xp
First post, by marjin_buu
i have windows xp and i dont now which one to download because theres so many
Reply 1 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
The technical terms on the download page might confuse you.
Windows 2000 and Windows XP (and open for debate) Win9x are classied as Win32
So the one you need is the one with win32 installer after its name
(second in the list.)
Water flows down the stream
Reply 6 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
🤣@harekiet
Consider reading the documentation called readme
and/or take a look here:
The Newbie's Pictorial Guide To DOSBox
Reply 11 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
add /g:bios when you start starcon2 (helps if you said which game it was)
if that doesn't work (it should) get a better cracked version as one of the cracks forgets to pass the /g:bios to real .exe
Reply 13 of 13, by Cthulhus
Use a frontend !!!! It's more easy to use with it !!
I use D-Fend and it's a nice sofware make DosBox easy to use
Sorry for my poor english ! 😉 But, try to speak french like I'm speak english ! 😀 It's not easy !
