of them is hooked up to a an X-FI drive and the the other an Audigy 2 ZS drive . The pinout for the AD_EXT connector is the same for these (the Audigy 2 ZS drive has an additional firewire header that remains unused with an X-FI card).
See this thread also :
Correct I/O Breakout Drive box for SoundBlaster Audigy2ZS Platinums?
I am pretty sure the original SB Live and first generation Audigy (before version 2) have interchangeable "drives", but I have never tried one myself (with a drive).
Good luck .
Reply 16 of 17, by cyberluke
Hi, I just bought Audigy 2 ZS Platinum Pro with two cables and two external units and remote controller: https://www.ebay.com/itm/196427890796
I got sound in headphones from the rear port, but there is no way I can get the external bay working. The power LED is off and even with remote control cannot turn it on (replaced CR2032 battery). As I have two cables and two external units I don't want to believe that both would be faulty.
Do you know if this behavior is normal? I don' know how to turn it on and use optical output. THANK YOU
Reply 17 of 17, by chinny22
Which card do you have? Is it the SB0360 with the special port on the back? (you can see it between the firewire and audio jack in the picture in this article)
https://www.soundonsound.com/reviews/creative … abs-audigy-2-zs
Power is done over the firewire port.
