First post, by u1comp1
In 3dmark03 on Windows 10 Creative Alchemy does not work. This is necessary to run the audio test, which is in 3dmark03. At startup, an error message appears and 3dmark03 does not start. Compatibility modes with other versions of Windows do not help. On Windows 7, everything works. What decision can be made? Or maybe there is some fix for this?
Reply 1 of 1, by UCyborg
There must be some oddity on your side, ALChemy works fine on Windows 10 (I tried). What does the error message say? Does the dsoundlog file appear in 3DMark03 folder when you run it? If it does, post its content. Does ALChemy work for other games?
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
