S3 Trio64V+ vs Trio64UV+
First post, by appiah4
I can get one of these two cards, but I can't seem to understand the difference between them and their memory configurations.. The photos of each card are below:
Is one better than the other?
Reply 1 of 5, by keropi
Get the 2nd that has more vram and could also be faster because of the later "gpu"
Reply 2 of 5, by appiah4
But an S3 Virge/DX would be better than either of them, right?
Reply 3 of 5, by keropi
I believe it will be slightly faster in 2D operations (and ofcourse adds the "3D" ability but that's not really an advantage in this case)
Reply 4 of 5, by vlask
Wrong 😉 2nd one is lowcost version using system memory share to increase its memory size. It have 4 chips, but only 1MB of memory and maximum is 1.5MB. If he get somewhere another chips, then can have 2MB of memory with 1st one....
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 5 of 5, by keropi
^ wow!
and there I was thinking that the higher part number meant better IC. Good to know about UV+ cards 😀
