First post, by KingPing
Hello!
Im going to build a 486 PC with a AMD 486 DX4-100 (have both NV8T and the SV8B) and hopefully a VLB video card, problem is i've no idea which of this 2 mobos is better.
Option A:
ECS (i think) UM4981 AIO REV1.0
This rev doesn't support natively the AMD DX4-100, although it boots fine and says it's a DX2 at 100MHz (any problem with that?)
2.54 MiB
Option B:
FIC 486-PVT
2.45 MiB
Which one should i use???
Reply 1 of 6, by Ampera
IMO, Option A, but not having the boards take whichever one has pure 72-pin SIMM slots (Unless they both have them)
TBH I am in love with my EXP-4045, but that wasn't an option soooo.
Reply 2 of 6, by SSTV2
Make it simple, max out performance via BIOS settings on both MBs and use same hardware (gfx card, cpu, ram) to bench doom1/2 on them, that way you'll know better than anyone else which MB is faster.
Reply 4 of 6, by Anonymous Coward
Option 1. UMC chipsets are good. ECS 486 boards are good too.
Reply 5 of 6, by KingPing
Any problem with the UM4981 AIO Rev1.0 not supporting the DX-100?
It boots fine and report it as a DX2 100MHz, is there any danger of damaging something? I'll try both the ECS and the FIC and see which is faster anyway 😀
Reply 6 of 6, by Ampera
If it is running it at 3.3v or you are using a VRM adapter, then there is 0 issue. My guess is at the time the BIOS was programmed, the name DX4 didn't exist, so they just threw DX2 on there.
