ATC-5030 no POST. Now fixed :D
First post, by Deksor
I just got that board locally with another no-name vx board (this one is a TX board and it seems very nice). The VX board is fine (I got another VX from the same place few month ago) but this one doesn't POST at all ... It came with a 6x86MX chip which had a missing pin. There is some green residue on the CPU and on the socket so I thought it might be corroded but I looked through the holes and the pins inside the socket were shining ... I also tried both AT and ATX psu, but still nothing ...
I used a pmmx 200 in order to make sure that the missing pin on the 6x86 wasn't preventing the board to start, but it didn't help. I think that few days ago the keyboard's light were getting on and then off but now it doesn't do that anymore ... Also few days ago, it outputed a POST code in the PCI and ISA slot, but I didn't check that again, the code wasn't changing though. It was stuck to the same value (can't remember what it was but I don't think that would be useful)
I don't know what to do now, this board looked so good 🙁
Oh and why did I mention the VX chipset earlier ? Because trough all the socket 7 motherboards I own only VX board are alive for some reason 🤣 anything else seems completely dead ... Ali, HX and now TX ... I now have three VX boards, but all I want is a better motherboard, not the exact same thing 🙁
I thought about removing the moving part of the socket (I don't know how to do that without destroying everything though) to check further if really it hasn't been damaged. I'll reflash the bios too in order to verify if it's just a bad flash/an old virus
Reply 2 of 24, by Deksor
The battery was already missing when I got it ... 🙁
I'll look to reflash the BIOS tomorrow
Reply 3 of 24, by Tetrium
Could you please post some pics of your board and of the missing pins of your CPU?
Basically pics of everything that may be significant. For all we know it may even be as trivial as a misplaced jumper 😀
My retro rigs (old topic)
Report spammers here!
Reply 4 of 24, by Deksor
Sure, I didn't make any picture because it was late X)
So here they are
834.35 KiB
My test bench (or should I say, my test chair)
461.17 KiB
A closer view
603.32 KiB
709.14 KiB
The poor 6x86
692.86 KiB
And finally the socket.
Apparently this board autodetects which voltage and which multiplier the CPU needs so the only thing I can change here is the FSB ... I don't think that it is a misplaced jumper issue ...
The board itself is in a great shape
Reply 5 of 24, by Deksor
Okay so I used the POST card and it displayed "F0"
I wanted to flash the bios using the hostwap technique ... using another ATC motherboard which I don't use at the moment. It's a 6150 model. But once I powered that board, guess what ? The POST card displayed "F0" too ! I have no idea why it's not working now, it was fine last time I used it ... At some point this board POSTed, but I had a problem with my floppy cable and once I replaced it, it re-displayed "F0" and didn't POST at all 🙁 I tried to move the CPU in it's slot, but no, nothing woke up that board again. The CPU fan isn't moving at all when the board does than
On the 5030 board I measured the voltage coming from the two VRMs. The left one was displaying 0v and the right one was displaying 2.3-2.4volts. I have no clue if those are correct values, but it make me think that there may be some dead VRM here, or that my guess on the socket is right and so that the CPU isn't correctly detected
Both board are using award bioses apparently
Reply 6 of 24, by meljor
I have the ATC 5030 board and it is great. It was in my ''pentium1 with voodoo1'' system and was stable and quick and easy to deal with. I mainly use Asus in my systems now so i tossed it for the Asus TX97
but the Atrend board was just as good.
I now use it for hotflashing bios chips 🤣 And yes, it uses an Award bios.
Is your psu ok? Because 2 dead boards with the same problem is weird. Also the cyrix cpu seems a bit black underneath and that is usually not a good sign (and it might have hurt the board too).
BTW on paper the TX is better but in practice you will probably not notice a difference. Vx boards are fine.
Reply 7 of 24, by Deksor
The dark coloration is just a piece of paper which might have been wet for a while during it's life.
I thought about the PSU, but I couldn't verify it's working order at the moment. One thing to mention : the VX board I got worked with the same PSU and I tried the 5030 with an ATX psu and it didn't help either. I didn't try the ATX psu with the 6150 though
Something really odd is going on there I guess ...
I just want to try something different than VX, but all I can get working is VX chipsets 🤣
This is also the only socket 7 board that I own that has the SB_Link connector. I know, I can just stick with ISA slot, but I'm still finding it a good thing to have
Reply 8 of 24, by Tetrium
If I looked correctly, your Cyrix 6x86 is missing pin Y1 which should be VCC (non-critical)
I used this and this, but would prefer someone with more knowledge to have another look if there may be a good reason to do so.
