King_Corduroy wrote:Huh that's a weird one, any date stamps on it anywhere? I thought generally NEC took over Packard Bell around '98 so it's a little strange it's a P166 (think that's what you said but can't find it now 🤣).
Specs can be found here (in Japanese): http://web.archive.org/web/19980216132122/htt … ec_promatev.htm
Although the page is from 1998, the release date listed is November 1996 and the CD-ROM drive also has a date stamp of November 1996.
Yesterday I repaired the case damage by gluing the bits back in place with superglue:
The attachment IMG_7166.jpg is no longer available
Not a perfect fix, but will do.
I then replaced the CMOS battery, which was a pain in the behind to do because the battery holder held the battery so tightly I had to wedge it out with a flat screwdriver. Today I changed some BIOS settings, discovered the system can actually boot from CD, and later had to change some more settings because setting it to a Plug 'n Play OS causes the onboard sound card to fail in Windows 98 DOS.
I then installed my old Adaptec SCSI controller card, and checked whether it was properly detected at boot and whether I could access the card's BIOS utility:
The attachment IMG_7168.jpg is no longer available
That all worked fine, so it was time for the moment of truth:
The attachment IMG_7169.jpg is no longer available
Hooked up my old 1Gb SCSI hard disk, an old Compaq server disk. Upon power on, the disk spun right up! 20 years after I last tried to use the drive, I could access my old files on the drive... 😘
The attachment IMG_7170.jpg is no longer available
...at least, some of them. Some directories threw up read errors, so off to Scandisk it was. Scandisk has been finding a lot of cluster errors until now, and a partially trashed MBR. The last system this was hooked up to was a AMD Duron MSI-based system with a intermittent power issue that caused it to destroy 2 IDE hard disks and damage a third (that still works fine 15 years on in another system). That system also failed to spin up/read this drive properly, and I also couldn't access the SCSI card's BIOS on it, so I guess the damage was caused back then.
I'll have to wait until Scandisk finishes its simple tasks (might take a while), do a surface scan, and then I think I will reformat the drive and check whether I can use it as a boot disk if I have an IDE CD-ROM drive present.
And I'll need some 5.25"->3.5" brackets to mount it because it's too tall to fit into the standard drive bracket...but I will only buy those after checking whether it works properly. Otherwise I'll have to try and find a larger SCSI drive (if I can boot from SCSI) or IDE drive (might go with a 4Gb CF card).
