First post, by atar
Bought a V7 Mirage P64 card (S3-Trio64, 86C764-P). It works in a 440BX PC, but if I plug it into a Xeon E3-1275 v3 @ 3.50GHz / C220 mainboard, the screen doesn't show any signs of life. The card itself seems to be working, but not in this machine. On the other hand, Hercules Terminator S3-Trio64V+ works fine in both 440BX and C220 machines.
Tried switching off the both com ports, disabling the VGA-Palete snoop, increasing the PCI latency timer, but no avail. The card is recognized by the mainboard - once the linux boots I can login over the net and see it on the PCI bus.
Are there more known issues with the S3-Trio64 cards? Have anyone tried them in i5+ machines?
Reply 1 of 7, by r00tb33r
How different is the VBIOS on each card? I don't suppose it will blow up if you swap ROM chips...?
Reply 2 of 7, by Jo22
Hi atar, I had the same issues with installing one of my Trios in an AMD Athlon 64 (AM2) machine.
I'm not familiar with all of the details, but I guess it is somehow related with ISA-PCI address space mapping
(ie, loading the VGA BIOS from C0000 - C7FFF doesn't seem to work, though Windows sees the card in device manager if used as a secondary card).
Sorry, that i can't be more precise. Best thing I found was this link about PCI.. 🙁
PCI I/O and PCI Memory Addresses
http://www.tldp.org/LDP/tlk/dd/pci.html
Edit: The PC I tested my Trio card with was an M2N-NVM model by ASUSTek.
Not sure if it is relevant, but it has PCI-Express slots already (and built-in Geforce graphics).
Reply 3 of 7, by r00tb33r
Is loading address on the ROM? If that's the case swapping ROM chips between the cards might give some insight. I think they are similar enough that it just might work.
Reply 4 of 7, by atar
While they indeed look similar to a user, Trio64V+ requires quite a different chip wake-up sequence ( compare http://bitsavers.trailing-edge.com/pdf/s3/Tri … rator_Jul95.pdf , section 13.1 : "CHIP WAKEUP" with http://www.vgamuseum.info/index.php/component … fa1ea50a13d0c31 section 11.1 : "CHIP WAKEUP"), so unless the VGA BIOS writers cared of different chips, it won't work. And supporting both of them is not trivial, here are more details on this: http://tyom.blogspot.de/2017/03/hercules-term … rikes-back.html . I doubt there is a VGA BIOS except of OFW which would work on both. That's why I needed testing in the other thread.
Reply 5 of 7, by atar
Hi Jo22, this made me test it on my AM2 machine too. Works out the box.
Mine is from ASROCK, but also has PCI-Express and buit-in Geforce. Although the Mirage card works fine in it, the main board has an NVIDIA chipset, and thus no IOMMU. So, I can not use it for my experiments.
After poking some VGA registers, I see that Trio64 doesn't even start the PLL. Which makes me think. Can it be that the new mainboards have slightly different PCI voltages?
Not starting PLL is definitely a hardware problem.
Reply 6 of 7, by yawetaG
Maybe the card only works in 5V PCI slots and not 3.3V ones, despite fitting in both?
What happens if you disable the on-board video? If you can't manually disable it, it might be that the motherboard doesn't support video cards in other slots than specific PCI-Express slots...
Reply 7 of 7, by atar
It looks like something like that, but I don't think any of my boards has 5V slots. They were only in early Pentium mainboards, right? At least from a look all my PCI slots are identical.
Unfortunately there is no setting for that. The on-board video switches off auto-magically. But I don't expect it to be the reason because a) there is no signal on the onboard video and b) a Trio64V+ card works fine in the same PCI slot. Tried actually multiple ones. Trio64V+ works everywhere, Trio64 doesn't.
Update: I stand corrected. There is a setting for disabling the on-board video, but disabling it makes no difference.
