First post, by Kreshna Aryaguna Nurzaman
- l33t
No, I'm not talking about Lucid Logix's Hydra nor DirectX 12. Instead, I'm talking about a scenario where you have both Radeon and GeForce on the same system, and you can select the active video card according to the game you want to play.
Certain titles like European Air War or Jane's World War II Fighters cannot be played on GeForce newer than FX generation, but Radeon can play them without problems. However, there are also games that are problematic with newer Radeons, but play on GeForce flawlessly. An example is Crimson Skies, whose AA changes the aircraft into black silhouette on Radeon, yet the same AA works fine on GeForce. So I think it's nice if one could have Radeon and GeForce on the same system, switching between the two cards as necessary.
However, is such thing possible? Which driver should be installed first? Have anyone tried it before?
Kreshna Aryaguna Nurzaman.
