First post, by Guest
I just downloaded DosBox 0.61, and I'm running it on WinXP Pro. Amazing program by the way!
My problem is when I toggle to fullscreen mode, I lose the bottom fourth or so of the screen. Like the text literally runs off the bottom of the screen. If I try and run a game, it runs fine, but same, the bottom fourth of the screen is cut off.
I can see the whole screen properly in windowed mode, but I'd really like to play games full screen.
Does anyone know what I might be able to do to fix this problem?
Thanks,
-Rob
Reply 1 of 2, by Guest
Play with the buttons on your monitor, I hope its something more complicated than that.
Reply 2 of 2, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
The position of the picture on the monitor screen depends on resolution and frequency. So it is normal that it is necessary to play with the monitor after a different resolution is set.
Mirek
