First post, by Oldskoolmaniac
Im trying to get windows ME going and I cant install the revolutions pack, it says I need the GDI+ runtime. Where do I find that? Ive tried the patches from MDGx and still nothing, maybe im grabbing the wrong thing?
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 1 of 6, by Jorpho
We can't very well know if you don't say what specific things you've grabbed, now can we..?
Reply 2 of 6, by notsofossil
Use this to keep track of what support files you are missing.
http://kernelex.sourceforge.net/wiki/Help:Contents
GDI+ is mentioned on there.
Thinkpad T42 Win9x Drivers | Latitude D600 Win9x Drivers
Next: Dell Inspiron 8000
Reply 3 of 6, by Oldskoolmaniac
I put the dll in the system folder like it says on wiki and I still get this error.
    17.87 KiB
Reply 4 of 6, by candle_86
Try this on the GDI DLL
Regsvr32.exe allows you to register/un-register DLL and OCX files that are self-registerable. Regsvr32.exe provides rudimentary error codes as well as a silent install option.
Regsvr32.exe is installed with Microsoft Visual Basic and can be found in the System (or System32) directory.
When used, Regsvr32.exe attempts to load the component and call it's DLLSelfRegister function. If successful Regsvr32.exe displays a dialog indicating success. If the registration fails, Regsvr32.exe returns a basic error code.
To use the Regsvr32.exe utility to register a component perform the following steps:
Open an MS-DOS Command prompt or from the Windows Start menu, select Run.
Execute the following command line:
REGSVR32.EXE C:\WINDOWS\SYSTEM\COMPONENT.DLL
Component.dll is the DLL/OCX to register onto the system. The path to the component must be included in the command line.
Components can be unregistered using the /u command line parameter.
For additional information on Regsvr32.exe command line parameters, execute the following command from an MS-DOS command line:
REGSVR32.EXE /?
Reply 5 of 6, by MrMateczko
http://tihiy.net/files/RP9Updates.exe
Apply this, reboot, then install Revolutions Pack.
Also, make sure you are using the latest version here: http://tihiy.net/files/RP9.exe
Reply 6 of 6, by Oldskoolmaniac
^That fixed my problem thanks for the links.