That Cyrix does look kinda dark underneath. It may have been fried? Those Cyrix's tended to run very hot, it may have burned up if the CPU fan stopped working at one time and this may have damaged the motherboard.
Reply 9 of 24, by Deksor
I made a quick test with the 6x86MX in the VX board and it does work ! The cooler I had with it had no fan, but I can see some damages in each corner that have probably been made by screws which means that at some point there was one.
For the slot 1 I found the problem : apparently it didn't like the POST card in the PCI slot. When I removed it it booted perfectly. Once I put it back, it didn't work again. Using it in an ISA slot solve the problem.
I hoped that that was the same problem on my 5030, but it's not 🙁
Reply 10 of 24, by Deksor
Does somebody know hop to remove safely the moving part of the socket ? I'd like to take a look inside it without damaging it
Reply 11 of 24, by Tetrium
I have done this years ago when I replaced a broken lever (I cannibalized another lever from a broken board) and I ended up using a flatbed screwdriver to carefully unlatch the top of the CPU socket, replace the lever and click it back.
But it's very easy to break something and I actually ended up breaking the socket of the already broken board (I used it to practice).
I only did this repairjob once though. I'd be hesitant to recommend to remove the moving part of the socket just to take a look inside.
Can't you just use a small bright light to have a look inside? When the socket is slid open you should be able to see through the holes right?
Reply 12 of 24, by Deksor
Well like I said, I didn't notice any damages through the holes, but I'd like to have a better look inside ...
Though the Cyrix being a power hungry CPU, maybe it just burned the VRMs since I measured 0v on one of them. But I'm not sure if it's the normal behavior of the board or not and since it's locked up to some step, it doesn't power on that VRM. Shouldn't cost me a lot of money and time trying to replace it though. On all my pentium motheboards, I've always seen one of the two VRMs (and that was always the left one) getting super hot. On this board, the VRMs are only cooled by the PCB, so yeah, maybe the CPU cooked the left one (which is the one that gives 0v)
I don't know how I could test the working order of that VRM though
Reply 13 of 24, by Deksor
So I just powered it on another time, and I felt that the CPU was getting warm, so this can't be a dead VRM issue, right ?
I also removed the moving part of the socket and I didn't see anything wrong.
I'll try to reflash the BIOS like I said (I still haven't done that right now), but yeah ... I think that unfortunately it's dead and it can't be repaired 😢
Reply 14 of 24, by Deksor
So today I finaly decided to reflash the BIOS, and this happened :
797.07 KiB
IT WORKS !!!!
I knew that this could fix boards, but I never thought I would have a board with a dead bios. I tried not really believing that this would fix it, but apparently it worked !
I'm not cursed anymore 🤣
According to uniflash, the original rom says "unknown" so I think it's just a toasted chip and not the result of a virus
Reply 15 of 24, by Tetrium
Niiice!
Now go have some fun with it and keep us informed! 😁
For all we know the board was bricked by its previous owner who tried to flash it 🤣!
Reply 16 of 24, by Deksor
I don't think it was bricked by the previous owner because like I said when I tried to reflash the original bios chip, uniflash couldn't determine it's type so the bios chip is probably just dead.
I don't care for that little chip, they are not as hard to find as a working pentium board with better chipset than VX 🤣
Here are the results of speedsys with the pentium mmx :
945.31 KiB
I tried the Cyrix 6x86MX that came with this board but oddly, it gets stuck at some point when speedsys is checking stuff.
Also for the missing pin, this is really odd because when you look at it, you can see that there was something there, but you can't see any remain or trace, just like it was just glued on the ceramic and wasn't really used for anything 🤣
892.44 KiB
Reply 17 of 24, by meljor
I noticed that!
Like... @Cyrix : '' damn, we forgot a pin! Oh, no worries, we glue one in and no one will ever notice.....''
Looks really strange...
Good to hear you got the board working, it really is a good board. You will like it.
Reply 18 of 24, by lazibayer
Deksor wrote:
So today I finaly decided to reflash the BIOS, and this happened : […]
IT WORKS !!!!
Big congrats!
I assume you reprogrammed with a new chip?
The previous owner/scraper might have reused the original BIOS chip for other boards and filled the socket on this board with a dud.
Reply 19 of 24, by Deksor
Hm now that I'm trying to install windows, something odd is happening 🙁
The hdd is detected correctly through the bios and fdisk sees it, but when I create a partition and that I reboot, the partition is gone ... I tried with 3 hdds and 2 ide cables and it still does the same thing. On the other hand the CD drives are working
I can use an IDE controller, but that's still unfortunate. Maybe running the CPU at the 83.3 fsb (required by Cyrix) during all it's previous life did hurt the chipset a little bit
