First post, by lowlytech
I have a packard bell 386 machine that has a 386 chip that looks like it is socketed. I have never messed with a chip like this and thought I would ask before I tried to remove it from the mainboard. I would like to put a 33Mhz DX chip in there as it is currently a sx-20.
    1.46 MiB
Reply 1 of 12, by gdjacobs
Please take a photo of the clock gen to the right. Some motherboards don't have a pll and require a different crystal to change clocks.
Reply 3 of 12, by lowlytech
Hal, do you know any other info on this board? Like what kind of cache ram I am assuming goes in those two 28 pin sockets? I vaugly remember another post here on the forum where someone put the wrong cache in and it smoked and blew up.
gdjacobs, here is the pic of the generator I think you wanted. The fact that it is 40MHz pretty much gives it away that we are stuck at 20MHz I assume?
    1.87 MiB
Reply 4 of 12, by Anonymous Coward
This is a really awesome setup. You have a removable 386SX CPU and cache. I've never seen them together like that. Please show more photos. Can the motherboard be adapted for other cases?
Reply 5 of 12, by gdjacobs
Crystals can be replaced, so theoretically 25mhz is possible on this CPU assuming the ISA bus doesn't clock synchronously and explode.
Reply 6 of 12, by lowlytech
I took a few photos with my better camera of the board. I don't know if this loosely follows the LPX standard or not, but that 4 ISA riser card might be a bear to move into a different case.
Here is the link to the photos I saved on google drive..
https://drive.google.com/drive/folders/0B2u7G … M1E?usp=sharing
Does anyone know where I could possibly get documentation for this board? I would love to know what the jumpers do, and what my options are for adding cache. I assume those two chips near the front of the board with the -25 are cache, and the -80 is the video ram.
Reply 7 of 12, by lazibayer
lowlytech wrote:
I took a few photos with my better camera of the board. I don't know if this loosely follows the LPX standard or not, but that […]
You are right. The board has 16KB cache. I guess the two empty sockets are for another two 8K x 8bit SRAM chips.
Reply 8 of 12, by lowlytech
I don't know much about cache, but would this be the chips I need to upgrade the cache?
http://www.ebay.com/itm/IDT7164S25P-CMOS-Stat … %3D391377191204
Reply 9 of 12, by Anonymous Coward
You know, you can buy TI 486SXLC-40 and 486SXLC2-50 CPUs that will fit into your CPU socket.
Make sure you don't buy the V or G series though. You need to verify it's a 5V model.
Usually -040 indicates a 5V 40MHz model, -G40 would be 3.3V core with 5V I/O at 40MHz, and -V40 would be pure 3.3V 40MHz.
I *think* this TI 486SLC will work, but I would verify the part number:
http://www.ebay.com/itm/TX486SLC-E-33PAF-Texa … GsAAMXQ1ZhTf0Wq
Reply 10 of 12, by lowlytech
A.C., thanks for the heads up with the cpu upgrade option. I will keep that in mind.
Any other thoughts on the cache upgrade from the previously posted ebay link? I just am paranoid that I will let the magic smoke out if I get the wrong thing.
Reply 11 of 12, by Anonymous Coward
You need this:
http://www.ebay.com/itm/Chip-Winbond-W2465AK- … 6YAAOSwB-1Y25xx
Reply 12 of 12, by lowlytech
Thanks so much for pointing me to the proper cache chips to order. Got them on the way, however after reading a snapshot of this motherboard from the wayback machine it is saying I need a CACHE32.COM file to be able to enable the extra cache. Any ideas where I might find this file?
https://web.archive.org/web/20000313020622/ht … b55/PB55ovw.asp
