Suntac 80286 Mainboards
First post, by Predator99
This week I received the 80286 board I ordered here
Paid much too much money but I liked to have it.
Its my 4th Suntac 80286 Board. Reason I am collecting them is that my 1st Computer from around 1988 I learned everything with had such a Mainbaord. Unfortunately I have "lost" the whole Computer within the last 5 years. I spend days to search everywhere but I didnt find it 😢 A GUS PnP Pro was also installed. Still have not found exactly the same board again.
So I will use this thread to post pictures, manuals and BIOS images of these boards. Hope its interesting and maybe useful for somebody else trying to get these running...otherwise delete 😒 Contributions are welcome 🤣
So 1st the unboxing of this "brand new" Magitronic A-B236 board.
Unfortunately the box and the manual is in bad condition and rather moldy....as said, paid too much for it 😵
1.96 MiB
1.65 MiB
Will add a Scan of the manual and the contents of the driver disk in the next days...
2.14 MiB
2.58 MiB
The board itself is in very good condition. The battery already started leaking and I removed it in good time. Not too much damage. Yes, its unused and new!
3.34 MiB
Reply 1 of 174, by Predator99
3.07 MiB
2.52 MiB
2.58 MiB
Reply 2 of 174, by Predator99
I installed RAM, CPU and BIOS from this still damaged board
SUNTAC 80286 Mainboard help
and it works perfectly 😎 😎 😎
3.3 MiB
2.47 MiB
1.65 MiB
____
After taking a second look the driver disk seems to be only a copy, the label does not match the content. However, the correct Suntac EMS driver is included, together with drivers for NEAT Mainboards and a BIOS Setup utility. All included in the ZIP.
1989-09-13 11:39           462           104  ATSETUP.BAT
1989-09-13 11:53 38 36 EMS.BAT
1989-09-13 11:51 235 110 NEAT.BAT
1988-06-03 16:12 12720 7647 ATSETUP\SET286.EXE
1986-06-30 10:28 24096 11776 ATSETUP\SETUP.COM
1988-02-06 16:07 11067 5296 ATSETUP\SETUPAT.COM
1989-09-13 12:00 377 253 EMS\EMS.DOC
1988-11-14 10:49 12754 4777 EMS\SEMS4.SYS
1988-12-22 16:29 12757 4758 EMS\SEMS5.SYS
1989-05-02 17:56 38 38 NEAT\CONFIG.SYS
1988-11-07 20:10 22000 5868 NEAT\EMM.SYS
1987-12-10 11:15 3330 1361 NEAT\EMM400.DOC
1989-05-02 09:56 5439 1656 NEAT\MGTNIT.EXE
1987-11-07 09:42 177816 16081 NEAT\NEATCNET.DAT
1987-11-07 09:42 4079 555 NEAT\NEATPGND.DAT
1988-10-04 10:51 27680 9547 NEAT\SETNEAT.COM
SUNTAC-62 Chip Set EMS Driver Version 4.0 Release 1.0 (C) LIUSKI-MAGITRONIC
Suntac ST 62 80286 EMS Driver.zip
70.13 KiB
220 downloads
The manual also does not really match to this exact kind of baord layout. The board in the manual does not seem to have SIP sockets.
Magitronic B236 80286 Suntac Manual.pdf
4.78 MiB
222 downloads
So..not a good deal, but nice to have. If somebody interested anyway, the dealer has more of these boards available...
Reply 3 of 174, by gdjacobs
Maybe a candidate for a SIMM slot mod/adapter?
http://sbfmdrv.blogspot.ca/2016/01/using-simms-as-sipps.html
Reply 4 of 174, by Predator99
Yes, this looks interesting and these adapters are new to me!
But I have some SIPs available and this board going to be stored in the shelf 😉
I have added driver disk and manaul above.
Reply 5 of 174, by Predator99
So next example is the board from this thread
2.27 MiB
2.61 MiB
It looks like it is in very good condition, but it is still not working. BIOS, RAM etc are OK as I tested them in the Magitronic board above
Jumper settings are here, thanks again to creepingnet for the link:
http://www.uncreativelabs.de/th99/m/U-Z/33180.htm
Screenshots from the Magitronic above are with the BIOS shipped with this board, its Award V3.03HLS
286 Modular BIOS Version 3.03HLS Copyright Award Software Inc.
BIOS images here...
SUNTAC 80286 Award V3.03HLS BIOS.zip
43.44 KiB
104 downloads
Reply 6 of 174, by Predator99
3rd one is this here
3.01 MiB
2.66 MiB
AUVA COMPUTER, INC. BAM/12-S2
Jumper configuration is here
http://stason.org/TULARC/pc/motherboards/A/AU … -BAM-12-S2.html
http://th99.classic-computing.de/src/m/A-B/32297.htm
As I got this board I was confused because of the weird setting of the DRAMs - has somebody forgot the 4 chips while scrapping the board? But its the correct configuration: "When there are 2 chips in Bank 0 or Bank 1, they are placed in BS1 and BS2 respectively."
Fortunately this board works without problems now. The leaking battery destroyed all traces connecting to the keyboard, but I replaced them with wires.
BIOS is the Phoenix 3.10 10.
