System Shock CD from GOG
First post, by .legaCy
Okay i purchased it on GOG and i have it installed in my main pc, but i wanna throw it in my retro pc i noticed it contains one image in bin extension and the cmdline for mount on dosbox config ends with -t iso
But none of my softwares available to handle iso cd images could open or mount it.
how can i burn one cd to install on my retro pc?
Reply 1 of 5, by Jorpho
Which programs have you tried, and which file were you trying to open?
Reply 2 of 5, by PhilsComputerLab
When I burnt my disc, it was 100% a plain ISO. That was last year though.
Reply 3 of 5, by .legaCy
MagicISO,Now i noticed that WinRAR opened it fine,.
Reply 4 of 5, by clueless1
A couple of things to try:
-use AnyBurn and try to burn it to CD as-is.
-rename .bin to .iso and try to burn it.
I believe option 1 will work, but I can't remember for sure.
EDIT: for future reference -
Digital DOS games (GOG, Steam...) Retro PC Compatibility Sheet: We need your input!
Reply 5 of 5, by .legaCy
clueless1 wrote:
A couple of things to try: -use AnyBurn and try to burn it to CD as-is. -rename .bin to .iso and try to burn it. […]
Thank you so much, that solved my issue.