1.79 MiB
1.63 MiB
Suntac Phoenix BIOS 3.10 10.zip
47.67 KiB
85 downloads
I assume all those BIOS are exchangable between the different boards even if there are minor differences in memory configuration...
Reply 7 of 174, by Predator99
My currently last board is this here. Powered up one time and never again 🙁
"SER 286S"
2.48 MiB
3.23 MiB
Award BIOS Version 3.03GS
1.36 MiB
Suntac-ROM2.zip
23.17 KiB
85 downloads
Reply 8 of 174, by Predator99
And this is the manual of the board that was installed in my 1st computer which is lost and I am searching for - HT-286.
HT-286r.pdf
2.25 MiB
155 downloads
The manual is quite interesting as a wiring diagram is included.
3.29 MiB
4.04 MiB
4.04 MiB
4.08 MiB
Thats it for the moment - hope it will also be for some use for you 😉
Reply 9 of 174, by Robin4
Thanks for sharing all of this information.. I really hope it would be usefull to get my suntac 286 boards running again also.
Reply 11 of 174, by Predator99
So this is my newest acquisition from this lot 😀
Re: Bought these (retro) hardware today
It looks as it was never installed, battery was removed and slight green corrosion in one ISA slot...but overall conditions is excellent!
4.27 MiB
4.05 MiB
2.46 MiB
Bios message (AWARD) is "HLB-286 SYSTEM"
On the board "MBA-009" is printed, dont know the manufacturer.
Will add BIOS images later when I have time to install a disk drive...
HLB-286.rar
65.68 KiB
94 downloads
Reply 12 of 174, by skyline486
I bought the same suntac motherboard of the OP.
I found the system bios rom files from the other post by you. Where can you find the rom file to flash for the keyboard bios?
Sorry I'm new to this. Does all 27256 and 8742 works as system bios and keyboard bios?
Reply 14 of 174, by Predator99
Good question. I dont think there is a way to dump the keyboard bios? And also no way to reprogram such chip? I have read somewhere that Award and Phoenix are not interchangable. But currently my Phoenix Board is running fine with a Award Bios and the original keyboard bios installed. So a Award system BIOS accepts the Phoenix keyboard Bios.
I dont know about the compability of these chips. But I think you can try without the risk of damaging anything. Maybe also the one from a 386 will work? Havent tested this yet.
For system BIOS you can use many comptabible chips also with a larger capacity, doesnt need to be 27256.
Reply 15 of 174, by Jo22
Dumping a keyboard conntroller is difficult, because only a few modern USB programmers can read something like a i8742/i8042.
Making a memory dump is also not possible, since the controller's memory is not visible to the PC.
Edit; Some of the oldschool programmers do support the MCS-48/MCS-41 line of archaic microcontrollers.
But to do so, they may need an optional adapter: https://www.ebay.com/itm/302517478660 and https://www.ebay.com/itm/291526949389
Reply 16 of 174, by brostenen
A little tip... A year or so ago, I purchased a rechargeable coincell 3.6volt battery, and replaced a barrel battery with it. They are not super cheap, just affordable enough for a perfect alternative.... Pins ligned perfectly up with the holes on that 486 board I did the replacement on. And it fitted the edge of the motherboard beautifully. The new battery was recharging and did not get warm or hot at any time.
https://www.ebay.com/itm/New-LIR2032-Li-ion-3 … 4MAAOSwpDdVGVUE
Reply 17 of 174, by Predator99
Yeah got it 😀 😀 😀
This is almost the exact board I was searching for a long time: ST62M02-B. The manual I posted above and belonging to my 1st Computer is a ST62M02-A. I remember the CPU was in standard PLCC socket and the DIPs were red.
Already desoldered the battery.
It came with an AMI Diagnostic BIOS I have not seen before:
(C)1987AMI,404-263-8181
01/03/88286-ROM DIAGNOSTICS.(C)1987, American Megatrends Inc.All rights reserved.
4025 pleasantdale road, Suite-320,GA.-30340, Phone-(404)-263-8181.
Will post the BIOS later...
2.31 MiB
1.65 MiB
697.27 KiB
1.3 MiB
Reply 18 of 174, by Predator99
The seller of this one
send me today some additional documentation he found 😀 Its
- the complete manual of the PC with wiring diagram of the ST62 Mainboard and driver disk
- original invoice dated 1988: 286 Tower, 1 MB RAM, 1.2 MB Floppy, 20 MB ST-125, Monitor and Keyboard for 491 DM ... cannot compare how much money this was
- Hard Disk manual with bad tracks list
Will scan the manual and post it here together with a image of the driver disk when I have some time...
2.87 MiB
2.84 MiB
EDIT: Whats that the driver disk includes the source of the EMS driver..!
SEMS SYS 5,508 10-20-87 1:36p
SEMS ASM 37,120 10-20-87 1:35p
CONFIG SYS 15 05-16-88 8:26a
;* EMM/EMS driver program for SUNTAC-62 chip set version B1 *
;* sample program - 10/20/1987 rev. 1.02 *
    st62ems.zip
    10.96 KiB
    88 downloads
Reply 19 of 174, by Jo22
That roughly was ~250€ (or $295), based on the exchange rates from ~1999/2000. 😀
https://simple.wikipedia.org/wiki/Deutsche_Mark
